Arduino OLED Snake Game
Hi and welcome, to our instructables on how to make and arduino OLED Game, this project came about as we were attempting to make our first ever game with an arduino, soooo, we thought where better to start than the nokia classic Snake (well at least a snake clone:) ).
What you Will Need
Supplies:
Arduino UNO or clone
OLED Display
4 Diodes
500-1k resistor
4 controller buttons
Passive Piezo buzzer
optional
Solderless BreadBoard
Please note these links are for example only
Teacher Notes
Step 1: The Circuit
In the above picture you can see our circuit, we use pin d3 on the arduino as an interrupt request pin so that the arduino will give priority to reading the controller inputs which are d4 d5 d6 d7. The basics of the circuit is that a direction button is pressed which goes high 5v this activates the interrupt request pin (d3 purple wire) and a corresponding direction pin, the interrupt function calls an update direction function and that code moves the snake accordingly. Pin 9 is used as the sound pin as it is a PWM (~ pulse width modulation) which is connected directly to a 5v piezo on the + pin and the - goes back to 0v/ground.
(FYI on the arduino uno and clones only d2 and d3 can act as interrupt request pins).
Direction pins:
d4 Up ORANGE
d5 Down PINK
d6 Left BLUE
d7 Right BROWN
d9 sound GREY
Each button has a in 5v connection input and an output that is connected first to their respective digital input on the arduino, this same output of each button is then connected to its own diode, we use the diodes to stop voltage feeding back through to the other buttons and activating them. On the cathode (-) end of all 4 diodes we join them together to create an output junction which connects to d3 and then through the a resistor to 0v/earth to pull the arduino pins low so as not to leave floating pins when not being activated.
(FYI a floating pin can receive phantom voltage and cause unusual behavior)
2 analog pins are used to drive the display, these are the arduino hardware i2c pins.
A5 is connected to SCL YELLOW
A4 is connected to SDA GREEN
The +5v and 0v (earth) output from the arduino is used as the source of the power for the whole circuit which can be powered by usb or phone charger.
Step 2: The Code
<p>//------------------------ ANJAWARE SNAKE Games With help from the net peoples ----------------------</p><p>#include<spi.h>
#include<adafruit_gfx.h>       //  <a href="https://github.com/adafruit/Adafruit-GFX-Library" rel="nofollow"> https://github.com/adafruit/Adafruit-GFX-Library
</a>
#include<adafruit_ssd1306.h>   //  <a href="https://github.com/adafruit/Adafruit_SSD1306" rel="nofollow"> https://github.com/adafruit/Adafruit-GFX-Library
</a>
// display set      (width,height)
Adafruit_SSD1306 display(128,64);
// define input pins these are the pins on the arduino they never change so #define
#define INTPIN    3       // only pins 2 and 3 can be interupt pins on UNO
#define UPPIN     4       // these are pins connected tp relevant switch
#define DWNPIN    5
#define LFTPIN    6
#define RHTPIN    7
#define SND       9
// define directions
#define DIRUP     1       // these values is what the "snake" looks at to decide-
#define DIRDOWN   2       // the direction the snake will travel
#define DIRLEFT   3
#define DIRRIGHT  4</adafruit_ssd1306.h></adafruit_gfx.h></spi.h></p><p>// set button variables</p><p>// volitile cos we need it to update with the interupt so can be any bit of cycle value
// is never higher than 4 so only need 8bit int to save resources
volatile uint8_t buttonpressed=0;
bool butup=0;
bool butdown=0;   // we use this to set true to "detect" which direction pressed
bool butleft=0;
bool butright=0;</p><p> // snake ints
byte snakePosX[30]; // array to make body of snake
byte snakePosY[30];</p><p>int snakeX=30;     // snake head position
int snakeY=30;
int snakeSize=1;   // snake size count limited to the size of the array</p><p>// world ints</p><p>uint8_t worldMinX=0;        // these set the limits of the play area
uint8_t worldMaxX=128;
uint8_t worldMinY=10;
uint8_t worldMaxY=63;</p><p>// collect scran(food) and position of scran
bool scranAte =0;
uint8_t scranPosX=0;
uint8_t scranPosY=0;</p><p>// scores variables
long playscore=0;
long highscore=30;  // set high score to 3 collect as a starting point</p><p>//--------------------------- this is what the interupt executes on voltage rise -------------------------
void interruptpressed()
      delay(150);  // slight delay for added "bounce" protection
      updatedirection();
// ------------------ update the direction value from button press -----------------
void updatedirection()
     // Serial.println("updatingdirection");
      butup=digitalRead(UPPIN);       // check which input went high and set relevant bool true
      butdown=digitalRead(DWNPIN);
      butleft=digitalRead(LFTPIN);
      butright=digitalRead(RHTPIN);
      // these if statemeents look at which input went high and enters the relevant value in "buttonpressed"
