Arduino Temperature and Humidity Clock
Introduction: Arduino Temperature and Humidity Clock
About: If you enjoy my projects, consider becoming my Patreon: https://www.patreon.com/Ferferite
In this instructable,i will show you how to build a Temperature and humidity clock,using I2C lcd on the Arduino Nano
Teacher Notes
Step 1: Watch the Video
Step 2: Buy the Components
For this,you will need:
-I2C 16x2 LCD
-DHT11 Temperature and humidity sensor
-Arduino Nano
NOTE:You will need a usb Micro B cable to power the arduino
Step 3: The Wiring
The display
SCL → A5
SDA → A4
GND → GND
VCC → 5V
Temperature sensor
OUT → D2
GND → GND
VCC → 5V
Step 4: The Code
You will need to download Arduino Software and open the sketch.
After you open the sketch,connect the arduino board to the computer,select the port and the Arduino board(You need to select Arduino nano) from Tool menu.
Step 5: The Case
Here are the 3D files for the case
After printing it,glue everything and you are done!
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
