Bring Your Own Moon
3,707
75
11
Introduction: Bring Your Own Moon
About: Make it yourself if you cannot buy one!
We will not get lost in the night when the Moon light go along with you. But how about the day before new Moon? Why don't you bring your own Moon alone with you?
This instructables show how to make a 2.5 inches rechargeable Moon key ring go alone with you.
Step 1: Preparation
Battery
Any tiny Lipo with around 250-500 mAh is ok, this time I am using a 102025 Lipo battery.
Charge Board
Any Lipo charge board with micro USB socket should be ok.
LED
A 0.5 - 1W LED with voltage regulator.
Switch
A 8 mm X 8 mm X 8 mm power switch.
Key Ring
A key ring set with a ring that can screw into the switch hat.
Step 2: 3D Printing
Download the 3D model at Thingiverse and print it out:
https://www.thingiverse.com/thing:3009415
Step 3: Soldering Work
The connection is very simple, here is the connection summary:
Lipo +ve -> Charge Board Battery +ve pin
         -> Power Switch -> LED +ve pin
Lipo -ve -> Charge Board Battery -ve pin
         -> LED -ve pin
Step 4: Hot Glue Assembly
Use hot glue fix the components to the key ring hat and then stick the hat with the Moon body together.
Step 5: Key Ring Assembly
Screw the ring to the switch hat and then chain the key ring together.
Step 6: Charge the Battery
Plug the USB power to the Moon key ring and wait for fully charged.
Step 7: Bring Your Own Moon!
Its time to bring your own Moon alone with you!
Step 8: If You Do Not Have a 3D Printer
There are various website selling Moon Lamp product on the web, some are selling key ring size product:
https://www.lunarlamps.com/products/3d-printed-moo...
P.S. I will post a real product here if I get one.
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    11 Discussions
    Jwsmiles
    Jwsmiles
    Question 1 year ago
    Great project!
    Just wanted to know where I could buy the led and board from? I can’t seem to find one with the voltage Reg. Thanks
    陳亮
    陳亮
    Reply 1 year ago
    If you cannot find that board, you may try to add a ~1x ~ 2xx Ohm resistor in series.
    Jwsmiles
    Jwsmiles
    Reply 1 year ago
    Sorry I’m very new to all of this.
    What ohm resister is “2xx” and “1x” and where abouts in the circuit should I wire them in series. Is it between the positive battery wire and the LED?
    陳亮
    陳亮
    Reply 1 year ago
    "x" only means a wild card. If you have some resistors between around 10 - 300 Ohm, you can try one by one which brightness can fit you.
    Jwsmiles
    Jwsmiles
    Reply 1 year ago
    "Sorry I’m very new to all of this.
    What ohm resister is “2xx” and “1x” and where abouts in the circuit should I wire them in series. Is it between the positive battery wire and the LED?"
    sorry can you help with the question above
    陳亮
    陳亮
    Reply 1 year ago
    I bought it at Taobao.
    MicahKV
    MicahKV
    2 years ago
    Awesome, I imagine this could work with a light sensor to use as a fixed outdoor light too. Very cool!
    Salgalpal
    Salgalpal
    2 years ago on Step 7
    This would have been wonderful to have the last time I lost my keys outside at night. It took it several people I know a lot of time to find them in the grass. But not if I had had this little guy. A very clever idea
    kd7eir
    kd7eir
    2 years ago
    The link to the file on Thingiverse is bad - it's just points right back to the instructable.
    陳亮
    陳亮
    Reply 2 years ago
    Hi kd7eir, thanks for tell me that, I have updated the correct link.
    paleseu
    paleseu
    2 years ago
    Awesome!