      // variable, this variable dictates the direction of movement
        if(butup==true)
              buttonpressed=DIRUP;
         //     Serial.println("UP pressed");
         //     Serial.println(buttonpressed);
              butup=false;
              tone(SND,1500,10);
        if(butdown==true)
              buttonpressed=DIRDOWN;
         //     Serial.println("DOWN pressed");
              butdown=false;
              tone(SND,1500,10);
          }</p><p>        if(butleft==true)
              buttonpressed=DIRLEFT;
          //    Serial.println("LEFT pressed");
              butleft=false;
              tone(SND,1500,10);
        if(butright==true)
               buttonpressed=DIRRIGHT;
          //     Serial.println("RIGHT pressed");
                butright=false;
                tone(SND,1500,10);
     }</p><p>//-------------------------- draw the display  routines-----------------------------------</p><p>void updateDisplay()  // draw scores and outlines
           // Serial.println("Update Display");</p><p>            display.fillRect(0,0, display.width()-1,8,BLACK);
            display.setTextSize(0);
            display.setTextColor(WHITE);
            // draw scores
            display.setCursor(2,1);
            display.print("Score:");
            display.print(String(playscore, DEC));
            display.setCursor(66,1);
            display.print("High:");
            display.print(String(highscore ,DEC));
            // draw play area
            //        pos  1x,1y, 2x,2y,colour
            display.drawLine(0,0,127,0,WHITE); // very top border
            display.drawLine(63,0,63,9,WHITE); // score seperator
            display.drawLine(0,9, 127,9,WHITE); // below text border
            display.drawLine(0,63,127,63,WHITE); // bottom border
            display.drawLine(0,0,0,63,WHITE); // left border
            display.drawLine(127,0,127,63,WHITE); //right border</p><p>    }
//----------------------------------- update play area ------------------------------</p><p>void updateGame()     // this updates the game area display
        display.clearDisplay();</p><p>          display.drawPixel(scranPosX,scranPosY, WHITE);
          scranAte = scranFood();   </p><p>            // check snake routines</p><p>              if (outOfArea()||selfCollision())
                      gameOver();
                   }</p><p>            // display snake
              for(int i=0;i<snakesize;i++)  ="" {="" display.drawpixel(snakeposx[i],snakeposy[i],white);="" }=""   ="" remove="" end="" pixel="" as="" movement="" occurs="" for(int="" i="snakeSize;i">0;i--)
                      snakePosX[i] = snakePosX[i-1];
                      snakePosY[i] = snakePosY[i-1];
              // add a extra pixel to the snake
              if(scranAte)
                    snakeSize+=1;
                    snakePosX[snakeSize-1]=snakeX;
                    snakePosY[snakeSize-1]=snakeY;
                  }</snakesize;i++)></p><p>            switch(buttonpressed) // was snakeDirection
                    case DIRUP:
                        snakeY-=1;
                        break;
                    case DIRDOWN:
                        snakeY+=1;
                        break;
                    case DIRLEFT:
                        snakeX-=1;
                        break;
                    case DIRRIGHT:
                        snakeX+=1;
                        break;
             snakePosX[0] = snakeX;
        snakePosY[0] = snakeY;
             updateDisplay();
          display.display();
 // --------------------- place the scran -------------------
        void placeScran()
              scranPosX=random(worldMinX+1,worldMaxX-1);
              scranPosY=random(worldMinY+1,worldMaxY-1);               }
//------------------------ SCRAN ATE POINT UP ----------------
        bool scranFood()
                  if(snakeX==scranPosX&&snakeY==scranPosY)
                          playscore=playscore+10;                           tone(SND,2000,10);
                              updateDisplay();
                              placeScran();
                            return 1;
                    else
                          return 0;
//--------------------- out of area----------------------    bool outOfArea()
          return snakeX <= worldMinX||snakeX >=worldMaxX ||snakeY<=worldMinY|| snakeY>=worldMaxY;
//---------------------- game over--------------------------    void gameOver()
          uint8_t rectX1,rectY1,rectX2,rectY2;
          rectX1=38;
          rectY1=28;
          rectX2=58;
          rectY2=12;
          display.setCursor(40,30);
          display.setTextSize(1);
          tone(SND,2000,50);
          display.print("GAME ");
          tone(SND,1000,50);
          display.print("OVER");
          if(playscore>=highscore)   //check to see if score higher than high score
                highscore=playscore;  //single if statment to update high score
          for(int i=0;i<=16;i++)   // this is to draw rectanlges around game over
