Curved Surface Paint Scraper
3,487
23
7
Introduction: Curved Surface Paint Scraper
I have an old wooden kitchen worksurface which I want to strip and use for another project. The backboard has a curve where it meets the worksurface, and a flat paintscraper would not work for getting in there.
There were no suitable tools in any of the paint stores, so I had to make my own.
A large washer from the junk box had exactly the right curve to get in there, so that, plus some M6 threaded rod and various fixings were pressed into service.
Components:-
M6 threaded rod
M6 nuts
M6 washers
Huge M12 washer from the junk box
Step 1: Assemble Tool Head
The tool head, comprising the scraper blade, the shaft, and the various bits connecting the two were assembled.
First, I cut a six inch chunk of M6 threaded rod, using this wonderful 'Ible to get a clean, quick cut.
The large diameter washer which would be the blade was too loose on the shaft, but a couple of narrower washers neatly filled the gap.
A padding washer on either side held everything together, and then the nuts which lock everything together were tightened as hard a possible.
Step 2: Make Tool Handle
I was really lucky in that my scrap pile had a six-inch length of lovely hardwood broom-handle, complete with a metal ferrule.
I needed a hole drilled in the end of the handle to accept the threaded rod of the tool, and it had to be co-axial with the handle.
To try and achieve this I clamped a vertical guide underneath my drill-press and held the dowel against that while I drilled a hole about 1mm wider than the threaded rod.
After the hole was drilled, I used a couple of grades of sandpaper to smooth the outside and give a nice feel to the handle.
Step 3: Fit Tool to Handle
To hold the tool in the handle, I used two-part epoxy.
Whichever brand of epoxy you use, read and follow the instructions, especially any notes about local climate. It's winter here and freezing cold, so that gave me a little more working time.
Following the instructions on the resin, I squeezed out matching amounts of the two components onto a clean, smooth piece of scrap timber, mixed them thoroughly with a piece of thick wire and then left them to stand for fifteen minutes.
Then I used the wire to scrape the epoxy into the hole in the end of the handle, and once it was all there I inserted the threaded rod of the tool and left the resin to cure for a day.
Step 4: Sharpen Tool
To give a good edge for lifting softened paint, we need to put an edge on the metal disc. To encourage the scraper to lift, rather than smear, the paint, we need to take material from the trailing edge of the blade.
This would most easily be done by working the trailing edge of the blade against a bench grinder, but since I don't have one, I fitted a metal-polishing disk to my angle-grinder and clamped that in a portable workbench.
For a tight curvature like this, it is much easier to get a smooth grind by manipulating the workpiece than by trying to manipulate the tool.
I held the blade of the scraper against the grinding disk and rotated the handle of the scraper to get an even chamfer on the trailing edge of the scraper blade.
Once the blade shape was right, I removed the burr from the workpiece with a medium cut file.
Step 5: Summary, Mistakes and Learnings
This tool is absolutely perfect for scraping the curve at the internal angle on the wood. I was extremely lucky that I had a washer the exact right curve to make this. The internal hole in the middle of this washer was so large that it would have slopped around on the shaft, but through another stroke of luck, I had a couple of washers whose internal diameter matched the rod, and whose external diameter matched the inside of the washer which would be the blade. The take-away from this, is to have a big box of random washers.
As you can see from the first photograph, the hole is a bit skew-whiff from where it should be. Rather than holding the rod against the upright guide when drilling, I should have spent longer to get everything clamped and held rigidly in the right place.
The second photograph shows me pushing glop into a tiny hole using some wire. Next time I might spring a dollar for a syringe from the pharmacist so that I can load it up, then inject the resin quickly and more cleanly.
Be the First to Share
    • Puzzles Speed Challenge
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    7 Discussions
    OutofPatience
    OutofPatience
    1 year ago
    Nice 'ible for a handy tool! I have a table to scrape and refinish ("someday") and this just might be the ticket for the curves on the legs. Thanks! (My rural location is also not conveniently situated for popping out to purchase tools on the spur of the moment.)
    Alex in NZ
    Alex in NZ
    Reply 1 year ago
    Thank you for the comment :-) Good luck with reducing your "someday" backlog.
    Iriscamp
    Iriscamp
    Tip 1 year ago on Step 5
    Once you have the all-thread cut and the washers fitted chuck the all-thread in the drill press and put the press in a slow speed and use a file to sharpen the edge.
    Alex in NZ
    Alex in NZ
    Reply 1 year ago
    That is a brilliant idea! Thank you very much for that. I will certainly remember it when I have a similar problem. :-)
    Omnivent
    Omnivent
    1 year ago
    Hi,
    Just FYI, You're probably set for the job at hand, but any well assorted tool shop should be able to sell you a round/circular carbide blade for the Bacho 625 scraper (or buy the scraper with triangle, round, pear- or drop shaped carbide blade). Not the cheapest, but carbide tools are never cheap and even if you don't like the very ergonomic handles, you can get the blades in one-off.
    Wouldn't use a steel scraper blade since I got my first (flat) Bacho carbide blade and my 625 is always within reach, as I beat it up on lots of jobs that need a scratch and a scrape.
    Have a nicew day :)
    Alex in NZ
    Alex in NZ
    Reply 1 year ago
    Not the tool shops round here, mate :-D
    Thanks for the tip. I've just checked that out on-line. They look great quality, but seem to be smaller than I need. The diameter quoted of 17mm(2/3") is far too tight to give a smooth interface to the curve I was after. The washer I ground down has a diameter of about twice that, and it fits the curve perfectly.
    The 625 blade (alone) is priced at $35 with one month delivery time, so I think I'd still have gone with my steel blade. The downside of living in paradise, is that it's a long way from warehouses :-)
    Thanks for your comment, and for the pointer to the Bahco scrapers.
    Omnivent
    Omnivent
    Reply 1 year ago
    Wow, that is expensive. The local (Denmark) "discount" tool shops sells the round blades for the equivalent of around NZ$18.5 (which I still think is expensive for what they do)
    Wish we were neighbors, city life is a high price to be near the goods you only need occasionally.
    Enjoy your Paradise lucky guy :)
