Dark Chocolate Mocha Truffles
2,302
46
10
Introduction: Dark Chocolate Mocha Truffles
About: We're an honest-to-goodness, old-fashioned, hobby-farming family in the rolling green hills of our great American MidWest. If you think Mayberry is a place of the past, think again! We're doing our best to l...
Two things you can never go wrong with are coffee and chocolate... And when they're together, even better! I've been making these truffles a few times a year for the last 25 years, and they're still a family favorite! These truffles are so rich and bursting with creamy coffee flavor!
Teacher Notes
Step 1: Ingredients
you'll need the following ingredients to make your own scrumptious truffles:
48oz semi sweet chocolate chips, for the ganache center
16oz cream cheese, softened (Just take it out of the fridge 20 minutes before you start the project)
1/2 cup instant coffee powder
1/4 cup water
48 oz chocolate chips (milk chocolate, semi sweet, dark, or a mix) for coating; used in last 2 steps
If for some strange reason, you don't want to make 200 bite sized mouthfuls of happiness, here are the measurements for making a batch that's half the size of the one above: (the directions/procedures for making them will all still be the same for a small batch)
24oz semi sweet chocolate chips, for the ganache center
8oz cream cheese, softened (Just take it out of the fridge 20 minutes before you start the project)
1/4 cup instant coffee powder
2 Tablespoons water
24 oz chocolate chips- (milk chocolate, semi sweet or dark) for coating; used in last 2 steps
Step 2: Just Beat It
In the bowl of your stand mixer, beat the cream cheese, instant coffee, and water. Leave the mixture in the mixer, as you'll be coming right back to it.
Step 3: Melt Chocolate
Now, melt the chocolate for the center. I prefer not to use the microwave to melt chocolate. Instead, I bring a pot of water to a boil, then set a bowl with the chocolate chips over the pot. As the chocolate melts, use a spatula to scrape the sides of the bowl and stir.
Step 4: Mix It Up
As soon as the chocolate is melted, pour the melted chocolate into the cream cheese mixture, and mix on medium speed until thoroughly incorporated.
Step 5: Spread and Chill
Line a large cookie sheet with parchment paper.
Spread the mixture out evenly. You'll want it to be about an inch thick. Refrigerate for at least 3 hours. If the chocolate is going to be chilling for more than a few hours before you get to it, do yourself a favor and cover it! Plastic wrap is great! If you don't cover it, your truffles will end up tasting like all of the things you forgot were in your fridge. :)
Make sure you spread the mixture BEFORE you refrigerate it! If you put the bowl in the fridge, you'll end up with a hardened mass of chocolate, making it incredibly difficult to portion out for truffles later...
Step 6: Cutting
Once the chocolate mixture has chilled, we'll cut them into squares that are about 1×1inch. You can probably see that the lines in the picture arent perfectly straight and that some pieces are bigger than others, so there's no need to pull out your ruler here. And definitely hide the scale...
Step 7: Rolling
Now we separate the pieces, and roll them. Using your fingers, sort of pinch the corners in to round the shape a bit. Then using both your hands, roll the piece of chocolate quickly to make a ball. The slower you work, the faster it will melt, and then the messier your hands will get. I find it extremely helpful to keep most of the squares in the fridge and take them out 20 at a time, to keep them all from warming up too much before I work with them. Once they're all rolled out, they can go right back on that cookie sheet in the fridge to think about all the damage they're about to do.
Step 8: Melt the Other Chocolate
Using the same heating method as in step 3, melt the second portion of chocolate chips. While you're waiting for it to heat up, prepare a cookie sheet or two with parchment paper, and take the truffle balls out of the fridge.
Once the chocolate is melted, work quickly to drop the truffle balls, one or two at a time, into the melted chocolate. Leave them there only long enough to be covered in chocolate. 5-7 seconds is ideal. More than that, and the truffles will start melting. Using a fork, lift the truffle out of the chocolate. To smooth out any bumps that may be on top, and to conserve chocolate, tap the handle of the fork on the edge of the bowl before transferring the truffle to the cookie sheet.
Let the truffles harden slowly at room temperature. Once they're set up enough to touch, it's safe to refrigerate them. (If they go into the fridge too soon, they could lose that shine, and get a cloudy, murky look.)
Step 9: Finished!
Your truffles are finished! Seriously, who ate them all?! When we do make enough to gift, we wrap them in foil candy wrappers, or set them in cute little gift boxes. They also store really well, so they ship to long-distance friends and relatives too!
Thanks so much for reading this instructable, y'all- Feel free to add comments/questions down below!
Coffee Speed Challenge
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Wearables Contest
      Wearables Contest
    10 Discussions
    tcs79
    tcs79
    Question 26 days ago
    Why cream cheese? It´s a truffle, cream cheese is a salt product. They don´t supposed to be togheter. NEVER!!
    Marianholdings
    Marianholdings
    Answer 26 days ago
    The cream cheese makes the truffles very creamy and rich; they're incredibly smooth and the little bit of added salt in the cream cheese has never been a problem. I've also been known to sprinkle a bit of salt on the truffles while they're still wet, getting that dark chocolate- sea salt combo so many people love!
    Gale joiner
    Gale joiner
    26 days ago
    My son is a baker-caterer and we're going to make these for his daddy's 80 th birthday party. Saw Martha Stewart on tv and she was using a yardstick to cut squares!
    Marianholdings
    Marianholdings
    Reply 26 days ago
    That's so exciting!! I'd love to see a picture afterward :)
    Oh my! I wouldn't have the patience to measure so closely- I knew how big my baking sheet was and guesstimated how many rows and columns I'd need to make
    TeresaM7
    TeresaM7
    26 days ago
    This would be super simple to change to a sugar free version. I can't wait to get into the kitchen!
    Marianholdings
    Marianholdings
    Reply 26 days ago
    Definitely! Besides using allergy-friendly chocolate, I've added xylitol to unsweetened chocolate with great results!
    Phleb61
    Phleb61
    26 days ago
    Those would be great for a keto diet if you just used sugar-free or stevia sweetened chocolate chips!
    Marianholdings
    Marianholdings
    Reply 26 days ago
    So true! We've used Enjoy Life brand chocolate in the past too for super-allergic friends and relatives!
    Marianholdings
    Marianholdings
    Reply 26 days ago
    Thank you so much!
