Introduction: Build a Three Hole Washers Score Keeper
This is a great way to store the washers and keep score for the washer game I made an instructable on earlier. It can be found here
www.instructables.com/id/Build-A-Three-Hole-Washers-Board-Game/
Enjoy and as always, please rat/ vote as you see fit. Thank you!
Step 1: The Stuff
MATERIALS
TOOLS
- 1/4" hard wood
- scrap leather
- golf tee (2)
- button and snap set
- leather strips
- wood finish
- wood glue
- small screws
- contact cement
TOOLS
- table saw
- band saw
- belt sander
- drill press
- wood burner
- scissors
Step 2: Step One
- cut out a 10" length of hard wood
- cut 1/4"x8" strips of hard wood for the sides
- cut a bottom part as well
- trim golf tees
- measure and number the board
- with a drill press, drill holes next to the numbers.
Step 3: Step Two
This part is a blast! that is, If you enjoy hand cramps
- Trace out the numbers with your wood burning kit
- take your time, if you mess up you can not erase it!
Step 4: Step Three
- Glue and clamp your side and bottom to the board
- use washers inside to make sure it is spaced right
- after the glue dries, sand smooth on a belt sander
- stain and finish the wood
- If you wish to add colors to the different teams side do that now and paint the pegs (golf tees)
- drill pilot holes to screw the leather in
Step 5: Step Four
- cut leather to size
- punch hole where the button will sit
- attach button
- apply contact cement to the wood edges and leather
- after it is tacky carefully join the wood and leather
- put the small screws in the holes you drilled on the sides and bottom
- pull threw the leather strip in the top to secure the top flap and act as a carrying handle
