Introduction: DIY Starwars Sith Wayfinder
Hello! :)
In this tutorial i show you how to make a simple Starwars Sith Wayfinder to find planet Exogol. The materials you need are pretty basic. Here’s my list :-):
Materials
cardboard sheet
printed template
semi translucent paper or something else you like to use for the windows
hot glue gun
Led light
plastic cap translucent
permanent marker in the color you like
black fineliner for the window drawing
knife/scissors/pencil/masking tape
Step 1: Cut Out My Template and Trace Onto Cardboard
Print out the template that i made, cut them out with your scissors and trace the shapes onto the cardboard sheet. cut out all the cardboard parts with your hobby knife and only light cut the lines where you will need to fold the cardboard. Make sure you don’t go all the way trough :-).
Step 2: Print or Hand Draw the Windows
print out the windows on to the semi translucent paper or any other paper you had in mind. Regular paper will work as well but it reduces the amount of light going trough, quite a lot. you could use also thin plastic sheets like the stuff you find in ordners to keep paper documents in :). In that case you can trace the drawing onto the plastic by hand. After finishing the windows you can insert them into the pyramid shape.
Up next is finishing the sides of the bottom of the wayfinder with the small elements.
Step 3: Green Light
use your marker to color the leds of your light source. Also color the plastic cap that will be mounted on top of the hole in the wayeinder’s base. This plastic cap will extra color the light and make it much more diffuse. It will spread the led light better to the windows.
Step 4: Finish Up and Make the Wayfinder Float
Use your glue gun to finish up the wayfinder. A little extra effect could be achieved by sticking white paper onto the bottom of the base. use little pieces of cardboard to make the wayfinder float. The white paper will reflect a bit of the light and peeks underneath the wayfinder :-)
Step 5: Ready to Enjoy!
You are ready! Time to find the way to Exogol ;-)
