DIY Face Masks to Support Medical Personnel
25,319
69
10
Introduction: DIY Face Masks to Support Medical Personnel
About: Hi. I'm Ellen, PhD student by day and sewer/crafter/maker by night. I believe anyone can be a maker, so I post videos on YouTube about what I make and how I make it to offer some help. I believe that if you...
This is a translation of a tutorial I made for an initiative by “Make In Belgium”. Different rules and requirements may exist in your area, so please check in with your local health providers before making and donating masks.
There is currently a very high demand for facemasks due to the corona virus, especially for medical personnel, and the available stock is reducing quickly. For this reason, “Make in Belgium”, in collaboration with the Belgian Government Office for Public Health, developed an emergency solution: facemasks you can make yourself and donate to hospitals and other medical institutions.
The facemasks do not provide as much protection as official facemasks, but in case of a shortage they are definitely better than nothing. You can also use them if you’re sick yourself, so that official facemasks remain available for medical personnel.
Please note that this facemask is not suitable for protection when you’re around infected people. It’s main purpose is to prevent yourself from infecting others.
You can download the (Dutch) pattern from http://maakjemondmasker.be
The mask is constructed like a pillowcase. This makes it possible to place a disposable filter inside the mask. In addition, the multiple layers provide better protection than a single layer. The pleats help with the fit.
Use fabric that’s 100% cotton, or cotton with 35 to 65% polyester. The most important thing is that the fabric can be washed at 90 degrees C. This also applies to the ribbons. In addition, the fabric should not be too thick, because this inhibits breathing.
In case of medical personal, neutral and plain colors are preferred. But if you’re making a mask for yourself, you can of course use whatever you want.
Teacher Notes
Step 1: Precautions
Wash the fabric and ribbons at 90 degrees C before you start.
Take the following precautions:
- Wear a mask yourself
- Disinfect your sewing machine
- Wash your hands thoroughly
Step 2: Material Preperation
Print the pattern on A4 paper, cut it out and stick it together. Decide if you’re making the large, small or kids size. Pin the pattern pieces to the fabric and cut them out. Make sure to use different colors for the inside and the outside, so that they’re easy to recognize for the wearer.
Cut 4 ribbons with a length of 50 cm. If you don’t have any ribbon that’s washable at 90 degrees C, you can also make strips out of fabric by folding the edges inwards and sewing them shut.
Step 3: Press the Folds and Pleats
Mark the location of the pleats and the fold on the fabric.
Press the fold towards the inside with an iron.
Press the pleats by lining up the pleat marks and pin them in place.
Step 4: Stitch the Hem, Fold and Pleats
Hem the bottom of both pieces by folding the fabric inwards half a centimeter. Stitch it in place.
Stitch the fold in place at the edges.
To make the next steps easier, I’m stitching the pleats in place at the edges too.
Step 5: Assemble the Mask
Place both pieces right sides together and pin them down. Sew them together at the top.
Place the ribbons in the corners of the front piece and pin them in place so that they’re pointing inwards.
Fold the pieces right sides together and pin them down. Make sure the ribbons aren’t in the way. Stitch down both sides to attach it all together.
Turn the mask right side out, and it’s done!
Step 6: Donate Masks
Wash the masks you made again at 90 degrees C to disinfect them, and pack them as sterile as possible, for example in plastic ziplock bags.
Follow the instructions of your local hospitals and other medical institutions to donate the masks.
Step 7: Wearing a Mask Yourselves
If you’re wearing a mask yourself, make sure you wash your hands before touching the mask. Don’t touch the inside of it, and use the ribbons to tie the mask in place without your hands getting close to your face. Don’t wear the mask any longer than necessary and replace it when it’s wet. You can wear safety glasses on top for a better fit around the nose.
Disinfect the mask at least once a day by washing it at 90 degrees C. And remember, wearing a mask doesn’t protect you from infection. It’s meant to prevent you from infecting others.
That’s it.
Take good care of yourself and help the people around you as much as you can. You can do that by making face masks for medical personnel, but also by following the advice of health institutions, washing your hands often and thoroughly, and supporting vulnerable people in your area.
Be the First to Share
    • Cardboard Speed Challenge
    • Sculpting Challenge
      Sculpting Challenge
    • Indoor Plants Challenge
    10 Discussions
    garry52w
    garry52w
    Question 16 hours ago on Step 7
    What kind of filters are used by hospital workers and are they available anywhere now or all gone or reserved for necessary workers?
    danakmckinney
    danakmckinney
    2 days ago
    I too would like to find the pattern.
    Dana
    GreenHorn2019
    GreenHorn2019
    4 days ago
    The N95 mask IS designed to protect the wearer. It is a tight fitting mask that is meant to be fitted to the wearer thus minimizing any air entering from around the mask. https://www.cdc.gov/niosh/npptl/pdfs/UnderstandDif...
    I do applaud these efforts in making these masks for I believe minimizing the amount virus floating around for others to inhale is a worthy goal. The virus enters the body via the nose, and mouth, enters the lungs infects the cells of the lung, uses the mechanisms of the cell to reproduce, ruptures the cell to break free and then goes on to infect more cells as well as exit the body as we breath, speak, cough and sneeze. The destruction of the cells of the lungs decreases the effectiveness of the lungs to absorb oxygen requiring the infected person requiring intubation.
    Bloostephie
    Bloostephie
    Question 14 days ago on Step 7
    Where can I find the pattern
    Donna_N
    Donna_N
    14 days ago
    Such a useful tutorial in these times. I'm about to make a few. Thanks!
    meanblackbike
    meanblackbike
    Reply 13 days ago
    I love the instructable , great job.
    But I also know that the covid-19 also can infect when is it in the eyes.
    So maybe this instructable and this one:
    https://www.instructables.com/id/DIY-Gas-Mask/
    can be combined in a new mask that protects all : eyes, mouth and nose (I mean that gas mask uses anti-dust masks that are no easy to buy this days).
    Also there has to be some thinking in perfect fit and insulating the edges on the masks (both instructables). For insulating the mask you can use those foams for dish washing (by hand) and glue a peaces to the edges - most importantly between the nose and chicks (where you can see a gaps that fails the protection needed).
    Also can use paper clip or peace of aluminium (or other plastic metal) sheet metal to close the nose gaps.
    There is another one :
    https://www.instructables.com/id/DIY-Cloth-Face-Mask/
    perhaps you can make one joint forces instructable (check the comments also there is valuable data).
    dpeach
    dpeach
    13 days ago
    My wife has been making masks for the last week for our local providers. I am excited to see so many people stepping up to do what they can. Sure, these aren't as good as medical grade masks, but they are certainly better than none.
    Thanks for posting this and showing people how they can be part of the solution.
    tercero
    tercero
    14 days ago
    Thanks for everything you're doing. You're one of the heros in my books.
    And thanks for clarifying for those reading this, that masks do absolutely nothing to protect a person from inhaling the virus. They're only remotely good for those already infected. I wish people would get that through their thick heads and stop stealing masks and equipment from hospitals.
    Some clown stole most of the N5 masks out of the ER in Barrie, Ontario.
    jessyratfink
    jessyratfink
    14 days ago
    Thank you so much for sharing!
