DIY Charcuterie Board - a One Day Project That Sells
5,795
56
Introduction: DIY Charcuterie Board - a One Day Project That Sells
Youtube Channel: Penalty Box Woodshop - Instagram: @penaltyboxwoodshop - Website: www.penaltyboxw...
Hey folks, Im Jesse with Penalty Box Woodshop and today Im going to show you how I turned scrap walnut into a beautiful charcuterie board. A charcuterie board is used to display and serve meats and cheese at social gatherings and events. Its basically a really nice serving tray! You can easily complete this project in one day and Im going to show you each step that I took to make it.
This DIY Charcuterie board project is an easy one day project that you can easily sell! You can make one for yourself and impress your friends at a party or add it to your list of scrap wood projects!
If you like this video please click here to subscribe to my channel
You can check out my website for more great stuff!
Supplies:
List of tools used in this build:
Howards Cutting Board Oil
*MWA Woodworks Video - How to make your own cutting board finish
Total Boat Epoxy
Hazelnut Pigment
Microjig Dovetail Pro Kit
Forstner Bit Set
Makita Router
Delta Table Saw
Dewalt Planer
Biesemeyer Table Saw Fence
Delta Miter Saw
Canon T6i DSLR
Rode VideoMic Microphone
Canon EF 28-135mm f/3 Zoom Lens
Teacher Notes
Step 1: Pick Out a Hardwood, Cut to Size, and Flatten
A while back I was given a stack of air dried walnut that had been stored outdoors for some time. There were a lot of good boards in the stack but a few had live edges, worm holes, and were just not suited for some projects. But, one thing they were perfect for was a charcuterie board. I cleaned the live edges up with a chisel and cut the board to about 34 inches.
For a project like this one, any type of hardwood will do just fine. The size of your charcuterie board is completely up to you and can be customized to fit anyones needs.
This board needed to be flattened and it was too wide for my jointer so I used my planer sled, some shims and my planer. If you don’t have a planer you can use a router and a router sled or even just a hand plane to flatten your board if it needs it. And if it doesn’t, well I guess you get to skip these first few steps.
Step 2: Fill Any Holes or Voids in the Wood As Necessary
After it was nice and flat on both sides I used some epoxy and hazelnut colored tint to fill all of the worm holes. There were a lot of them but I think it just adds some character to the board. After the epoxy was cured I removed the excess with my planer. You could choose to leave the holes or voids in the board but I was worried that food and other things would get stuck in the crevasses. Also, Hazelnut tint is typically my go to color with walnut but they make epoxy tint in just about every color under the sun.
Step 3: Design and Cut Out Your Handle
Next, I began to lay out the handle for the board. The design and shape is completely up to you and you can be as creative as you want with this. I used some circle cutoffs from another project to help me with the lines and I used one of my table saw push stick handles to trace a comfortable width for the handle of the board. After a few adjustments I liked the shape that I had come up with. I clamped the board to my bench and used my cordless jigsaw to cut the handle. It was pretty simple and I wasn’t very worried about being exactly on my lines for this.
I got out my spindle sander and smoothed out all the edges and rounded parts. If you do not have spindle sander then you can easily use a palm sander to do this.
Step 4: Drill a Hole in the Handle
Over at the drill press I used a forester bit to drill a hole in the handle. Ive seen these thumb holes on other boards and thought they were a nice touch. Also, I figured it would be a good way to hang it for storage once its completed. With my cordless router I broke all the edges with a slight chamfer with exception of the live edges.
Step 5: Sand the Live Edge and Refill Any Exposed Holes
For the live edge, I got out one of my sanders and used a low grit sandpaper to clean them up and ensure all of the bark and sharp edges were gone. That opened up a few more worm holes so I had to bust out the epoxy one last time to fill them. Once that epoxy cured I sanded the entire board staring at 80 grit and stopping at 180 grit.
Step 6: Wet the Board With Water and Sand to Final Grit
I used a spray bottle and sprayed all sides of the board with water. This will raise the grain before the final sanding and ensure that the board stays smooth forever. Once it dried, I sanded it with 220 grit and make sure you don’t forget to sand your edges on this step.
Step 7: Apply a Natural Finish and Enjoy!
Now for my favorite part, the finish. I use an all natural finish like Howards and Walrus oil or you can make your own like my buddy Matt with MWA Woodworks does. Ill link his video on how to make his board finish in the tools section if you want to check it out, it’s a simple process that I will start using from now on.
I applied the first coat and let it dry for a few hours before wiping the excess off. I let that dry and applied a second coat just because this walnut really seemed like it needed it. After the second coat dried I used a shop rag to buff it out to nice sheen and this board is ready for some meat and cheese!
For more details you can watch the full build video here:
If you want to see more woodworking and DIY videos then please Subscribe to my channel
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    2 Discussions
    thesees1
    thesees1
    9 days ago on Step 2
    Did the cured epoxy machine well with the planer? Did that process wear the blades out pre-maturely ?
    penaltyboxwoodshop
    penaltyboxwoodshop
    Reply 9 days ago
    Yes, the planer works great for smoothing or removing excess epoxy. The epoxy is close to or softer than wood so there are no adverse effects on your blades other than normal usage.
