Big, Auto Dim, Room Clock (using Arduino and WS2811)
172,301
834
220
First Hello instructables.
This is my first contact with :
  • Instructables
  • Arduino
  • Programmable LED's
So please don't trow rocks at me for noobish mistakes.
Keeping that in mind I'm waiting to read your comments with grate interest and I'm open to any suggestion
Features :
  • big digits ( each digit is approximately the size of a A4 paper).
  • slim in order to fit in a photo frame (a big one).
  • auto dim the light depending on the light in the room.
  • dedicated DST button.
Teacher Notes
Step 1: Prerequisites
Things I used for this project :
Electronics :
  1. Arduino nano V3.0 (sadly since I can't afford an original arduino I used a chinese clone, for showing my support I donated 2.9 $ to arduino) - 2.9$ on ebay
  2. Digital Light Intensity Sensor Module Photo Resistor for Arduino - 0.99$ on ebay
  3. DS3231 AT24C32 IIC Module Precision Real Time Clock Quare Memory for Arduino - 0.99$ on ebay
  4. DC-DC Buck Converter Step Down Module LM2596 Power Output 1.23V-30V - 0.90$ on ebay
  5. 4m WS2811 led strip 30 leds/m - 12 $ on aliexpress (1 WS2811 IC control 3 LED Chip)
Total cost of electronics : 17.78 $ (without arduino donation)
Miscellaneous :
  1. Heat Shrink Tubing - 7.99$ ebay (assortment, it total 33m)
  2. 20 pcs 5 x 7 cm prototype pcb - 3$ ebay
  3. 3 pcs Micro Switch - 1$ locally bought
  4. Solder - 1$ locally bought
  5. Flux - 1$ locally bought
  6. UTP cable (individual wires used for various connections)
  7. LCD font (http://www.dafont.com/lcd-lcd-mono.font) - free
  8. Cardboard - free loacal supermarket
  9. Polystyrene board - 1.50$ locally bought
Various tools.
Step 2: Preparing - Digit Template
  1. download and install LCD font (http://www.dafont.com/lcd-lcd-mono.font
  2. open word or similar editor and make a template similar to the image (first img)
    • font size ~800,
    • white font color black outline,
    • gray boxes where led strip fits
  3. Print and cut the gray strips with a exacto knife (second img)
Step 3: Preparing - Cut Cardboard and Led Strip
Using the digit template cut the cardboard to size (don't forget to leave space for the dots between hours and minutes)
If your LED strips came with connectors at each end (like mine did) desolder the connector and cut them in sets of 3.
Step 4: Stick the LED Strips
Using the template stick the LED strip on the cardboard.
It's not mandatory but I used a pencil to mark where the LED strips should be placed, this way I got to see the final form before attaching the LED's. It was a good thing since this is how I noticed I left two much space for those dots in the middle, as a result I had stuck the LED strips a little closer.
Step 5: Solder LED Strips
Now starts a long soldering session.
Solder the LED strips in order to form a continues strip.
Notice the order in which to solder the strips in the picture.
For the middle dots I used a single LED strip and covered the middle LED with duct tape.
I used the following color code
  • Blue for ground
  • Green for data
  • Red for Vcc (12v)
Step 6: Wire Arduino on Breadbord
I tried doing a sketch in fritzing but I can't find all the parts :( , Sorry
So here is a list with all the connections and another picture with the setup on a breadboard
Step 7: Test LED's
Before loading this sketch (for which I assume no credit) don't forget to add FastLED library.
If everything went OK the LED's should cycle trough colors. If you have any problems first check your soldered points.
Step 8: Program the Clock
After struggling a little I managed to get a working clock that covers all my needs. I'm sure there is room for improvement.
The code is very commented, if you have any questions please feel free to ask. Also if you have any suggestions, please do tell.
All debugging messages are commented as well.
In order to change the color used you must modify the variable at line 22 ( int ledColor = 0x0000FF; // Color used (in hex)). You can find a list of colors at the bottom of this page: https://github.com/FastLED/FastLED/wiki/Pixel-refe...
If you have problems downloading the code file from instructables here is a mirror : http://bit.ly/1Qjtgg0
Step 9: Make Digits Form Using Polystyrene
Cut each segment in the template printed at the beginning.
Form each digit in the polystyrene using a exacto knife (very hard) or a Hot Wire Cutter.
You can see how I made mine in the pictures.
If you don't have a guitar string you can use just about any thin STEEL wire.
In order to power the Hot Wire Cutter I used the 12v LED power supply.
Also there is a picture with a cut digit. (sorry I forgot to take pictures in the process).
Step 10: Glue Digits and Adding Diffuser
After cutting all 4 digits and the dots glue all of them on the cardboard with the LED strips. (for this process I used
double sided adhesive tape).
