Introduction: Creating IoT Devices With the ESP8266 and PubNub
In case you hadn't heard, the internet of things is king of a big deal. Rather than bore you with the predictions of how many billions of devices will be connected in the next few years, I'm going to show you how to easily create an IoT device using the awesome ESP8266 WiFi module and connect that device to anyone, anywhere, in real time with the power of PubNub.
Many projects incorporating the ESP8266 use it as an external module, communicating over a serial port with a complex set of AT commands. But this module is actually a programmable 32bit MCU with an embedded TCP stack, and if it speaks TCP, it speaks PubNub. With a bit of effort, we can write our own firmware to create a stand-alone, WiFi-enabled device!
Step 1: Project Overview and Requirements
For this project, I am using the tiny ESP-01, but any of the modules with access to GPIO0 and GPIO2 will work. The module is loaded with custom firmware, written in C, and compiled using the official SDK from Espressif on a Debian Linux machine. To start, here are a few things you need to get:
- ESP8266 Module - These are easily acquired online for a few dollars each.
- USB to Serial Module - For programming and debugging - it must use 3.3V signals! This is a great one from Sparkfun.
- Development Environment - This is the most complicated part, so I will direct you to the official documentation.
- PubNub - Sign up for a free account here, and then get your own keys here.
- Source Code - hosted in this GitHub Repository
With that out of the way, we can get down to business. Like I said before, we will be writing custom firmware to load onto the ESP8266 which can send and receive data to and from any other PubNub enabled device. With over 70 official SDKs, that shouldn't be a problem! Unfortunately, the ESP8266 is not currently an officially supported device, but never fear - I've created a basic library for use with this module that should get you going in no time! The library builds off of the PubNub REST API, but more on that later...
There is one small caveat; however, the actual networking code used in this project is not the most robust. It will connect you to a WiFi network, but it might not keep you connected through unforseen events. This will obviously affect the connection to PubNub, and you may notice intermentent performance issues after some period of time. The quick and dirty fix is a timer-based soft-reset, but adding more robust and performance proven connect/disconnect routines would be a more proper way to go. As with any aspect of an embedded system, the solution relies on your specific use case.
Step 2: Hardware Parts and Such
If you want to build a *thing*, you obviously need some real life *things*. For this demo, I am using the following components:
- Breadboard - Also called a prototyping board; we will use this to connect the other components.
- ESP8266 - You do have at least one of these by now, don't you?
- Push Button - x2 (normally open, momentary).
- LED - x2 (One is an optional power indicator).
- 10k Resistor - x2 (Color Code: Brown, Black, Orange).
- 1k Resistor - x2 (Color Code: Brown, Black, Red).
- 0.1uF Ceramic Capacitor - This is optional, but does help with performance.
- Jumper Wire - So as to connect stuff together!
Step 3: Circuit Design
The power source for this project will be the actual USB connection. The USB to Serial module should have its own 3.3V regulator that we can then use to power the ESP8266. The ESP8266 is not 5V tolerant. I cannot stress this enough! You must power it and communicate using 3.3V signals, or you will be a very sad panda. With that PSA out of the way, let's take a look at the circuit.
You should notice that the transmit pin (TX) of the ESP goes to the receive pin (RX) of the USB to serial module, and vice versa. Here is a quick rundown of what every part is doing:
- U1 - ESP8266 module.
- U2 - USB to Serial module.
- C1 - 0.1uF ceramic capacitor - (optional) "Decoupling Capcitor" to increase power line stability.
- R1 - 10k Ohm "Pullup" Resistor - Keeps the chip from resetting by providing a "weak" path to 3.3V.
- SW1 - Normally Open, Momentary Switch (push button) - Resets the chip by connecting "Reset" to Ground.
- R2 - 1k Ohm Resistor - Limits the current through LED1.
- LED1 - An LED we will control with the ESP8266.
- R3 - 10k Ohm "Pullup" Resistor - Keeps GPIO0 "pulled high."
- SW2 - Normally Open, Momentary Switch (push button) - Connects GPIO0 to Ground.
- R4 - 1k Ohm Resistor - Limits the current through LED2.
- LED2 - Power status indicator (optional).
Step 4: Wire It Up
It's time to connect all of the components together on the breadboard. I have provided a pinout of the ESP module I am using. Remember to never apply power greater than 3.3V!
