Introduction: Cheap and Easy Toner Transfer for PCB Making
There are lots of people mentioned about using Inkjet Glossy Paper to do Toner Transfer. It can be done. But it is not easy to remove it after ironing. You have soak the PCB in hot water for more than ten minutes. It is quite time consuming. If you cannot remove the coating completely. It cannot be etched.
I have tried to use Konica Minolta Photo Quailty Matte Paper. Then design your own circuit and print it on the Matte Paper. Remember, before printing it. You need to mirror board. Otherwise, the circuit will be inversed.
Step 1: Start to Iron It.
Face the Toner Side of Matte Paper towards to the Copper Side. Turn On your Iron. Unlike the Glossy Paper, you have to turn to maximum temperature. You don't need it this time. I turn the iron to medium temperature (becoz the paper is not very thick.. Heat is easy to Transfer to Copper and Toner). Firstly, Iron the side of PCB. After 30 seconds, you will find the Matte Paper will stick to Copper firmly. It means it is successful. Then Iron the whole PCB. Depends on the Size of PCB, I use around 2minutes for this Copper Board (Around 3cm x 4cm).
If some area cannot stick, it means your copper board is not clean enough. Remove the Paper and Use Acetone and Sand Paper to Clean it.
Step 2: Soak It With Cold Water
Just Soak It in the Cold Water. Since Matte Paper are much thinner than Glossy Paper. Paper will become soft very quickly. Use your finger to remove the paper gently. Don't Remove it Too Hard. Otherwise, some toner will be removed too.
Please check the every trace. Find out any broke trace. If find, use Acetone to clean it and do it again.
Step 3: Etch It !
Use any kind of etchant to etch your copper board. I use Ferric Chloride. Put Ferric Chloride into Water and wait until it dissolve. Put the Copper Board into it and Wait Until All Uncover Copper Disappear.
Step 4: Clean and Then Finish!
Finally, we need to remove the Toner. Use the Acetone (Nail Polish Remover) to clean it.
This PCB in the Photo are LQFP -80 14mmx14mm. The Trace is around 14mil. It is quite clean and no broken trace is found.
Originally, this method are tried by Karo-sama. He has made a video for demostration.
For more details , you can find it in my wiki.
