Introduction: Easy Smurf Costume With Pattern
It will take you longer to paint yourself blue than it will to make this easy Smurf costume! In ten minutes or less, you can make this super simple Smurf hat (known historically as a Phrygian cap) from the pattern included. All you need is some white fleece (or red if you're dressing as Papa Smurf!) and basic sewing skills (ok, I won't tell if you use staples instead), and you're ready to go!
Step 1: Materials
I used 1/2 yard of white polar fleece for this hat. I ended up stuffing the tip of it with polyester fiber fill. Traditionally, these types of hats were often used to store and carry supplies. Sort of like head pockets! What do you think Smurfs kept in there?
Download and print out the attached pdf pattern, gather your scissors and thread (ok, I used a sewing machine for this), and let's get started.
Step 2: Cut
Tape together the two pattern pieces, and compare the bottom measurement with your head measurement. You may want to adjust the pattern to be larger or smaller to suit your needs. I made the pattern extra long so I could fold the excess to the inside. You can decide how long you want the hat as well!
Trace the adjusted pattern onto your fabric.
Add 1/2" seam allowance all the way around and cut out. You'll want to cut out two pieces.
Sew the pieces together along the curved edge, leaving open along the bottom.
Turn the hat right-side out.
Step 3: Finish
I stuffed some polyester fiber fill into the end of the hat to make it look more cartoony.
Next I tried the hat on and figured out where it bent naturally on my head. I pinned the tip to the body of the hat and sewed it down so it wouldn't be so floppy.
That's it! Add your blue body suit (or, if you're very brave, paint), white pants or dress, and you're ready to go Smurfing around town!
Halloween Easy Costumes Challenge
