Introduction: Easy to Make Hot Glue Bowl!
This is a neat project for you if you are bored and need something easy to do or if you want something nice to put on your desk!
Step 1: Materials
All you will need to make this is:
Hot glue gun
Hot glue sticks
Parchment paper or wax paper (optional but recommended)
Step 2: Building
First, put a blob of hot glue onto the paper that you are using. This will be the base of your bowl, so make sure it's the size you want it to be.
Next, glue a ring JUST around the base so it makes a rim around it. After that, glue another ring around the rim and then another on top of that. Keep doing that so the base keeps getting taller. The rings should gradually get larger and larger so that they form a bowl shape.
Step 3: Finishing Up
Ta Daaa!!! A bowl made entirely out of hot glue!
You could stop here, but to improve it even more, use the tip of your hot glue gun and melt away and rough places, then turn the bowl inside out! The outside will look even better now!
Thanks for reading, and feel free to share your bigger and better bowls!
~Seawee
Weekend Projects Contest