In order to diffuse the LED light I used 2 paper sheets on top of the polystyrene. For convenience and aesthetics I used a single A2 size paper folded in two.
Also for finishing touches I've put the entire assembly in a large picture frame.
Time Contest
Second Prize in the
Time Contest
20 People Made This Project!
  • CNC Contest
    CNC Contest
  • Make it Move
    Make it Move
  • Teacher Contest
    Teacher Contest
220 Discussions
Martin T
Tip 12 days ago
Finished
TomaszK52
10 months ago
Hello, I'm just learning. please check the code and ask for help in displaying the temperature in the right color. Apologizes for the Google translator.
#include <DS3232RTC.h>
#include <Time.h>
#include <DHT.h>
#include <Wire.h>
#include "FastLED.h"
#define NUM_LEDS 58// Number of LED controles (remember I have 3 leds / controler
#define COLOR_ORDER BRG // Define color order for your strip
#define DATA_PIN 6 // Data pin for led comunication
#define DHTPIN 7
//#define DHTTYPE DHT11
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
CRGB leds[NUM_LEDS]; // Define LEDs strip
byte digits[12][14] = {{0,0,1,1,1,1,1,1,1,1,1,1,1,1}, // Digit 0
{0,0,1,1,0,0,0,0,0,0,0,0,1,1}, // Digit 1
{1,1,1,1,1,1,0,0,1,1,1,1,0,0}, // Digit 2
{1,1,1,1,1,1,0,0,0,0,1,1,1,1}, // Digit 3
{1,1,1,1,0,0,1,1,0,0,0,0,1,1}, // Digit 4
{1,1,0,0,1,1,1,1,0,0,1,1,1,1}, // Digit 5
{1,1,0,0,1,1,1,1,1,1,1,1,1,1}, // Digit 6
{0,0,1,1,1,1,0,0,0,0,0,0,1,1}, // Digit 7
{1,1,1,1,1,1,1,1,1,1,1,1,1,1}, // Digit 8
{1,1,1,1,1,1,1,1,0,0,1,1,1,1},
{1,1,1,1,1,1,1,1,0,0,0,0,0,0},
{0,0,0,0,1,1,1,1,1,1,1,1,0,0}
}; // Digit 9 | 2D Array for numbers on 7 segment
// {11111111000000}, // Digit *0
// {00001111111100}}
bool TempShow = true;
bool Dot = true; //Dot state
bool DST = true; //DST state
//int ledColor = 0x0000FF; // Color used (in hex)
int last_digit = 1;
long ledColor = CRGB::DarkOrchid; // Color used (in hex)
//long ledColor = CRGB::MediumVioletRed;
//Random colors i picked up
long ColorTable[16] = {
CRGB::Amethyst,
CRGB::Aqua,
CRGB::Blue,
CRGB::Chartreuse,
CRGB::DarkGreen,
CRGB::DarkMagenta,
CRGB::DarkOrange,
CRGB::DeepPink,
CRGB::Fuchsia,
CRGB::Gold,
CRGB::GreenYellow,
CRGB::LightCoral,
CRGB::Tomato,
CRGB::Salmon,
CRGB::Red,
CRGB::Orchid
void setup(){
Serial.begin(9600);
Wire.begin();
dht.begin();
LEDS.addLeds<WS2811, DATA_PIN, COLOR_ORDER>(leds, NUM_LEDS); // Set LED strip type
LEDS.setBrightness(255); // Set initial brightness
pinMode(2, INPUT_PULLUP); // Define DST adjust button pin
pinMode(4, INPUT_PULLUP); // Define Minutes adjust button pin
pinMode(5, INPUT_PULLUP); // Define Hours adjust button pin
// Get time in a single number, if hours will be a single digit then time will be displayed 155 instead of 0155
int GetTime(){
// RTC.setDateTime(__DATE__, __TIME__);
tmElements_t Now;
RTC.read(Now);
//time_t Now = RTC.Now();// Getting the current Time and storing it into a DateTime object
int hour=Now.Hour;
int minutes=Now.Minute;
int second =Now.Second;
if (second % 2==0) {Dot = false;}
else {Dot = true;};
return (hour*100+minutes);
// Check Light sensor and set brightness accordingly
void BrightnessCheck(){
const byte sensorPin = 11; // light sensor pin
const byte brightnessLow = 30; // Low brightness value
const byte brightnessHigh =30 ; // High brightness value
int sensorValue = digitalRead(sensorPin); // Read sensor
if (sensorValue == 0) {LEDS.setBrightness(brightnessHigh);}
else {LEDS.setBrightness(brightnessLow);}
void TempToArray(){
tmElements_t tm;
RTC.read(tm);
if (tm.Second != 47) {
TempShow =false;
return;
TempShow = true;
int t = dht.readTemperature();
//int celsius = (t / 4.0) * 100;
int celsius =(t);
Serial.print("Temp is: ");
