Introduction: DIY CUTTING HEAD FOR DRILLING MACHINE
Today I will give you a simple tip to convert your darling machine in to a cutting machine.
This is a DIY solution.try only with necessary safety equipments.
Step 1: Parts You Need
For this DIY you will need
(i am using Indian standards)
1) 13mm nut & bolt (M8 size)
2) Two metal washers (M10 size , 20mm dia)
3) A cutting discs 105x1x16mm
4) Two 13mm spanner
Step 2:
sandwich the cutting disk with two metal washers
Step 3:
Take the bolt and pass it through the metal washers and cutting disk
Step 4:
Take the nut and tight it up
Step 5:
Alien the metal washers,cutting disk, bolt and nut in same axis
Step 6:
Tight the nut with spanners or wrench
Step 7: Moment of Truth
Your own DIY cutting tool is ready for action.fix it on the darling machine and start cutting
