Introduction: DIY 300 Watt 5.1 Channel Amplifier
About: Hi, I'm Steve! I'm a creative mind with a knack for technical skills—I can build just about anything you can dream up! From innovative projects to captivating designs, I bring ideas to life with passion and pr…
Hey! everyone My name is Steve.
Today I'm going to show you How to Make 5.1 Channel Amplifier
Click here to See the Video
Let's Start
Step 1: Make Your PCB
This post is supported by NEXTPCB.
I’ve been really impressed with the quality and consistency of their work. NEXTPCB offers professional PCB fabrication and assembly services, making it easy to bring custom electronics projects to life — whether you're prototyping or doing full production. Their support team is helpful, turnaround times are fast, and the results speak for themselves. If you're looking for a reliable partner for your PCB needs, I genuinely recommend checking out NEXTPCB.
NextPCB
Step 2: Gallery
Pictures
Step 3: Features
Input Power
  • 24V DC @ 15A
Input Signal
  • 6 channel
Output Power & Signal
  • 6 Channel x 50watt @ 4 Ohms = 300 Watt @ 4 Ohms
Operation
  • 5.1 Via Sound Card " Windows Computer only "
  • 5.1 Via Digital to Analog Converter " Aux Input & Digital Input "
Built-in Protection
  • Over Load Protection
  • Short Circuit Protection
  • Over Heat Protection
Step 4: Things You Need
Recommended Products
Where To Buy "Cheapest"
Bangood
1. TPA3116 Audio Amplifier - https://goo.gl/dCeLgE
2. XT30 connector - https://goo.gl/T8uxyC
3. XT60 connector - https://goo.gl/Tm4rRQ
4. Acrylic Sheet - https://goo.gl/T8uxyC
5. PCB Standoff - https://goo.gl/T8uxyC
6. 5.1 Sound Card - https://goo.gl/T8uxyC
7. 5.1 Digital to Analog Converter - https://goo.gl/T8uxyC
8. Blitzwolf® Audio Cable - https://goo.gl/T8uxyC
9. 3.5mm to RCA - https://goo.gl/T8uxyC
10. 24v 360 watts Power Supply - https://goo.gl/T8uxyC
11. Soldering Iron - https://goo.gl/T8uxyC
12. Heat Shrink Tube - https://goo.gl/T8uxyC
Mechanical parts with discount here - https://goo.gl/TTA1Z5
Amazon
1. TPA3116 Audio Amplifier - http://amzn.to/2gShZaJ
2. XT30 connector - http://amzn.to/2gShZaJ
3. XT60 connector - http://amzn.to/2gShZaJ
4. Acrylic Sheet - http://amzn.to/2gShZaJ
5. PCB Standoff - http://amzn.to/2gShZaJ
6. 5.1 Sound Card - http://amzn.to/2gShZaJ
7. 5.1 Digital to Analog Converter - http://amzn.to/2gShZaJ
8. AmazonBasics Audio Cable - http://amzn.to/2gShZaJ
9. 3.5mm to RCA - http://amzn.to/2gShZaJ
10. 24v 360 watts Power Supply - http://amzn.to/2gShZaJ
11. Soldering Iron - http://amzn.to/2gShZaJ
12. Heat Shrink Tube - http://amzn.to/2gShZaJ
Aliexpress
1. TPA3116 Audio Amplifier - https://goo.gl/oLzZ46
2. XT30 connector - https://goo.gl/oLzZ46
3. XT60 connector - https://goo.gl/oLzZ46
4. Acrylic Sheet - https://goo.gl/oLzZ46
5. PCB Standoff - https://goo.gl/oLzZ46
6. 5.1 Sound Card - https://goo.gl/oLzZ46
7. 5.1 Digital to Analog Converter - https://goo.gl/oLzZ46
8. Blitzwolf® Audio Cable - https://goo.gl/oLzZ46
9. 3.5mm to RCA - https://goo.gl/oLzZ46
10. 24v 360 watts Power Supply - https://goo.gl/oLzZ46
11. Soldering Iron - https://goo.gl/oLzZ46
12. Heat Shrink Tube - https://goo.gl/oLzZ46
https://www.utsource.net/ is an online platform for electronic technicians, Makers, Enthusiasts, Kids to find electronic components
Step 5: Soldering Job
  • Solder XT30 Female to the Speaker Output of the Amplifier " See the Image "
  • Repeat this process for all Three boards
Step 6: Stand Off Installation
  • First, install the standoff "as shown in the image "
Step 7: Wiring
  • Now, I used an XT60 with little wire and connected 3 little wire " see the image "
  • And, Then I connected that to the board " see the image "
Step 8: The Acrylic
  • I took an acrylic sheet and marked the point for drilling " see the image "
  • Drilled, and then I peeled off the protective layer
Step 9: Final Assembly
  • Now Assemble " as shown in the image "
  • Connect all the Power Wire
  • Now, Take some screw and install the acrylic sheet
Step 10: Connection
  • Connect all the Speaker wire " XT30 " and Power Wire "XT60"
Step 11: Windows 5.1 Setup
  • Connect all the signal wire to the amplifier with Sound Card
  • And, Plug the USB and Install the Sound Card Driver
Step 12: Digital & Aux 5.1 Setup
  • Now connect all the Signal wire to the Digital to Analog Converter " As shown in the image "
Step 13: Finishing
Power Supply
  • Connect your Power Supply to the XT60 Connector " 24v "
  • Now connect all the Speaker and Power
  • And, you are Ready to roll
Click Here to See The Video
You Just Made It
Thank you for visiting my Instructables
Stay tuned for next Projects
