Introduction: DIY Self Watering Dog Dish
Here's an easy way to keep your dogs dish or bowl full of water so he or she won't go thirsty! Recently I was at the hardware store and had a 4" PVC coupler in my hand and had an ah-ha moment! I realized right away how I could make a self watering dog bowl to eliminate my dogs occasional dry water dish. What I came up with was an easy to make self filling dog dish that works flawlessly! It re-purposes a soda bottle, pop bottle, or cola bottle to make this self watering bowl, which is good for the environment, and my dog!
Step 1: A Quick Video
Some can visualize better by watching the video. Good luck with this Instructable!
Step 2: Parts List
All dog bowls are different in size so specific measurements for this instructable aren't necessary. Watch the video at the end to get a better idea.
You'll need:
1) a piece of plywood for the base.
2) a piece of 2x4 for the stand
3) one white 4" PVC coupler (get it at the hardware store)
4) 4 screws.
5) 2 litre pop bottle with "hour glass" shape
6) optional: paint it whatever colour you like!
Step 3: The Base
First, take the piece of plywood and use the 4" PVC coupler to scribe a rounded shape on the front corners. This will keep it feet and dog paw friendly.
Step 4: Cutting the Base
Now use a jig saw to cut the corner pieces. If you don't have a jigsaw, a good sanding will do the trick.
Step 5: Sanding and Smoothing
This step is optional. I used my router with a rounding bit to round out the edges of the 2x4 to give it that store bought pro look.
Step 6: Adding the Base
Now pre drill 2 holes in the base for the 2x4. Use 2 screws to attach the base to the 2x4. You don't have to pre-drill but it makes it easier to assemble.
Step 7: Cutting the Coupler
Next make 2 marks on the coupler about an inch or 26mm apart and cut it out using a hacksaw. Use sandpaper to smooth out the edges.
Step 8: Drilling the Coupler
Make 2 marks and drill the coupler. It's easy to spread the PVC coupler apart a bit to get the drill in there or drill from the back.
Step 9: Attaching the Coupler
We're ready for the last step! Place your dog bowl on the base. Fill the bottle with water and screw the cap on. Now slide the bottle into the PVC coupler upside down making sure the hour glass part of the bottle is seated in the middle of the coupler. Now hold the PVC coupler against the 2x4. The level of the water will be determined by the position of the mouth of the bottle. You can choose to have a low water level or high, whichever you want. Now remove the bottle and screw the PVC coupler to the 2x4 with 2 screws.
Step 10: Your Dog Will Love You!
You're finished! Slide the bottle into the coupler and remove the cap!
Step 11: How to Make a Self Watering Dog Dish
Grand Prize in the
Dog Challenge 2016
