Introduction: DIY. 3D Led Cube 8x8x8 3mm
This project is made by our customer Kohonov.
3D LightSquared DIY Kit 8x8x8 3mm LED Cube White LED Green Ray
Step 1: Accessories
1.1.512 x 3mm white green LED
2.2 x XH2.54-40P round female pin
3.9 x 20P IC socket
4.9 x74HC573 DIP
5. 1x USB to DC005 cable
6.1 xDC005 power socket
7.1 x18P IC socket
8.1 x ULN2803 DIP
9.1 x 40P IC socket
10.1 x STC12C5A60S2 (with code)
11.1x A09-103 Resisters
12.1 x8*8 Self-locking switch
13.2 x 10uf 25V electrolytic capacitor
14.1 x12MHz crystals
15.2x 22pf ceramics capacitor
16.8 x 470ohm resistor
17.2x 4.7K ohm resistor
18.1x LED 3mm
19.1x 0.8mm cable
Step 2: Solder Contacts Are Cleaned to the Board. A Total of 72 Pieces
Step 3: Go to the Resistors, Capacitors and Other Small Things
On the product page shows the type of resistors SMD. In fact, come resistors type MLT. Soldered resistors, and their 10 pieces, 4 capacitors, quartz resonator, the power button, power connector, 9-pin LED and resistor A09-103.
Step 4: Go to the Soldering DIP Sockets for ICs 8 Panels of 20 Pins, 1 Bar for 18 Contacts and 1 Bar for 40 Contacts.
Step 5: Fix the Plastic Stand on the Board and Chip Set
Step 6: Go to Work With LEDs
For convenience, soldering LEDs I made a template of Plexiglas. Draw the lattice 8 x 8 mm with an interval of 15 and drilled holes diodes.
