Introduction: DIY 200 Watt Portable Amplifier
Hey! everyone My name is Steve.
Today I'm going to show you How to Make 200 Watt Portable Amplifier
Let's Start
Step 1: Features
Output Power
- 100 Watt x 2 @ 2Ohms
Input Power
- 11 - 24V DC
Built-in Protection
- Over Load Protection
- Short Circuit Protection
Over Heat Protection
Step 2: Make Your PCB
This post is supported by NEXTPCB.
I’ve been really impressed with the quality and consistency of their work. NEXTPCB offers professional PCB fabrication and assembly services, making it easy to bring custom electronics projects to life — whether you're prototyping or doing full production. Their support team is helpful, turnaround times are fast, and the results speak for themselves. If you're looking for a reliable partner for your PCB needs, I genuinely recommend checking out NEXTPCB.
Step 3: Thing I've Used
Banggood
- Amplifier Board - https://bit.ly/2PTgM6F
- Aluminium Case - https://bit.ly/2FmHkIN
- Speakon Connector - https://bit.ly/2FmHkIN
- XT60 Connector - https://bit.ly/2FmHkIN
- PCB Stand-Off - https://bit.ly/2FmHkIN
- Heat Shrink Tube - https://bit.ly/2FmHkIN
- RCA Connector - https://bit.ly/2FmHkIN
- Rubber Pad - https://bit.ly/2FmHkIN
- Speakon Male Connector - https://bit.ly/2FmHkIN
- Drill Bit - https://bit.ly/2FmHkIN
Amazon
- Amplifier Board - https://amzn.to/2S9D94w
- Aluminium Case - https://amzn.to/2S9D94w
- Speakon Connector - https://amzn.to/2S9D94w
- XT60 Connector - https://amzn.to/2S9D94w
- PCB Stand-Off - https://amzn.to/2S9D94w
- Heat Shrink Tube - https://amzn.to/2S9D94w
- RCA Connector - https://amzn.to/2S9D94w
- Rubber Pad - https://amzn.to/2S9D94w
- Speakon Male Connector - https://amzn.to/2S9D94w
- Drill Bit - https://amzn.to/2S9D94w
Aliexpress
- Amplifier Board - http://bit.ly/2zq2y33
- Aluminium Case - http://bit.ly/2zq2y33
- Speakon Connector - http://bit.ly/2zq2y33
- XT60 Connector - http://bit.ly/2zq2y33
- PCB Stand-Off - http://bit.ly/2zq2y33
- Heat Shrink Tube - http://bit.ly/2zq2y33
- RCA Connector - http://bit.ly/2zq2y33
- Rubber Pad - http://bit.ly/2zq2y33
- Speakon Male Connector - http://bit.ly/2zq2y33
- Drill Bit - http://bit.ly/2zq2y33
https://www.utsource.net/ is an online platform for electronic technicians, Makers, Enthusiasts, Kids to find electronic components
Step 4: Marking & Drilling
- I Used a Philips Head Screw Driver to Open the Encloser
- And Then I placed the amplifier on top of the Encloser and used a Center Punch to Punch 4 Holes
- And then I used a 3mm Drill Bit to Drill the Punches
Step 5: Drilling Front Panel
- For Audio Input I used a Pair of RCA Sockets So, I used a 3mm Drill Bit to drill the corresponding holes and then I used a Step Drill bit to enlarge the holes
- For Volume Controle I used a 22K Dual Gang Potentiometer So, I used a 3mm Drill Bit to drill the corresponding holes and then I used a Step Drill bit to enlarge the holes
Step 6: Drilling Back Panel
- For Audio Output I used a Female Speakon Socket So, I used a 3mm Drill Bit to drill the corresponding holes and then I used a Step Drill bit to enlarge the holes
- For Power Input I Used a Mountable Female XT60 So, I used a Sharp tool to make an outline on the panel and used 1mm Drill bit to drill " See the Image "
- And Used a File to make it Prefect " See the Image "
Step 7: Circuit Diagram
Step 8: Assembling of Front Panel
- First, I Installed 2 RCA Sockets
- And then Installed Potentiometer " See the Image "
- And i Soldered Shielded wire according to the Diagram " See the Image "
Step 9: Assembling of Back Panel
- First, I Installed Female Speakon Connector using 2 Nuts and Bolts
- And then I Installed XT60 Using 2 Nuts and Bolts
- And then I Soldered Some thick Wire " See the Image "
Step 10: Board Assembly
- I used some Stand-off to give it some clearance
- And then I Removed the Screw Terminal Connectors to make some Space Inside
- And Then I Soldered 4 Speaker wire for Each Channel and 2 wire for power input " See the Image "
Step 11: Final Assembly
- First, I Inserted the main board and then I've used 4 M3 Screws to tighten it up
- And then I closed the Back panel and used 4 M3 Screws to tighten it up
- And then I used a tweezer to put signal wire " See the Image "
- And then I closed the Front panel and used 4 M3 Screws to tighten it up
- Lastly, I used 4 rubber pad " legs " " See the Image "
Step 12: Setup and Enjoy
- The Amplifier is Finished
- Now Just Plug the power and Enjoy
You Just Made It
Thank you for visiting my Instructables Stay tuned for next Projects