int cursor = 59; // last led number
leds[28]=0x000000;
leds[29]=0x000000;
for(int i=0;i<=13;i++){
int digit = celsius % 10; // get last digit in time
if (i==4){
Serial.print("Digit 4 is : ");
Serial.print(digit);Serial.print(" ");
cursor = 44;
for(int k=0; k<=13;k++){
Serial.print(digits[11][k]);
if (digits[11][k]== 1){leds[cursor]=ledColor;}
else if (digits[11][k]==0){leds[cursor]=0x000000;};
cursor ++;
Serial.println();
else if (i==3){
Serial.print("Digit 3 is : ");Serial.print(digit);Serial.print(" ");
cursor =30;
for(int k=0; k<=13 ;k++){
Serial.print(digits[10][k]);
if (digits[10][k]== 1){leds[cursor]=ledColor;}
else if (digits[10][k]==0){leds[cursor]=0x000000;};
cursor ++;
Serial.println();
else if (i==2){
Serial.print("Digit 2 is : ");Serial.print(digit);Serial.print(" ");
cursor =14;
Serial.print(digits[digit][k]);
if (digits[digit][k]== 1){leds[cursor]=ledColor;}
else if (digits[digit][k]==0){leds[cursor]=0x000000;};
cursor ++;
Serial.println();
else if (i==1){
Serial.print("Digit is : ");Serial.print(digit);Serial.print(" ");
cursor =0;
cursor ++;
Serial.println();
celsius /= 10;
// Convert time to array needet for display
void TimeToArray(){
int Now = GetTime(); // Get time
int cursor =59;
Serial.print("Time is: ");Serial.println(Now);
if (DST){ // if DST is true then add one hour
Now+=100;
Serial.print("DST is ON, time set to : ");Serial.println(Now);
if (Dot){leds[29]=ledColor;
leds[28]=ledColor;
else {leds[29]=0x000000;
leds[28]=0x000000;
for(int i=1;i<=4;i++){
int digit = Now % 10; // get last digit in time
if (i==1){
Serial.print("Digit 4 is : ");Serial.print(digit);Serial.print(" ");
cursor =44;
for(int k=0 ; k<=13 ;k++){
cursor ++;
Serial.println(); Serial.println();
else if (i==2){
cursor =30;
cursor ++;
Serial.println();
else if (i==3){
cursor =14;
cursor ++;
Serial.println();
if (digit != last_digit)
cylon();
ledColor = ColorTable[random(16)];
last_digit = digit;
else if (i==4){
Serial.print("Digit1 is : ");Serial.print(digit);Serial.print(" ");
cursor =0;
cursor ++;
Serial.println();
Now /= 10;
void DSTcheck(){
int buttonDST = digitalRead(2);
// Serial.print("DST is: ");Serial.println(DST);
if (buttonDST == LOW){
if (DST){
DST=false;
// Serial.print("Switching DST to: ");Serial.println(DST);
else if (!DST){
DST=true;
delay(500);
void TimeAdjust(){
int buttonH = digitalRead(5);
int buttonM = digitalRead(4);
if (buttonH == LOW || buttonM == LOW){
delay(100);
tmElements_t Now;
RTC.read(Now);
int hour=Now.Hour;
if (buttonH == LOW){
if (Now.Hour== 23){Now.Hour=0;}
else {Now.Hour += 1;};
}else {
if (Now.Minute== 59){Now.Minute=0;}
else {Now.Minute += 1;};
RTC.write(Now); }}
void fadeall() { for(int i = 0; i < NUM_LEDS; i++) { leds[i].nscale8(250); }}
void cylon () {
static uint8_t hue = 0;
Serial.print("x");
// First slide the led in one direction
// Set the i'th led to red
leds[i] = CHSV(hue++, 255, 255);
// Show the leds
FastLED.show();
// now that we've shown the leds, reset the i'th led to black
// leds[i] = CRGB::Black;
fadeall();
// Wait a little bit before we loop around and do it again
delay(15);
Serial.print("x");
// Now go in the other direction.
for(int i = (NUM_LEDS)-1; i >= 0; i--) {
// Show the leds
FastLED.show();
fadeall();
delay(15);
void loop() // Main loop
Serial.print("Temperatura: ");
Serial.print(t);
BrightnessCheck(); // Check brightness
DSTcheck(); // Check DST
TimeAdjust(); // Check to se if time is geting modified
TimeToArray(); // Get leds array with required configuration
TempToArray();
FastLED.show(); // Display leds array
if (TempShow == true) delay (7000);
JogeirLTomaszK52
Reply 8 months ago
There are several things I do not understand in this instuctabels, as I am a newbee.
