Cool Lighting for Fre (LED Modules)
1,243
8
6
Introduction: Cool Lighting for Fre (LED Modules)
About: I like to build some cool stuf
in this instructable i made little LED lights for some nice lightening effects
i used recycled batteries because it was free but you can use whatever battery you want :)
Teacher Notes
Step 1:
It all started when I went around the container for used batteries and I was wondering how many of them are actually useful
so ask my teacher if I could test them with some school meters in his lab and he agreed
Step 2: First Measuring
inside was a lot of rubbish and used lightbulbs,
I was impressed some batteries was even new :)
exactly half of them was able to output 100mA and hold their voltage between 1.5-1.1V
(current 100mA was given by variable resistor, one LED need only around 20mA)
there was also few rechargeable batteries which were probably used only once (i tested them at home and capacity was pretty close to the description on battery )
when I finished my measuring I packed all of the useful batteries and return a container with remaining bad ones in his place
it seems nobody registered half of them is gone :)
Step 3: Second Measuring
after I arrived home I measured batteries once more and I sorted them by their voltage
Step 4: Schematics and Some Info
I used only best batteries with 1.5V for this project rest could be used in some other projects
you can even use worse batteries if you add joule thief but I didn't have that many components for the build.
All that I used was just two batteries, switch and LED
you can also use battery box with switch and just add LED and batteries
I bought 10pcs on eBay for $5 here
green, white and blue LED could be powered by 3V without a resistor other colors need one
50-100Ω should be enough for other colors (only if you use 3V power source)
if you don't know much about electronics you can use this nice page for calculating resistor http://www.ohmslawcalculator.com/led-resistor-cal...
I also add a picture with LED voltage for each color
Step 5: Assembly
It took a few finished pieces until I learned the effective method, after that I was working faster and the assembly of 20 lights took less than three hours
Step 6: ​if You Like Satisfying Time Lapses I Have One Especially for You :)
Step 7: Packing and Storing
I added some tape to isolate LED pins (heatshrink tube would be better)
and packed it for future use
Step 8: Magnets
you can use little neodymium magnets to attach lights on metal surfaces
Step 9:
we went shooting mini film to old cold war bunker
here are some photos as we had some fun in the end
Make it Glow Contest 2018
Be the First to Share
    • Finish It Already Speed Challenge
    • Arduino Contest 2020
    • First Time Author Contest
    6 Discussions
    Tangski
    Tangski
    1 year ago
    Nice job buddy, and hey, the bunker is cool, but even more cool with your lights:) Great place to relax...LOL Or um ghost hunting perhaps??LOL Anyway, nice job!
    nikdo_nic
    nikdo_nic
    Reply 1 year ago
    many thanks
    lightening that bunker was my favorite part of this project :)
    Gadisha
    Gadisha
    1 year ago
    I like that you used old battery's, the Lights create a nice effect!
    nikdo_nic
    nikdo_nic
    Reply 1 year ago
    thank you
    audreyobscura
    audreyobscura
    1 year ago
    Wow! This really yielded a nice effect for your photos! You're seriously brave for soldering directly to battery terminals! :P
    nikdo_nic
    nikdo_nic
    Reply 1 year ago
    actually it's not that risky if you have a powerful soldering iron, low melting point solder wire battery will be ok