The jumper wire coming off of the USB to Serial module in the picture is for the 3.3V power supply because the 'VCC' pin is wired to 5V, so I am not using that (for the previously discussed reasons). Also, the 'ESP8266 Socket' is just an easy way to plug the module into the breadboard because of it's pin spacing. It is not required, but making your own might be a good idea! The first breadboard picture shows each important component, and the last picture shows the circuit with the ESP8266 plugged in.
The ESP8266 has a few different operational modes, depneding upon the state of some of the pins. If GPIO0 is held low (connected to ground) when the chip resets, it will enter the 'UART download boot mode' which allow us to program the chip's flash memory. If you recall the circuit, we are using GPIO0 to read an active low push button, so this works out nicely.
Programming the chip:
- Press and hold reset button
- Press and hold button on GPIO0
- Release reset button
- Release button on GPIO0
If you are not used to directly programming these types of chips, this might seem strange to you, but trust me, you will get used to it quickly.
Step 5: Exploring the Firmware
With the circuit built, it's time to check out the code we''ll be installing. If you haven't yet setup your development environment, do so now! As mentioned, this is the most difficult part of the whole project, but there are numerous online tutorials for doing this in various operating systems. If you run into any problems, consult the ESP8266 Community Forum for advice.
The code is hosted on GitHub, so to get your copy, clone or download this repository.
The actual code is in the directory esp8266-helloworld-demo. If you have been developing your own firmware for this module, the directory structure should look familiar. The main source code is found in user, while included header files are place in include. The pubnub source code is found in the pubnub directory - imagine that! Compiled builds are found in build, and the files to be written to memory are in firmware.
FUN FACT: The difference between software and firmware is the actual purpose of the code. Firmware is a subset of software which is installed directly to a chip's memory rather than on top of some other operating system. For example, *VLC Media Player* is **software**, while the code that controls your microwave or the BIOS on your computer is **firmware**. Embedded devices typically run firmware, but this is not an absolute.
Step 6: Program Operation
When first powered on, LED1 will flash twice per second. This will continue until the device has connected to the internet. At this time, a connection to PubNub will be established. This demo incorporates both publishing and subscribing to a channel. Unfortunately, publish events cannot take place until a subscribe event takes place or times out. This is due to limitations in single-threaded devices. The provided library can be adjusted for a particular need (such as only publishing, or automatically subscribing) or be reworked to incorporate threading if a different SDK is used. I will leave such tasks up to you, as the exact operation of the device will be specific to your needs!
The device will subscribe to the channel "esp8266-demo". Any other device writing to this channel can send commands to our ESP8266! For this demo, we will use the developer's console, but any mobile app, web page, or other application can be used.
A message of "1" will turn on LED1, while "0" will turn it off. Pushing SW2 will request a publish which will take place at either the next subscription message received or a timeout, due to the limitations previously discussed. Removing the "Subscribe" section of code or otherwise adjusting the overall program flow will allow for real time publishing.
Step 7: The Makefile
I have provided a Makefile which will build the outputs and program a connected device; however, to use it you will have to manually adjust the location of your toolchain paths. If you have installed the toolchain based on the instructions I previously linked to, there should be minimal changes required.
The following primary targets are available for use:
- all - this is default.. it will: clean, build, clean
- build - this will: clean, build
- clean - this will: clean
- flash - this will: flash the chip
For basic compilation checks, simply issuing a 'make' command is quick and easy. To actually program the chip, you will have to issue 'make build' followed by 'make flash' (or possibly 'sudo make flash'). A working build is included in the repository, so once you have the Makefile adjusted, you can use it to flash your chip; however, until you manually configure your WiFi settings, the device will be unable to connect to the internet.
Step 8: Firmware: Main
When directly programming common microcontrollers like the Atmel AVR line, you can create a main function containing an internal "forever loop." This is not the case with the ESP8266. This module uses hooks, similar to Arduino, so the compiler will expect a few defined functions. After that, you can schedule a timer to handle repeated tasks.
The most common hooks in use are:
// Required for SDK v1.1.0 - Can be used to disable RFvoid user_rf_pre_init(void) { } // Loop function - Can/will continuously reschedule itself to runstatic void IFA user_procTask(os_event_t *events) { os_delay_us(10); // system_os_post(user_procTaskPrio, 0, 0 ); } // User Initialization void IFA user_init() { // Initialize the device here }
Othwerwise, you are free to write your own functions and call them like a normal C program. The "IFA" attribute is actually a macro I defined in include/esp8266.h as:
#define IFA ICACHE_FLASH_ATTR
If a function is prefixed with IFA, it is written to flash which is mapped to ROM. Without this attribute, the function will end up in the instruction RAM segment, which is faster, but will fill up quickly. If at all possible, always use the IFA attribute. This header file also includes most all of the SDK libraries commonly used as well as remapping a few common C functions (like printf) to the version required by the Espressif SDK (os_printf). Lastly, it defines a simple debug printing macro which can be used to selectively print statements when a certain value is defined, which it is in the *include/user_config.h* file. I use this macro extensively in the library, but be careful with it as it can easily be broken.
