Decorative Pegboard Frame
2,155
33
9
Introduction: Decorative Pegboard Frame
Pegboards can be a fun, organized way to display your tools and keep you in a crafty state of mind. Unfortunately, they often come with ragged brown edges that look a little too rough to display inside. This tutorial will show you how to create a sub-$20 wooden border to nicely frame your pegboard and cover those raw edges. You can even customize your paint color to coordinate with your craft room.
Step 1: Gather Supplies
You will need:
  • Moulding for the entire perimeter of your pegboard (I purchased mine at Home Depot for $1.37/foot)
  • Handsaw and Miter box or saw of your choice
  • Acrylic paint and paintbrush
  • Liquid Nails or similar wood glue
  • Sealant (optional)
This project came out to just under $20 for my 4' x 2' pegboard. Let's get started!
Step 2: Measure and Mark Moulding
First determine a consistent direction for your moulding. Traditionally, the more detailed side faces inward. Then carefully align the edge of your moulding to any edge of your pegboard, making sure your desired side of the moulding is facing inward. Make a light mark on the outer corner of the wood where the pegboard ends, as well as an arrow from the outer corner towards the middle of the pegboard. This will help ensure that you saw in the correct direction. Repeat for every edge of the pegboard.
Step 3: Saw Moulding
Set up your moulding in a safe, well-lit location and saw at a forty-five degree angle according to your markings. Sand away any rough edges. Align your four pieces with the edges of your pegboard and ensure they sit smoothly against one another before putting away your saw.
Step 4: Paint and Seal
Cover your workspace and grab a large paintbrush. Apply 2-3 generous coats of acrylic paint to the front and sides of each piece of moulding. I recommend painting the angled sides as well in case there are gaps between your wood pieces. If you'd like to add additional gloss and protection, follow up with an application of sealant after the acrylic is completely dry. Make sure your project is in a location where it can remain undisturbed for the entire drying time of the sealant.
Step 5: Glue to Pegboard
Quickly dot wood glue along one edge of your pegboard, align the moulding, and press down thoroughly. If you do not have clamps to help the wood bond to the pegboard, consider recruiting a helper to hold the pieces together for several minutes. Repeat for every edge of the frame. After gluing down all pieces, use a toothpick to remove any glue spillover. Let your frame sit for several hours before handling.
Step 6: Mount
After your glue has fully dried according to the bottle instructions, you're ready to hang or display your pegboard however you'd like. Enjoy your polished new frame!
1 Hour Challenge
1 Hour Challenge
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    9 Discussions
    beadinbythesea
    beadinbythesea
    Question 1 year ago on Step 1
    What width did you use for the moulding?
    spookydonuts
    spookydonuts
    Answer 1 year ago
    I used 1.5” moulding.
    beadinbythesea
    beadinbythesea
    Reply 1 year ago
    Thank you, I already ordered 3/4" but I think it will work. Will post a photo when finished. Thanks for the tutorial!
    spookydonuts
    spookydonuts
    Reply 1 year ago
    That will definitely work, can’t wait to see it!
    violetsmuse
    violetsmuse
    1 year ago
    OMGosh, super cute and super smart idea!
    klp0445
    klp0445
    Question 1 year ago on Introduction
    Did you put something in back of frame so there was space for the metal pegs to go thru so they don’t hit the wall?
    spookydonuts
    spookydonuts
    Reply 1 year ago
    I bought a peg kit that included ~.75" rubber stoppers with screw holes to add some distance between the board and the wall. 1" wooden square blocks or rods on the back of the board would work, too.
    AmyandTanner
    AmyandTanner
    1 year ago
    so cute!! this would really class up my studio!
    Alex in NZ
    Alex in NZ
    1 year ago
    Nice! Especially the little rail for hanging the ribbons. Thank you for sharing :-)
