Introduction: Convert 12V DC to 5V DC
Hii friend,
Today I am going to tell you how to convert upto 24V DC to constant 5V DC.
Let's get started,
Step 1: Take All Components As Shown Below and in Pictures
Components required -
(1.)Voltage regulator - 7805
(2.)Multimeter (Digital/Analog) [Only for Testing purpose]
(3.)Input power supply - 7V.........24V DC
Step 2: Connect Input Power Supply
7805 voltage regulator contain three pins.In which we have to give power supply on pin-1 and pin-2.
we have to connect +ve input power supply to the 1st pin of the voltage regulator and -ve input power supply to the 2nd pin of the voltage regulator as shown in the picture.
Step 3: Output Power Supply
Now we have to connect output power supply wires.The output power supply will give always constant 5V DC power supply.
we have to connect the +ve wire of output power supply to the 3rd pin of the voltage regulator and -ve power supply to the 2nd pin of the voltage regulator.
Step 4: Wiring Is Completed
Now the wiring of voltage regulator is fully completed and the next step is we have to check the circuit.
we have to give input power supply about 7V..........24V DC and we will get constant output power supply 5V DC.
Let's check,
Step 5: Checking
In this circuit I give 12V DC input power supply and as you can see in the display digital multi meter the output power supply is almost near about 5V DC.
This type we can convert upto 24V input DC to constant 5V output DC.
Thanks
