Introduction: Cat Tree by Frosta X
I have cats from February 2014. In the year I have been adopt three stray cats.
Inspired by Frosta X : http://www.ikeahackers.net/2012/06/frosta-x.html
stuff : 5 Frostas
tool:Drill, 3M double-sided tape, silicone, screws (for wood), wood glue,paper tape,
can help you sawing wood friends
Step 1: Arrange the Patterns
Arrange the most beautiful patterns on the floor. It is easier to arrange springboards. You can always modify until satisfied.
Note to comply with the size of the wall.
I measured the size of the walls. Then use tiles forecast the range of cat tree.
Step 2: Stick Together
Sticking together one day use Wood glue and clamp.
The next day using an electric drill and screws to make work more solid.
Work is divided into several parts in combination.
Step 3: Paper Tape on the Wall
Because the work is heavy, then you want to use silicon to stick to the wall.
Draw the cat tree with a pencil and then put the paper tape outline in the wall.
If silicon extruded out of range, release the paper tape can have a pretty face.
Step 4: Just Double-sided Tape and Silicone
I just used double-sided tape and silicone fixed to the wall.
The next day it does not fall off.
