Introduction: Easy Homemade Nail Glue
Hi guys! In this DIY I will tell you how you can make homemade nail glue at home because nail glue is expensive and why not know how to make it?! :)
Step 1: THINGS YOU NEED AND HOW TO MAKE IT.
First things first things you will need!
Small container
glue(white or clear)
Clear nail polish
1 Q Tip
Steps to make and apply!
Pour glue in small container filling about half of the container with glue .Make sure that the container is clean first. (White glue or clear glue, can be found in department or craft stores.)
Add the clear nail polish filling up the rest of the small container. The clear nail polish will the glue adhere smoothly to your nails. Cut the end off of a Q tip. Use the end that is free of the cotton to mix the glue and clear nail polish together. You will also use this to apply the glue to your nails. If you used the cotton side, you would get pieces of cotton stuck to your nails. Hold your fake nail down over the glue that you put on your real nail for at least one minute so that the homemade glue can set properly. It takes about 10 minutes to harden completely.
Hope this works for you!
~<3Fritz707
