Introduction: ESP32 Handheld Game Console
This instructables show how to use a ESP32 and ATtiny861 to build a NES emulator game console.
Step 1: Hardware Preparation
ESP32 Dev Board
This time I am using a TTGO T8 ESP32 dev board. This board have built-in Lipo charging and regulating circuit, it can help reduce the extra components.
Display
This time I am using a 2.4" IPS LCD. The driver controller is ST7789V and the resolution is 320 x 240. This resolution is best fit for NES emulator 252 x 224 resolution.
Battery
This time I am using a 454261 Lipo battery. 4.5 mm is the thickness of ESP32 dev board, and 61 mm is the width of the board.
Pin Header
A 4 pins male round pin header and a 4 pins female round pin header for connecting I2C gamepad.
PETG Plate
A small PET/PETG plate for supporting the dev board and Lipo battery, you can easily find it in product packing.
Multiple Purpose PCB
2 PCB required, 1 0.4 mm thick for supporting the Display, 1 1.2 mm thick for a I2C gamepad.
Buttons
A 5 directions button, 2 small buttons for Select and Start and 2 for A and B button.
I2C Gamepad Controller
This time I use a ATtiny861 microcontroller as an I2C gamepad controller.
Others
1 SMD 12 Ohm resistor, a ISP programmer (e.g. TinyISP)
Step 2: Software Preparation
Arduino IDE
Download and install Arduino IDE if not yet: https://www.arduino.cc/en/Main/Software
ATTinyCore Support
Follow the installation steps to add ATTinyCore support if not yet: https://github.com/SpenceKonde/ATTinyCore/blob/mas...
ESP-IDF
Follow the ESP-IDF get started guide to setup the development environment if not yet: https://docs.espressif.com/projects/esp-idf/en/sta...
Step 3: 3D Printing
Download and print the case: https://www.thingiverse.com/thing:3591170
Step 4: LCD Support
Cut a 24 x 27 holes 0.4 mm PCB for LCD support. Remember reserve some space for folding LCD FPC. Then use some double side adhesive tape fix the LCD on the PCB.
Step 5: Prepare PETG Plate
Cut out a 62 mm x 69 mm PETG plate for dev board and Lipo battery support.
Step 6: Fix ESP32 Dev Board
Use double side adhesive tape to fix dev board on the PETG plate.
Step 7: Fix Lipo Battery
Use double side adhesive tape to fix Lipo battery besides the dev board.
Step 8: Connect Battery & Dev Board
Step 9: Prepare Display Pins
LCD display have many variation form different vendors. Please obtain the correct datasheet and read it before any patch and connection.
Some pins are reserved for touch panel. Since this LCD do not have touch panel, simply cut out those pins can reduce the disturbance.
Step 10: Connect GND Pins
In most case, there are few pins require connect to GND. To reduce soldering effort, I cut a copper tape shape to reach all the GND pins and then soldering altogether.
Step 11: Connect Vcc Pins
There are 2 pins required connect to Vcc, LCD power and LED power. According to data sheet, LCD power can direct connect to dev board 3.3 V pin but LED power operate a little bit lower than 3.3 V. So it is better add a SMD resistor in the middle, e.g. 12 Ohm resistor.
Step 12: Connect LCD & Dev Board Support
use tape connect LCD support and dev board support together. Both support should reserve around 5 mm gap for folding.
Step 13: Connect SPI Pins
Here are the connection summary:
LCD ESP32 GND -> GND RST -> GPIO 33 SCL -> GPIO 18 DC -> GPIO 27 CS -> GPIO 5 SDI -> GPIO 23 SDO -> not connected Vcc -> 3.3 V LED+ -> 12 Ohm resistor -> 3.3 V LED- -> GND
Step 14: Flash Program
- Download the source code at GitHub: https://github.com/moononournation/esp32-nesemu
- Under source code folder, run "make menuconfig"
- Select "Nofrendo ESP32-specific configuration"
- Select "Hardware to run on" -> "Custom Hardware"
- Select "LCD Type" -> "ST7789V LCD"
- Fill pin settings: MISO -> -1, MOSI -> 23, CLK -> 18, CS -> 5, DC -> 27, RST -> 33, Backlight -> -1, IPS -> Y
- Exit and Save
- Run "make -j5 flash"
- Run "sh flashrom.sh PATH_TO_YOUR_ROM_FILE"
Step 15: I2C Connector
Breakout the I2C pins, ESP32 default I2C pins are:
Pin 1 (SCL) -> GPIO 22 Pin 2 (SDA) -> GPIO 21 Pin 3 (Vcc) -> 3.3 V (no 5 V power while powered by Lipo battery) Pin 4 (GND) -> GND
Step 16: Assembly Part 1
Follow the video steps to fold and squeeze all the parts into the case.
Step 17: Prototype I2C Gamepad
The program for the I2C Gamepad is very simple, only 15 lines of code. But it is a little bit hard to reprogram the ATtiny861 after soldering, so it is better test it on the breadboard first.
Download, compile and flash the program from GitHub: https://github.com/moononournation/attiny861_i2c_...
Step 18: Build I2C Gamepad
Here are the connection Summary:
ATtiny861 Button GND -> All buttons one pin Pin 20 (PA0) -> Up button Pin 19 (PA1) -> Down button Pin 18 (PA2) -> Left button Pin 17 (PA3) -> Right button Pin 14 (PA4) -> Select button Pin 13 (PA5) -> Start button Pin 12 (PA6) -> A button Pin 11 (PA7) -> B button Pin 6 (GND) -> I2C male pin header pin 4 Pin 5 (Vcc) -> I2C male pin header pin 3 Pin 3 (SCL) -> I2C male pin header pin 1 Pin 1 (SDA) -> I2C male pin header pin 2
Step 19: Assembly Part 2
Follow the video steps to install the cover and the I2C gamepad to the main body.
Step 20: Optional: Audio Breakout Pins
ESP32 dev board Pin 25 and 26 is outputting the analog audio signal, it is very easy to breakout the these 2 pins and also power pins (3.3 V and GND) on the top. Then you can patch a earphone to plug on it. Or even you can add an audio amplifier module with speaker to play it loud.
Step 21: What's Next?
NES emulator is not the only interesting thing you can make with ESP32. E.g. you can build a micro python console with it. The only component you need to change is from I2C gamepad to I2C keyboard. I think it is not so difficult to make it with a ATtiny88 controller. You may follow my twitter to see the status.