// Define to print debug statements over UART using DEBUG_PRINT()#define DEBUG_PRINT_ 1 // Only prints lines for debugging purposes#ifdef DEBUG_PRINT_ # define DEBUG_PRINT(S) printf S #else# define DEBUG_PRINT(S) #endif
Inside of the user_init() function, we will initialize the UART connection, setup the GPIO pins, and connect to WiFi. The values of SSID and SSID_PW are define in include/user_config.h. You must set these values to the corresponding SSID and password for your home WiFi connection! The overall code flow goes somthing like this:
- Initialize UART
- Initialize GPIO
- Initialize PubNub
- Connect to network (pause here until connection established)
- Connect to Pubnub
- Monitor button (SW2) and control LED1 based on messages received.
Step 9: PubNub Library
The provided library defines the following functions in pubnub/pubnub.h.
/** * Creates a connection to Pubnub * This should be called when a network connection is established! */void IFA pubnub_connect(void) /** * Initialize the PubNub Connection */void IFA pubnub_init(const char *publish_key, const char *subscribe_key); /** * Publish message on channel using Pubnub. * JSON type message should be used, Unicode characters are injected automatically... */bool IFA pubnub_publish(const char *channel, const char *message); /** * Subscribe to a Pubnub channel */bool IFA pubnub_subscribe(const char *channel, Pubnub_subscribeCB subCB); /** * Unsubscribe to a Pubnub channel */; bool IFA pubnub_unsubscribe(const char; *channel);
The usage of each of these functions is clearly shown in user/user_main.c. I have also supplied the full C source code instead of a typical lib file, so feel free to poke around inside and alter the code to be more specific to your tasks. The primary force behind the library is the PubNub REST API. An HTTP Get request string is build and used for all functionality. Using these basic building blocks, other PubNub functionality can be added including Presence, History, and Security.
Step 10: Using the PubNub Debug Console
PubNub has supplied an easy to use console for quickly testing applications. Using the console can get you up and running much faster than developing a full web interface, or can easily test different aspects of your overall program. You can find the console here.
In the console, type in your unique publish and subscribe keys, the channel to listen on, and push "Subscribe." You can then send messages to the channel as well as monitor the channel for all messages published!
Step 11: Serial Debugging
If you plan on modifying the code to do your bidding (and I highly encourage you to do just that) you will want to make use of the DEBUG_PRINT() statements scattered about the library. These will print information through the serial port whenever various events take place. The UART is initialized to a baudrate of 9600, but this is easily modified in include/user_config.h. In Linux, I am using the program gtkterm for serial bugging.
The first image shows a typical initialization of this demo.
After this initial message is sent, PubNub will send an empty response. Now, we can subscribe to a channel. The first subscribe call will use a Timetoken of '0'. PubNub will respond with a valid timetoken which should be used in the next subscribe call. (Refer to the second image.)
From here on, every resonse after a subscribe will contain a new Timetoken. This new Timetoken should always be used in the next subscribe call. After a subscribe call, the program will wait for a response or a timeout. When a message is received, it will be displayed, and the user defined subscribe callback function in user_main.c will be called. (Refer to the third image.)
If the button on GPIO0 is pushed, a publish request will be made. You should see a "Waiting on subscription(s)" message. The publish will then happen after the next message is received or a timeout occurs (in roughly 300 seconds). After the publish event, a new subscribe call using the last Timetoken is made again. (Refer to the fourth image.)
Note, that any messages sent from this device to a subscribed channel will be received on this device as well. (Refer to the fifth image.)
Step 12: Wrapping Up
That about does it for this demo. I hope you have seen how easy it can be to create IoT devices using an ESP8266 module, and the incredible amount of versatility PubNub offers to that device. You can communicate with your thing in real time from any other PubNub enabled device in the world! The presented library can also be customized for your specific needs. Functionality can easily be added or removed, and the basics shown here can really be applied to any other chip you want to use that has TCP capabilities. So go forth, and create something amazing! Just be sure to let me know what you come up with.