                  display.drawRect(rectX1,rectY1,rectX2,rectY2,WHITE);
                  Serial.println("if loop");
                  display.display();
                    rectX1-=2;      // shift over by 2 pixels
                    rectY1-=2;
                    rectX2+=4;      // shift over 2 pixels from last point
                    rectY2+=4;
                    tone(SND,i*200,3);
           display.display();
                    //Screen Wipe after fame over
                    rectX1=0;   // set start position of line
                    rectY1=0;
                    rectX2=0;
                    rectY2=63;                for (int i =0;i<=127;i++)
                           uint8_t cnt=0;
                           display.drawLine(rectX1,rectY1,rectX2,rectY2,BLACK);
                            rectX1++;
                            rectX2++;
                            display.display();
          playscore=0;        // reset snake and player details
          snakeSize=1;
          snakeX=display.width()/2;
          snakeY=display.height()/2;           waitForPress();        // wait for player to start game          }
//-------------------------wait for presss loop -------------------------
        void waitForPress()
                bool waiting=0;  // loop ends whjen this is true
                while(waiting==0)
                              drawALineForMe(WHITE); // draw a random white line
                              drawALineForMe(BLACK); // draw a random black line so that the screen not completely fill white
                              display.fillRect(19,20,90,32,BLACK); // blank background for text
                              display.setCursor(35,25);
                              display.setTextSize(2); // bigger font
                              display.println("SNAKE");
                                              //    x  y   w  h r  col
                              display.drawRoundRect(33,22,62,20,4,WHITE);  // border Snake
                              display.drawRect(19,20,90,32,WHITE);         // border box  - 3
                              display.setCursor(28,42);
                              display.setTextSize(0);  // font back to normal
                              display.println("press any key");
                              display.display();
                              waiting = digitalRead(INTPIN);  // check to see if key pressed waiting will change to 1 ending while
                              buttonpressed=0;     // reset button press
//--------------------DRAW a random line input colour uint8_t-------------------
    void drawALineForMe(uint8_t clr)
                     uint8_t line1X,line1Y,line2X,line2Y=0;
                          // set random co-ordinates for a line then draw it
                          //  variable         no less      no more
                              line1X = random(worldMinX+1,worldMaxX-1);
                              line1Y = random(worldMinY+1,worldMaxY-1);
                              line2X = random(worldMinX+1,worldMaxX-1);
                              line2Y = random(worldMinY+1,worldMaxY-1);
                              display.drawLine(line1X,line1Y,line2X,line2Y,clr);
//-------------------------------------  collision detecion -------------------------------<br>
          for(byte i=4;i<snakeSize;i++)
                     if(snakeX==snakePosX[i]&&snakeY==snakePosy[i])
				return 1;
                          	tone(SND,2000,20);
                                tone(SND,1000,20);
                   return 0;
//-------------------------------- SETUP----------------------------------------------
void setup()
    delay(100); // just give stuff a chance to "boot"
    //    Serial.begin(9600);  // uncheck this if you want to see the serial outputs
    display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
    display.clearDisplay();   // start with a clean display
    display.setTextColor(WHITE);// set up text color rotation size etc
    display.setRotation(0);
    display.setTextWrap(false);
    display.dim(0);         // set the display brighness
    pinMode(INTPIN,INPUT);  // set the correct ports to inputs
    pinMode(UPPIN,INPUT);
    pinMode(DWNPIN,INPUT);
    pinMode(LFTPIN,INPUT);
    pinMode(RHTPIN,INPUT);
    // this is the interupt command this "halts" the arduino to read the inputs
    //command-          function-         pin-function to execute-condition on pin
    attachInterrupt(digitalPinToInterrupt(INTPIN),interruptpressed,RISING);
    // Serial.println("Setup Passed");
    waitForPress();    // display the snake start up screen
    placeScran();  // place first bit of food
//---------------------MAIN LOOP---------------------------------------
void loop()
    updateGame();  // this function is what carries the main code
Step 3:
Games Contest
Games Contest
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    2 Discussions
    asmgabberPenolopy Bulnick
    Reply 5 weeks ago
    no problem and we hope you enjoy (we as in my daugher and myself :) )
