Introduction: DIY Backyard Water Slide
Step 1: Tools and Supplies
You Will Need:
1.Drill
2.Screws
3.Wood
4.Foam Blocks
5.Bubble Wrap
6.Hoses
7.Tarp
8. laminated Surface(Plastic/Laminated Wood)
9. Clamps
Step 2: The Base
First create a frame for the slide. Create a 6x4 frame using the wood and screws. pretttty simple.
Next cut a sheet of wood to fit over top of this frame. Screw it down.
Finally cut the laminated wood to fit over the board. Screw it down.
Step 3: The Pool.
Next we must create the pool. To create the pool just place the foam blocks where you want the perimeter of the pool. Then place the tarp over-top of the perimeter just created. push the tarp inward until it touches the ground. Finally place wood around the edges to hold it down. Make sure to leave a gap on the side to release water.
Step 4: Foamify
In this step you will build the Support for the ramp. To do so stack up some foam blocks next to the pool as high as you want the slide to be. place a layer of bubble wrap over the end of the pool where the slide will be. Lay the Finished base down over the foam support you just made.
Step 5: Finishing Up!
Green Living & Technology Challenge
Watersports Summer Challenge
