Cobweb Candy
2,489
41
5
G'day everyone. I'm a maker of things. Nerdy decor, props, experimental woodwork and more.
It goes by many names; Dragons beard, Chinese cotton candy, silver silk candy or just hand-pulled cotton candy. However, in this spooky month of Halloween and with the addition of some gummy spiders, I present Cobweb Candy.
Supplies:
Ingredients:
  • 2 cups of white sugar
  • 1/4 cup of glucose syrup or light corn syrup
  • 1 teaspoon of white vinegar
  • 1 cup of water
  • 1 cup of corn flour, corn starch or rice flour
  • Gummy spiders
Utensils:
  • A candy thermometer
  • Saucepan
  • Measuring cups and spoons
  • Round plastic containers
Teacher Notes
Step 1: Add Ingredients to a Saucepan
Add 2 cups sugar, 1/4 cup glucose syrup (corn syrup), 1 teaspoon vinegar and 1 cup of water to a saucepan.
Step 2: Heat
Heat the mixture to 260°F (126°C).
Use the candy thermometer to make sure you reach this temperature.
It may take a while however wait until it reaches the required temperature and then remove from heat.
Pro tips:
Don't stir the mixture as stirring may cause sugar crystals to form. You can also brush the inside walls of the saucepan with water to prevent sugar crystals from forming.
Step 3: Let It Cool
After removing the saucepan from the stove at 260°F (126°C) it should continue to rise a bit to about 270°F (132°C). This is okay.
Let it cool to about 212°F (100°C) then transfer into the circular plastic containers.
Let them cool even further for a few hours until they are room temperature.
Step 4: Remove From Mould and Flour
Sprinkle a generous amount of corn flour (corn starch or rice flour) onto a large plate or tray.
When your candy is room temperature it should be firm but still malleable.
Remove the candy from the mould. This may take some time and effort but keep working the edges of the container until the candy pops out.
Coat the candy block with the corn flour. Don't be afraid to get this all over your hands as it will prevent the candy from sticking.
Work the candy block with your fingers until you can push through a small hole in the centre. Your now ready to start the fun part.
Step 5: Stretch Out the Candy
This is where many people make mistakes (i mean happy accidents) and rush causing breaks.
Go slow.
Slowly and carefully stretch out the candy to make a hoop about half an arm's length.
Try to make it even with no thick or thin areas.
Twist the hoop in the middle and fold over making a circle with two layers.
Now repeat. Slowly stretch out your circle again until you think you have enough to twist and fold.
Step 6: Multiply
Stretch, twist, fold. Stretch, twist, fold.
Keep going with that pattern. Work slowly and carefully to make each strand the same thickness.
Watch the magic of exponential growth happen before your eyes. In only about 13 stretch-twist-fold's you will have roughly 16000 thin strands of candy.
Pro tip:
Keep applying more corn flour every stretch-twist-fold. The thinner the strands get, the more they want to stick together, especially in a humid environment.
Step 7: Roll Up Some Spider's Prey
Lay out a small bunch of the candy as seen in picture 1 above.
Carefully roll up a little bundle and cut it off. Repeat.
Traditional dragon's beard candy has a peanut mixture meant to be wrapped up in the middle. In these pictures i did not wrap up anything however keeping with the theme, perhaps some gummy worms or some other gummy bug would work well inside these cobweb candy bundles.
Step 8: Add Gummy Spiders and Serve
Place your cobweb candy bundles on a plate or serving tray and add some gummy spiders on top.
You could even make a larger pile with some spiders (last picture) or stretch the cobweb candy over your Halloween desert or treat table.
When you're done admiring your Cobweb Candy, don't forget that it's actually edible and treat yourself :)
Thanks for reading through my instructable and I hope I have inspired some of you with this idea for next Halloween.
Candy Challenge
First Prize in the
Candy Challenge
Be the First to Share
    • Meal Prep Challenge
      Meal Prep Challenge
    • Reuse Contest
      Reuse Contest
    • Made with Math Contest
    5 Discussions
    jeanniel1
    7 days ago
    I watched mesmerized by the candymaker in China making this candy. It was simply amazing to see so many strands come out of just a few twists and pulls! You did a great job describing how to start the strands - I would have never guessed how it's made otherwise! Nice touch with the jelly spiders - heh heh heh!
    jannie.lloyd
    18 days ago
    On the rare times we spent Hallowe'en at granny's in the 1950's she would make something like this but leave it at the stage as shown in your very first picture - i.e. as strands/cobwebs. She would hang it up across the room and the game was to pass under it trying to get a mouthful of the candy. Not as easy as it sounds, especially when you are only a little 7 year old.
    Thanks for reminding me of great times and for your INSTRUCTABLE. I might have a go at this next year for my grand children.
    attosa
    21 days ago
    So cool! My parents used to bring us similar candy from their trips to Iran. It's called Pashmak over there. I wonder if it tastes the same as yours :) Thanks for sharing!
    Penolopy Bulnick
    21 days ago
    This is so neat! I've always been fascinated by how this candy is made :)
