Introduction: BaW-Bot Part 3: Adding Sight and Touch to the Bot
This is the third part of our BaW-Bot (Bells-and-Whistles Bot) build – 5 separate instructables that look into different Arduino-related technologies, combining to create a Bot with all the bells-and-whistles.
Part 1: Build an Arduino on a Board
Part 2: Build the motor-controller & body
Part 4: Blinging up the BaW-Bot
Part 5: Taking it to the Next Level
In this instructable, we’ll be giving our Bot some freedom by adding sensors to keep it safe. We’ll be adding an ultrasonic sensor (“eyes”) as well as 2 lever microswitches (“whiskers”). We’ll also be building a “leash” so that we can keep it out of trouble while we develop the bot.
Step 1: The Parts
You'll need the following parts, as well as the body and Arduino you built in Parts 1 & 2 of this series. There are many different models and manufacturers - I've simply linked to the parts I have, you can opt for your own preferred supplier/model:
1 x IR Receiver (38KHz)
1 x Household Infrared Remote Control (TV / stereo / iPod / etc.)
1 x Ultrasonic Range Sensor
2 x Lever Snap Action switches
Connector wires
2 x 10k Ohm resistors
Connector wires
Step 2: Rein the Bot In
You may have struggled with the Bot during the previous instructable, as it starts driving around as soon as you connect the power. Let’s get it under control, so that it only starts moving once you press a button on a remote – and stops moving when you press the same button again. The “stop” button will become useful as you start experimenting with sketches that help the robot avoid obstacles. As you know, most remotes use Infrared (IR) – so the next few steps will take us through implementing this. We could have used a simple push-button, but this is more fun…
Help from Ken
Ken Shirriff has written a few great blogs on getting IR working on an Arduino (check out http://www.arcfn.com/), and has also written a very useful library. We’ll use that library for this instructable (thanks Ken!) – even though we won’t use close to all the functionality it offers.
To begin, download the library from the link on Ken’s page on his Infrared Remote Library and unzip it into your Arduino folder:
arduino\libraries.
If you’re using version 1.0 or higher of the Arduino IDE, you’ll need to edit the file “IRRemoteInt.h” and change the line:
#include <WProgram.h>
to
#include <Arduino.h>
Then restart the IDE.
Help from Ken
arduino\libraries.
to
Step 3: Connect the IR Receiver
Remove the Boards
Remove the breadboards from the body, so we can work on them more easily. Make sure you disconnect the motor power supply - we don’t want the Bot to run away from us while we’re testing.
Refer to the fact sheet for the IR Receiver – you’ll see it has 3 pins – Vs, GND and OUT. For this test, mount the IR Receiver on the Arduino breadboard, and connect:
- Vs to the +ve power rail
- GND to the GND power rail
- OUT to pin 12 (i.e. physical pin 18 on the ATmega chip).
Step 4: Test the IR Receiver
Upload a Test Sketch
Upload the sketch below using the FTDI breakout board. This was written by Ken, and simply prints out any IR codes the sensor receives, to the Serial monitor (I have modified to print decimal instead of Ken’s original hex).
Test a few Remotes
Once the sketch is uploaded, start the Serial Monitor in the Arduino IDE (Tools, Serial Monitor).
Point a number of remote controls at the sensor, and watch what comes out on the serial monitor when you press their various buttons. You should see output similar to the image above. Do you notice that each button generates a slightly different code? These unique codes will allow us to write a sketch that reacts to a particular code – i.e. a particular button on a remote.
In some cases one button might generate multiple codes, or holding a button down could result in a single code repeating – we’ll ignore these for this project.
Copy the Code for your chosen button
Now that you’ve seen how the codes appear, press the button that you want to use to stop/start the BaW-Bot. Now copy and paste the code from the Serial Monitor into a temporary test document – we’ll need it later.
For my bot, I used the play/pause button on my iPod docking station remote. This generated 2 codes, so I just took the first one: “2011265621”
Now let's put this code to good use.
Test a few Remotes
Step 5: Get Things Under Control
Before we continue, let’s see how the remote works with your bot. Put the boards back into the BaW-Bot, and download the sketch below. This is a very simple sketch that moves and turns the bot as you press your chosen button on the remote.
Once you’ve opened the sketch in your Arduino IDE, make sure you replace the IR code from the previous step onto the line that reads (replace the portion in bold):
const unsigned int irCodeStartStop = 2011265621;
Connect your batteries, and the bot should not move. Press the button and it should for each press, move forward / stop / turn / stop.
