C4 Remote Prop
Introduction: C4 Remote Prop
About: Hi i am student and i love creating and designing stuff .and most of my ideas for prop creations comes from my childhood that there were not many stuff or new stuff to play with so today as i have grow up i ...
Hi guys n gals .
today i was thinking about a remote for the c4 that i made and how should it look so i came up with this thing you are looking at . it looks more cartoonic hope you enjoy it .
The items n materials you need. (you can find most of it in your home)
1-cardboard sheet
2-cutter
3-foam board (1mm) & (3mm)
4-straw (7cm)
5-A4 sheet
6-foam glue
7-paint (black / grey or silver / yellow / red white)
note:please see the pictures with the texts to understand better
lets get started.
Step 1: Making the Body
for this section you need to make the general body of the remote .
  • size
    main surface : 7 x 4 (cm)
    Length : 1.5 x 7 (Cm)
    Width : 4 x 1 (cm)
    after you cut out the peaces on card board you should glue them together
    Note : Look at the pictures for a better reference on how to make it thinner .
    sorry i forget to take a picture from the raw box i created it looks like one of the c4 blocks but smaller .
Step 2: Attaching the Straw
you should make a hole in your top left part of your width and put your straw into the box about 3mm.
after that make a 1.5 x 1 (cm) card board and make the same hole with the same diameter and push it from the top of the straw and attach it to the top width glue .
NOTE : YOU SHOULD FILL THE STRAW WITH PAPPER OR SHOPPING RECEIPTS TO MAKE IT HARD INSIDE.
Step 3: Making the Details
  • you should cute 3 rectangle foams (3mm) with the sizes of
  1. 2 x 1 (cm) (small one)
  2. 2.5 x 1 (cm) (medium one)
  3. 3 x 1 (cm) (large one)
  4. glue them like picture above
  • after that you should make a screen ( i really don't know why i made it :| ! just for fun :D )
  1. cut out a 1.5 x 4 (cm) of your 1mm foam
  2. and cut out a a4 paper with the same scale
  3. glue them together and attach the to the middle top part of your main surface .
  • and for the red button
  1. cut out 1 x 3 (cm) cardboard
  2. glue it to the right top side of your lenght part like picture above
  • Start painting like the picture above and have fun
    i used poster colors .
Step 4: And You Are Done Have Fun
♦♦♦congratulations you have finished your c4 remote prop♦♦♦
sorry for bad English and bad explaining i tried my best to explain the process . if you have any ideas or question comment them down below . thanks for your time ♥ hope to teach you the thing you wanted .
P.N : i don't take any responsibilities for any miss use or problems
Step 5: P.S
  1. the firsts picture is the plan i designed for making this thing its a little vague but you can sort things out -_^
  2. and the second picture is a future reference that i might create a bag or something like that to put the c4 and the remote in it (Half-life 1 c4 charge)
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
