Introduction: EF 230: Home System 3000 Instructable
The Home System 3000 is a device that uses an Arduino, a temperature sensor, a piezo buzzer, an optical detector/phototransistor, and a servo to display ways to improve home energy efficiency.
Step 1: Temperature Sensor
· Run your power and ground wires from
the micro controller to the side of the bread board
· Place the temperature sensor into the bread board, and run the corresponding power and ground wires accordingly
· Notice that the temperature sensor has three prongs, and the middle prong has a wire that runs from the port "A0".
· Code for temperature sensor:
answer = questdlg('Please run arduino and servo start code','response','Ok','Ok')
prompt = 'Press any key to begin'
pause
prompt1 = 'Set minimum temperature'
x = input(prompt1)
prompt2 = 'Set maximum temperature'
y = input(prompt2)
prompt3 = 'press any key to begin'
pause
figure
h = animatedline;
ax = gca;
ax.YGrid = 'on';
ax.YLim = [65 85];
stop = false;
startTime = datetime('now');
while ~stop
% Read current voltage value
v = readVoltage(a,'A0');
% Calculate temperature from voltage (based on data sheet)
TempC = (v - 0.5)*100;
TempF = 9/5*TempC + 32;
% Get current time
t = datetime('now') - startTime;
% Add points to animation
addpoints(h,datenum(t),TempF)
% Update axes
ax.XLim = datenum([t-seconds(15) t]);
datetick('x','keeplimits')
drawnow
% Check stop condition
stop = readDigitalPin(a,'D12');
Step 2: Buzzer
· Wire in the buzzer that will be used to signal an extreme high or extreme low temperature reading
· No wire is run from the positive column to the positive side of the buzzer
· Instead a wire is run from the positive side of the buzzer to a port labeled "11"
This will be used later to call the location of the buzzer in the written code.
· Code for buzzer:
if TempF >= y
disp('close door it''s hot')
playTone(a,'D11',500,1)
elseif TempF <= x
disp('close door it''s cold')
playTone(a,'D11',250,1)
end
end
Step 3: Optical Detector/Phototransistor
· This sensor requires resisters unlike the others
· Make sure all four prongs of the sensor are included in the loop after plugging in the wires
· The sensor detects a change in light, representing motion, and records it as an input
· Code for Optical Detector/Phototransistor:
clear a
a = arduino('/dev/tty.usbserial-DN01DVI2', 'Uno', 'Libraries', 'Servo');
prompt = 'Set light level threshold'
z = input(prompt)
lightLevel = 0
while lightLevel ~= -1
lightLevel = readVoltage (a,'A1')
if lightLevel >= z
answer = questdlg('would to like to alter AC?','Yes','No')
switch answer
case 'Yes'
answer2 = questdlg('Turn AC up or down?','response','Down','Up','Up')
switch answer2
case 'Down'
s = servo(a, 'D10');
for angle = 0:.1:.5
writePosition(s, angle);
current_position = readPosition(s);
current_position = current_position * 180;
% print current position of servo motor
fprintf('Current position is %d\n', current_position);
% small delay is required so that servo can be positioned at the
% angle told to it.
pause(2);
end
% bring back motor to 0 angle position
writePosition(s, 0);
clear s
prompt = 'Press any key to continue'
questdlg('AC turned down','response','Ok','Ok')
case 'Up'
for angle = .5:.1:1
% angle told to it.
pause(2);
end
Step 4: Servo
· The servo represents
an air conditioner, and is an output of the motion detection input
· It requires a positive wire, ground wire, and a wire from port "D9" to the servo
· Code for servo:
clear s
questdlg('AC turned up','response','Ok','Ok')
end
end
pause
break
end
end
*Special note: some of the code for the servo is integrated with the code for the optical detector/phototransistor.