Now that you’ve got your BaW-Bot under control, you are one step closer to setting him free to explore.
Step 6: Give the Gift of Sight
To keep our BaW-Bot safe, we’re going to give him sight – this will stop him from bumping into most things. In fact, we’re not actually giving him sight, but more sound – incredibly fine-tuned hearing – by connecting an ultrasonic rangefinder.
To use this module, we send out a “ping” (like a submarine’s sonar) and time how long it takes to bounce back. The time taken tells us how far away the object is, and whether we should keep going or panic and drop the anchors.
First up, we need to mount the ultrasound module onto the robot. If you’ve also used cardboard for the body, then you can simply cut a hole and fit the sensors through the holes – if you’ve used a conductive material you’ll need to mount it and ensure that it is insulated from the body.
Connections
The connections are also extremely simple – the same as the IR Receiver, in fact:
Connections
- Connect VCC to the +ve power rail
- Connect GND to the –ve power rail
- Connect SIG to pin 4 on the Arduino (i.e. physical pin 6)
Step 7: Add a Sense of Touch
If you read the fact sheet on the ultrasonic rangefinder, you’d see that it has some fairly large blind-spots – particularly when approaching an obstacle at an acute angle. To cover our bases, we’re going to give the robot some whiskers, to pick up those small items that escape the sonar. These whiskers will take the form of lever microswitches which project beyond the edge of the body.
Solder Connectors onto the Switches
The best way to connect the switches to the project is to solder wire connectors on the switch contacts. You’ll see that I am using SPDT (Single Pole, Double Throw) switches, but for this project you can use SPST (Single Pole, Single Throw) switches as well.
Cut Holes in the Body
Cut small rectangular holes so that the whiskers project beyond the side of the robot, but the switches are hidden inside. Bolt them onto the body to keep them in place.
Wire the Switches Up
As with all switches and buttons, these do not provide a reliable signal when they are not closed (i.e. making contact) – they float, randomly sending HIGH or LOW signals. Therefore we need to either pull the switch up or down when it’s open – in this case we want the switch to be LOW so we pull it down with a 10k pull-down resistor.
If you're using a SPDT switch, you'll have 3 connectors - which 2 of these should you use? An easy test is to use a multimeter (or even test it on a breadboard like the circuit in the image above, adding an LED) and make sure that the circuit is complete when the switch is closed (activated).
For each switch:
Connect the left-hand switch to Pin 2 and the right-hand one to Pin 3.
As the board is getting complex now (a bit of a ratsnest), I’ve included an image above of the wiring needed on an empty breadboard for clarity.
For each switch:
- Connect one terminal to +ve rail
Connect the other terminal to breadboard. On the same row in the breadboard:
- connect a 10k Ohm resistor to GND (the pull-down resistor)
- connect a jumper to the relevant pin on the Arduino
Step 8: Set the BaW-Bot Rolling
Now that we’ve finished with all the sensors, let’s get the BaW-Bot moving. All you need to do now is to upload the sketch below and power the Bot up.
The logic in brief:
As the Bot approaches an obstacle, it slows down and pings the ultrasound more frequently.
When the Bot comes within 10cm (approx. 4 inches) of an obstacle it reverses and turns left.
When the left lever-switch activates it brakes, then reverses and turns right.
When the right lever-switch activates it brakes, then reverses and turns left.
Some comments on the sketch:
All reverse and turn manoeuvres are based on time, not distance – so depending on your motor speed and wheel diameter you may need to alter these. I’m using slow motors and small wheels, so everything takes longer.
The ultrasound sensor doesn’t always give accurate readings, so I’ve used a simple algorithm I borrowed sometime in the past to calculate an average of 5 values – this smoothes the Bot’s behaviour to an extent.
The obstacle-avoidance logic is far from perfect – it’s meant as a basic platform to get the BaW-Bot running and is there to for you to build on – please share any clever algorithms you come up with!
The sketch is close to utilising the maximum available memory – if you add a whole bunch of variables and Serial.print commands for debugging, it will start overflowing and likely hang at odd moments. There are ways around this – but that’s for another instructable.
The lever microswitches are connected to the Arduino pins that are interrupt-enabled. You could expand the sketch by using interrupts to drive the behaviour when the lever-switches are activated.
Thanks for building this with me - please let me have any comments
Coming up next - blinging the BaW-Bot up a little.
The logic in brief:
