Cardboard Bluetooth Speaker
4,158
24
13
Introduction: Cardboard Bluetooth Speaker
About: There is no greater harm than that of time wasted - Michelangelo Buonarroti
In this instructable I will try to show you how to make a simple but very cool cardboard bluetooth speaker.
My first instructable was the inspiration for this project.
https://youtu.be/F-B0r1T3isM
Very easy project, only few tools needed. I used a lot of recycled pieces to build it.
The sound is amazing for a cheap cardboard speaker!
Step 1: Materials
Thick Cardboard Sheets
2x 15w 8ohm speakers
12v 18650 li-ion battery pack
HX-3S-FL25A 3 SBMS with balancing function
2x10w PAM8610 Amplifier
On/Off switch
Bluetooth module
5v DC-DC Buck converter
Power Jack socket, 2.1mm Connection
Step 2: Speaker Box
Use a precision cutter to cut the carboard :
2 pieces 17cmx17cm (side panels)
2 pieces 17cmx26cm (top and bottom)
4 pieces 17cmx24,5cm (front and back -double)
6 pieces 2cmx22cm (speaker box handle)
Cut round holes for the speakers in both the front panels
Use a hot glue gun to join the cardboard sheets. Use it also for the speakers.
Make it airtight.
Step 3: Electronics
I made a 12v battery pack with li-ion 18650 cels - 3S2P
I added the hx-3s-fl25a-a BMS module because it has over discharge voltage protection and balancing function.
The PAM 8610 amp works with 12v. For the 5v bluetooth module I used a DC-DC 5v buck converter.
Step 4: Finishing
Use the hot glue gun to attach the 12v charging connector and all other electronics, amplifier, battery pack, bluetooth module.
Make two holes on top of the speaker box and attach the handle.
Use paint to make the front panel black.
Use glue to attach a piece of black cloth on the front panel.
I also used a piece of self adhesive bass insulation cotton on the double-back panel and a 10cm long 1inch bass reflex tube on the front. I don't know how this helped but the speaker sound is great :)
Done :).
I hope you will try to make one and write a comment about it
Sorry for my bad english!
Remix Contest
Remix Contest
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    13 Discussions
    xaenon
    xaenon
    1 year ago on Step 4
    You shouldn't apologize for your English. It is better than a lot of people I know who speak it natively.
    I am honestly enthusiastic about this project. I know a lot of people will complain about it being cardboard, but it is far easier (and less expensive!) to prototype something in cardboard and work out the details than it is in other materials. Once you get the details down, you can move on to making the final project out of a more durable material. But there's nothing wrong with leaving it in a cardboard enclosure, either. More easily recycled that way.
    Clifflew2002
    Clifflew2002
    1 year ago
    Great project! I think the only thing I would possibly change is the cardboard. If I make it, I think I’d build the box out of 3/8” plywood.
    markgrogan
    markgrogan
    1 year ago on Introduction
    This looks like a toy speaker or a recycling project children would bring to school. I am truly amazed that it actually works. I guess it isn't at all about the outlook but it is about making sure your main objective is eventually achieved. The physical aspect of projects shouldn't be made as the main focus in order to achieve great success.
    ImpactDIY
    ImpactDIY
    Reply 1 year ago
    Hello! This speaker can produce great sound. It was a huge surprise for me. I made it for my son but now I used more than any other speaker, and I have a few :). The sound is close to the 80's speakers. And it plays 48hours on one charge at moderate volume :).
    AnandM54
    AnandM54
    1 year ago
    Looking nice one and very cool project !!
    ImpactDIY
    ImpactDIY
    Reply 1 year ago
    Thank you!
    UdyRegan
    UdyRegan
    If people only knew just how easy it is to create really useful things in your home, I think we would all save a lot of money…. That's what instructables are for isn't it? This is a really great build - thanks for sharing!
    ImpactDIY
    ImpactDIY
    Reply 1 year ago
    Thank you ! I hope this instructable will help someone. :)
    1234567guy
    1234567guy
    Question 1 year ago on Step 4
    Can you explain more in detail on how to wire the speakers?
    ImpactDIY
    ImpactDIY
    Answer 1 year ago
    Hello, I will make a new schematic and post it here. I hope it will help you!
    1234567guy
    1234567guy
    Reply 1 year ago
    I'm looking forward!
    fitpamsy63
    fitpamsy63
    I would like to make it...what would the supplies cost?
    ImpactDIY
    ImpactDIY
    Reply 1 year ago
    Hello, the speakers and 18650 cells were recovered.
    Cardboard Sheets - 0$
    2x 15w 8ohm speakers - recovered -0$ (15-20$ new)
    12v 18650 li-ion cells - recovered- 0$ (about 5$/piece new)
    HX-3S-FL25A 3 SBMS with balancing function - 7$
    2x10w PAM8610 Amplifier - 5$
    On/Off switch - 0,5$
    Bluetooth module -3$
    5v DC-DC Buck converter - 3$
    Power Jack socket, 2.1mm Connection - 0,5$
