Cardboard Gramaphone Passive Speaker
11,435
157
29
1 Teacher Note
I’ve always loved the aesthetic of old gramophones and finally sat down and made one. It will boost the volume of your music only a little bit, but it sure looks cool!
Supplies:
Cardboard
Box cutters
Scissors
Tape
Glue gun and glue
Cutting mat
Print out of all SVG pattern pages
(Fuzzy assistant not necessary, but always nice)
1 Teacher Note
Step 1: Cut Out All Cardboard Pieces
Cut out all of the pieces of the SVG pattern. Add 2-3 inches to the 4 stem bits of the bell(the ones with the square ends). Add more if you want it to be taller than mine ended up being.
Lay out all the pieces of the template and cut out of cardboard. Make sure that all the pieces of both the octagonal bowl and bell are drawn on the grain of the cardboard so that they bend the way you want. The corrugated stripes are 90 degrees from the direction you want the pieces to bend. (See pictures)
Step 2: Pre-bend and Compress Cardboard Pieces
On all the pieces for the bowl and the bell bevel the edges by compressing the side-saddle with a hard object. I used the handle for my scissors. This will make it easier to put the sides together.
Also pre-bend the curved pieces. You don’t want to have to do this while you’re taping them together. It won’t end well.
Step 3: Make Bowl and Octagonal Base
Take the first 2 sides of the bowl and tape together starting at the longest side and working down. Repeat for all the other sides the same way. You will end up with a spiral of cardboard and will have to unwind it to tape the last side. Alternate taping the last side with taping the bottom of the bowl so that all the sides line up.
Once taped glue the inside of the bowl with a glue gun to strengthen it.
The tape the bottom and sides of the base together. Glue all inside seems. Do not attach the top yet. (my camera eat these pics sorry)
Step 4: Score, Fold, and Glue Phone Platform to Top
Score all the fold lines with the tip of the scissors and then fold to match photos. Glue the back flaps down and then push up through the opening in the top until the flaps line up with the underside of the top. Glue down all five of the flaps on on three of the sides. (The flap on the bottom doesn’t get glued down. It just rests against the bowl once everything is glued up)
Step 5: Put Together the Bell
Start with the center bottom piece and tape starting at the very edge of the bell working down to the base. Match up the edges the whole way down. The cardboard may fight you on this but it is possible to do. This is why you pre-bent thing earlier.
Then tape the bottom piece to the other side. Do this for the side pieces as well to end up with 5 pieces taped together. Once that’s done brace open the sides and glue along all the inside seams. Now tape the top center piece to the 2 upper side pieces and then press open and glue.
Now tape the 3 piece group and5 piece group and tape together along seems. This is the hardest part and it would be helpful to have an extra set of hands (or be an octopus)
Glue the last 2 seems in the bell and far down as your glue gun will let you and you’re done! Just square off the bottom so everything is even.
Step 6: Putting It All Together
Slide the bowl into the base. It will be a close fit. Tape the bell to the square opening in the top and glue down. Then place top with bell onto the base and glue along all 8 sides.
And now enjoy your new cardboard gramophone!
The pattern is sized to fit an iPhone 6 Plus. The phone in the picture is and old iPhone 3.
Cardboard Speed Challenge
First Prize in the
Be the First to Share
    • Fashion Contest
      Fashion Contest
    • Reuse Contest
      Reuse Contest
    • Hot Glue Speed Challenge
    29 Discussions
    nsekkins
    22 days ago on Step 6
    I wanted to use this with my students, but .SVG can be tough to work with and the template sizes are kind of hard to print. I cropped them to 8 and 1/2 by 11 sized and changed them to .PDF format. This may impact how a phone fits? Thanks for the project, we are very excited to build it! (Just fixed the issue with file #6.)
    Nodelnsekkins
    Reply 22 days ago
    Wow that’s amazing! Yeah I know the template wasn’t all that great thanks for fixing it up! For it to be big enough to fit my behemoth of a phone it cut off a lot of edges when it printed.
    nsekkinsNodel
    Reply 21 days ago
    You're welcome, thanks for sharing the project!
    Megaetnsekkins
    Reply 22 days ago
    All pdf files work, with the exception of "2B6sm". The file seems to be corrupt. Great work.
    nsekkinsMegaet
    Reply 21 days ago
    It should be fixed now. Thanks for letting me know.
    OwenH35
    11 days ago
    It's really good. It needs a little skill and patience
    attosa
    17 days ago
    Congrats on your win! This is so cool!
    Nodelattosa
    Reply 17 days ago
    Thanks so much! I can’t believe how much everyone seems to like my project. I’m blown away!
    ltc1
    23 days ago
    Hermoso,darle un acabado al cartón al gusto de uno,ya sea caoba o nogal .Beautifull.
    Nodelltc1
    Reply 22 days ago
    ¡Gracias!
    AndrewA167
    23 days ago
    This looks really nice; thanks for sharing it! Some ideas for others:
    1. Stain the bell and the base using wood stain or other color stains - or use spray paint (copper and brass)...
    2. Instead of the cardboard base, use a wood cigar box - which leads to:
    3. Add a small speaker (maybe a speaker from a pair of headphones?) to the small end of the bell. Connect it to a small amplifier (look for a monophonic bluetooth amplifier on Amazon, Ebay, or Aliexpress). If you can't get a mono amp, go stereo, and make two bells instead!
    4. You could make an entire fake grammaphone with a motor to "spin" the "record"...
    5. Add an old vacuum tube which has an intact heater, and make it glow?
    6. Go the steampunk route and add a bunch of gears?
    I honestly wish this instructable had come out earlier, or I had thought of it - I'm in the process of building a "vintage" bluetooth speaker - but I'm basing mine off an old 1930s wooden cabinet 8" PA speaker (like a school would have used), and I've already bought everything for it.
    Of course - maybe a second speaker wouldn't be a bad thing...
    NodelAndrewA167
    Reply 23 days ago
    I love all of your ideas!
    I was actually thinking about remaking it in either balsa wood or chipboard or something a bit sturdier than cardboard and the headphone speaker at the base of the bell would actually mean that the phone could be attached differently to the base and still work.
    Please tell me you’ll make an instructable for the PA speaker though, that sounds really cool.
    jeanniel1
    24 days ago
    Wow, so fun! A retro idea for a now-tro device! I'm going to make this!
    Nodeljeanniel1
    Reply 23 days ago
    I love the aesthetic of things from this era. But I don’t have the space or money for antiques that just look cool. This way I have something that looks cool but is still useful!
    jeanniel1Nodel
    Reply 23 days ago
    That's also the beauty of cardboard - sustainable - recyclable when finished.
    sitearm
    23 days ago on Step 6
    Step 7. Now use phone to take picture of phone on base...erm... 🤣 Ty for posting! 😁
