DIY Reusable Cozy for Your Cup Out of Vegetable Tanned Leather
11,565
56
8
Introduction: DIY Reusable Cozy for Your Cup Out of Vegetable Tanned Leather
About: We are Amy and Tanner Skrocki and we are a husband and wife full-time artist team who are also parents of a 4-year-old. We create a variety of handmade items including metal work, leather-work, woodwork, pap...
My husband and I go out for coffee quite a bit, while we are running errands, and we noticed the coffee sleeve or cozy was not thick enough to reduce the heat and it wasn't reusable. So we decided to make our own out of vegetable tanned leather. This coffee cozy tutorial will show you how to cut, add a border, stamp, dye and finish your coffee sleeve. The included video shows all the steps as well.
Supplies:
Tools: Hand Border Tool, Edging tool, ruler, rotary cutter, leather scissors, rotary punch, mallet, rivet setting tool, anvil horn or other metal piece for setting rivets on curved leather pieces, assorted leather stamps or alphabet sets, hand or machine burnishers, ruler
Materials: Vegetable tanned leather between 4-6 ounces, template, painters tape, pen/awl, rivets, linen free cloth or rag for dying, sponges, water and dish, water based dye or dye of your choice, leather finish of your choice - I used carnauba wax, beeswax for burnishing edges
Step 1: Step 2: Print and Cut Out
Print and cut out included template on card stock.
Step 2: Step 2: Select Leather and Cut Out
Find a piece of vegetable tanned leather between 4-6 oz. Cut out the template and you can tape down the template if you need to onto the leather with painter’s tape. Don’t press too hard with the tape or it may leave marks on the leather.
Step 3: Step 3: Mark the Holes
Mark the holes with a pen, pencil or awl. Don’t worry any mark you make will be punched out with your rotary punch.
Step 4: Step 4: Cut Your Leather
You can trace around the template with a pen, pencil or awl or if you have experience with a rotary cutter you don’t need to trace around the template. You can also use leather scissors. If you decide to use scissors you may want to trace around the template that way it won’t shift.
Step 5: Step 5: Punch Your Holes
Punch marked holes with rotary punch. Aim for the centre of the mark you made. You want to make a hole that fits snuggly around the rivet.
Step 6: Step 6: Trim Any Uneven Spots
Trim any uneven spots with your leather scissors.
Step 7: Step 7: Wet Leather
Wet your leather with sponge if you want to add any tooling, lines, initials etc. If you don’t want to add any decoration skip to step - dying your leather.
Step 8: Step 8: Border Tool
Add an optional border to the project with a hand border tool.
Step 9: Step 9: Edging Tool
Round the edges, optional, with a hand edging tool.
Step 10: Step 10: Measure
Take your ruler and mark the places where you want to add any stamps to.
Your stamps must be added while the leather is damp.
Step 11: Step 11: Stamp or Tool
Use stamps or alphabet sets on tool steel, an anvil or granite slabs.
Step 12: Step 12: Dye
Dye your coffee sleeve with the dye of your choice. I used Tandy’s water based dye. Wipe off any excess dye, let your item dry and repeat 2-3 times or as many times as necessary to achieve the look you want. Once the front is dyed you can choose to dye the inside or leave it natural leather.
Step 13: Step 13: Seal
Once your project is completely dried you can add a sealant to your leather piece with a sponge or cloth. This can be carnauba wax or any sealer you wish to use. Let your sealer dry and buff the front with lambs wool or another soft cloth.
Step 14: Step 14: Burnish the Edges
Select the burnished tool that is available to you. I found the wooden tools work the best. Add beeswax to the edges of your item. 2-3 times around should be more than enough. If your beeswax is soft you may only need to go around once or twice. Too much beeswax can ball up while you are burnished and it can mark your leather. Burnish edges until they are smooth and shiny. Trim any extra fibres and add more beeswax if edges are not smooth and go over again with your burnisher.
Step 15: Step 15: Rivets
Select the rivet color of your choice. I picked black double capped 7/16” rivets for this project. Smaller rivets would also work as well.
Step 16: Image 16: Set Rivets
The rivets can be easily set over the horn of an anvil or any rounded tool steel. Hammer rivets into place and give your item a quick final buff with your soft cloth or the lambs wool and you are done!
If you need any extra help check out the video!
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Puzzles Speed Challenge
    8 Discussions
    bahadur321
    bahadur321
    1 year ago
    I would prefer not to see that comfortable getting wet. Cowhide truly does not do well with water or dampness. Be that as it may, in any case, it's an extremely dazzling structure and it's very much created! I took in a ton about the perishing procedure and for the most part, working the calfskin take from this, so much appreciated !
    TossManual
    TossManual
    Tip 1 year ago
    This is a zarf, BTW: great scabble word...
    maxhirez
    maxhirez
    Reply 1 year ago
    I'm glad someone else posted this. It means either it's true or that I wasn't the only one who fell for it.
    UdyRegan
    UdyRegan
    1 year ago on Introduction
    I would hate to see that cosy get wet.. Leather really does not do well with water or moisture. But regardless, it's a really lovely design and it's well crafted! I learnt a lot about the dying process and generally working the leather strip from this, so thanks!
    AmieB
    AmieB
    1 year ago
    Always looking for easy saleable things to make with my stash of leather! These are great! <3
    AmyandTanner
    AmyandTanner
    Reply 1 year ago
    Thank you so much Penolopy!
