Introduction: Cardboard Square Basket
Learn how to weave your own square basket - all out of cardboard!
Easy to make in only ten minutes or less!
It may look like this basket has a lot of steps but they are only for clarity.
Step 1: Gathering Materials
What You'll Need
5 x 14 inch piece of thin cardboard
Paper cutter
Ruler
Pencil
Tape
A clean surface
Step 2: Marking Each Quarter-Inch
With your pencil, mark each quarter-inch on both of the 5-inch long sides of the piece of cardboard.
Step 3: Cutting the Strips
Cut out twenty long strips from the 5 x 11 piece of cardboard, using the quarter-inch pencil markings as a guide.
Step 4: Taping Down the Strips
Take five of the strips and place them parallel to each other. The length from the first strip to the fifth strip should be three inches. Place tape on both ends of the strips.
Step 5: Placing a Dot
Find the middle of the third strip and place a dot there. The middle should be seven inches down the strip.
Step 6: Weaving the Base
Take another five strips and weave them through the first five strips as shown in the picture below.
Step 7: Folding the Strips
Remove the tape from both ends of the first five strips and fold up the strips on all four sides. These strips will now be called ribs.
Step 8: Weaving the First Layer
Take one strip and place one end behind a rib. Weave it over and under the ribs, going around the base of the basket. It helps to tape the beginning of the first strip to a rib. Once you get to the end of the first layer, stick it under one of the ribs. The first layer is always the hardest so don't give up.
Step 9: Weaving the Second Layer and More
Start the next layer on a side other than the one you started on. If you used tape to secure your first layer, then remove it now. Continue weaving the rest of the strips.
Step 10: Folding and Cutting the Ribs
Once you finish weaving all of the strips, cut the ribs so that an inch is left at the top of each one. Fold the ribs that go over the last layer and tuck them under the third to last layer. Cut the ribs that go under the last layer. Now you're done!
Step 11: Whoa!
The basket you've made is strong enough to support over ten pounds of weight!
Gorilla Glue Cardboard Contest