And I do like to build this clock (as a magic mirror), fix/glue the LED's to a black
painted plywood sheet and a 1way mirror in the front.
1st. where can I get this one, and how to hook it up
2nd.
Step 6: Wire Arduino on Breadboard
Light Sensor: will that be a LDR?
Buck COnverter: I do not know what that is, is that a IC f some kind
and how to conect it.
3rd.
LED strip
On mine I have: +12, R, G, B
How to connect this to the UNO board
4th.
Button 1: (DST): Daylight Saving Time?
I live in the Pilippines so we do not have daylight saving time here.
How can I remove that from the sketch?
Button 2: (H): Hour setting?
Button 3: (M): Minuttes setting?
Later I like to change it to a GPS clock.
And add a BMP180/280, temp an barometric pressure,
That will be something :-)
Clock.ino
Compile fine on Arduino1.8.8
Light LEDS.ino
Do not compile.
Here is the problem, in
void setup()
LEDS.addLeds(leds,NUM_LEDS);
arduino sketch from:
TomaszK52
Evan31
Cameltoe
jeffreye
Cameltoe (This is the modification I've done so far with no luck.)
They all compile without problem. So which sketch will I star with?
I do hope any of you Arduino gurus out there can help me to shine
some light on this problems.
But I do have a Mega bord laying around, maybe that is a good
idea to use that one? Yes? :-)
RaimisS
1 year ago
Hi everyone,
I have replicated this project with some additions. Here you will find my code: https://github.com/Barcors/WS2812B_TemperatureCloc...
I have added Dallas sensor for measuring outside temperatures. Positive temperature are working good but I am not success with negative temperatures. Might be someone can help me with this. I do not know how to light up minus and corectly diplay negative temperatures. Thanks
Velikov71RaimisS
Reply 6 months ago
Hello!
I implemented the project with three pixels per segment. I use your code. Would you help me how to change the code so it works with 87 pixels (21x4) +3.
Thank you in advance!!!
RaimisSVelikov71
Reply 4 months ago
I am pretty sure that you have booth: hardware and code problems. You replicating the initiate project not mine. You mixed things up. Which type of strip you are using? WS2811 and WS2812 are bit different so pay attention on digits constructing. Your code is tried to adjust for WS2811 and mine is for WS2812. You are not using minus temperature so my code is not for your project. Try use initiate code.
You can not connect two things to one input. Arduino pins are different 3 and D3 - read manual and check that again.
maeseunoRaimisS
Reply 4 months ago
Hi, thanks for your answer, I am using WS2812 and I corrected the connection, light sensor connected to the A3 temperature sensor to the D3, I really would like to use your code since it is for WS2812, I have searched and modified other codes but without positive results, I have reading eh tried to solve this for a week or more, I mean I'm not a lazy guy, I'm just stuck and it's my second arduino project, I hope you can help me please, or any suggestions, apart from formally studying arduino code, which will in the future ;)
RaimisSmaeseuno
Reply 4 months ago
OK no problem then correct digits. As you using WS2812 strip and it have three led's controlled by one microcontroller so you must use my code example. Pay attention to digit construction. For example digit 0
WS2811 : {0,1,1,1,1,1,1}
WS2812 : {0,0,0,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1}
So try it again and you and your child will be very happy. Also if you are not using this clock for outside temperature you must disable three led's in front of the strip. Remember that those led's on such a strip WS**** are activated one after one in a sequence. So you must construct or imagine in your head or draw it on a paper each segment of the digit to find out which led is for which segment. Look carefully to example i gave and i am sure you understand. And formula will be not 7x4+2 but 21x4+3. I think it is possible to use your formula but then it needs to think and count...
RaimisSRaimisS
Reply 4 months ago
Really it should be ok and might be you need disable three led's in front.
RaimisSRaimisS
Reply 4 months ago
I am glad you have made it.
maeseunoRaimisS
Reply 4 months ago
Thank you very much for your advice and the time you dedicated me, finally I get it to work correctly (thanks to you) we are very happy my childrens and myself !!!
RaimisSVelikov71
Reply 6 months ago
Which one strip you have used? As i remember correctly you must correctly define digitising of digits.
For example digit 0
Try it again.
Velikov71RaimisS
Reply 6 months ago
Thank you for your answer, sir !!! I will try again !!!
RaimisSRaimisS
Reply 1 year ago
Already made working code. You can use it from github.
СергейР28RaimisS
Reply 1 year ago
RaimisS tell me please, how are the LEDs in this project arranged for your sketch?
RaimisSСергейР28
Reply 1 year ago
I am not quite sure that I understood what you mean by that - leds are not anyhow arranged - they are on the strip and goes one after another.
СергейР28RaimisS
Reply 1 year ago
I thank . I already collected the project. I meant connecting to Arduino, but everything is clear. Thanks for the sketch.
