Equatorial Mount for DSLR
19,353
289
87
Introduction: Equatorial Mount for DSLR
About: I'm a French mechanical student, I like to design and make things and share them here. My main hobbies are astronomy, astrophotography and 3D printing.
As a big fan of astrophotography and 3D printing I had to build my own equatorial mount for my DSLR.
For this project I used Fusion 360 to design all the pieces.
With this instructable you can design your own or you can use my STL files and follow the assembly tutorial.
Enjoy!
Supplies:
Electric:
  • 1x stepper motor 28BYJ-48 5V
  • 1x ULN2003 driver board
  • 1x Arduino (I used nano but every arduino will work)
  • 2x push button (I used a double momentary toggle switch)
  • 2x led 3mm (1x Orange + 1x Red)
  • 1x DC jack adapter
  • wires, soldering iron,
Mechanic:
  • 2x ball bearing (10-30-9)
  • 1x metal tube 105~110 mm long with external diameter according to the bearing (here 10 mm)
  • 3D printer + PLA
  • Screws + nuts (I used M2.5 kit)
  • 1x M8 threaded rod + M8 nuts
  • Heavy stuff
Others:
  • 1x DSLR camera + lens
  • 1x Tripod (mine is a Manfrotto Compact Advanced)
  • 1x Camera ball joint
  • 1x Kodak screw to mount the ball joint
  • CAD software if you want to modify the files (fusion 360 is free for students)
Teacher Notes
Step 1: Purpose
As you know, Earth is rotating, so it is not easy to photograph stars because they leave star-trails.
In astrophotography, we use the "500 Rule" it allows to take pictures of the night sky without noticeable star trails: divide 500 by the focal length of your lens and you will obtain the maximum exposure time. However, with the crop factor of my DSLR it turns out to be the "300 Rule". My lens is a Canon 24mm f2.8 so according to the rule: 300/24=12.5 I can only shoot stars during 12.5s and that is very short to capture enough light from them.
The device I made is tracking stars, that allows to get rid of that rule and shoot as long as we need.
Fortunately the rotation of the Earth is well known, the axis is passing through the north celestial pole and the rotation speed is 1rev/23h56min4s (stellar day)
With that we can create a device that turns on a parallel axis and at the exact opposite speed as the Earth.
It is called "equatorial mount", it is commonly used with a telescope because with only 1 motor it tracks stars.
Some of them are big and really powerful in order to rotate enormous telescopes but some others are small carrying only a DSLR that is what I wanted to make.
It can also be useful to make timelapse according to earth's rotation.
Step 2: Designing
First, 1rev/23h56min4s is slow, very slow. And for my star tracker I wanted as few gear wheels as possible in order to reduce play in the mechanism that is why I didn't make a planetary gear. I decided to make a simple gear reducer with only 2 wheels, one with 10 teeth and the other with 60 teeth, that way, it divide the speed by 6 and multiply the torque by 6, perfect !
The main shaft is made from a copper tube the material is not very important but it must be a tube, you will understand why later. It has a diameter of 10mm because I had some 10-30-9 bearings (those may be oversized but it results in a very reliable revolute joint)
I used a 5VDC 28BYJ-48 stepper motor, which is not very powerful but with the gear ratio it should be enough
As I live in the north hemisphere at roughly 45° latitude I tilted the Manfrotto socket by 45° the adjustments will be ensured by the tripod head.
I designed all the parts using Fusion 360.
on the 2nd picture, pieces with a "*" are not 3D printed.
Step 3: 3D Printing
I 3D printed all the parts on my Creality Ender 3 with those settings:
  • Cura slicer
  • ICE filament 1.75mm
  • nozzle 210°C
  • bed 50°C
  • 20% infill (gyroïd)
  • 0.16mm / 0.2mm layer height
  • no supports
  • Ø 0.4mm nozzle
  • 40mm/s
the total printing duration is roughly 12h.
Here is the Thingiverse link to the files: HERE (.stl and .f3d)
Step 4: Prototyping
23h56min4s is equal to 23.9344444...h
1rev/23.934444h on the main shaft --> 1rev/3.989074h on the motor shaft
4096steps/rev on the motor --> 1 step every 3.506s [3.506022s]
The DSLR stays motionless during exactly 3.506s so according to the 500 and 300 Rule : the equatorial mount will work with lens below 142mm focal length on a full frame and below 85mm on a crop factor.
In order to drive the motor with 4096 steps, there is this Arduino library by tyhenry.
Here is the code to put in the arduino board if you live in the northern hemisphere.
/*<br>Sketch by SimonRob
3D printed equatorial mount for DSLR
int buttonA1 = 0;
int buttonA2 = 0;
int ledOrange = 4;
int ledRed = 5;
#include <CheapStepper.h>
CheapStepper stepper;
void setup() {
  pinMode(A1, INPUT);
  pinMode(A2, INPUT);
  pinMode(ledOrange, OUTPUT);
  pinMode(ledRed, OUTPUT);
void loop() {
buttonA1 = digitalRead(A1);
buttonA2 = digitalRead(A2);
if (buttonA1 == HIGH){
  digitalWrite (ledOrange, HIGH);
  digitalWrite (ledRed, LOW);
  stepper.step(false);
  delay(6);
if (buttonA2 == HIGH){
  stepper.step(true);
  delay(6);
while((buttonA1 == LOW)&&(buttonA2 == LOW)){
  digitalWrite (ledOrange, LOW);
  digitalWrite (ledRed, HIGH);
  delay(3506);
the member videoenquirer modified the previous code for the southern hemisphere :
Step 5: Assembly
  1. Screw the motor in place with 2x M2.5 screws + nuts
  2. Hammer the bearing on the tube, 20mm from the end
  3. Place those in the corresponding hole of the main body (red piece)
  4. Hammer the second bearing on the top
  5. Place a washer or anything that can be a spacer here
  6. Insert 4x M2.5 nuts where it is needed (here is the example on the big gear wheel)
  7. Screw the big wheel and the support on the tube, tight them enough to make a mark on the tube
  8. Remove those 2 pieces and drill 2 holes at the marks
  9. Sharpen the end of 2 screws
  10. Screw the big wheel and the support on the tube
  11. Insert the M8 nut into the support piece
  12. Screw the M8 threaded rod
  13. Screw a camera ball joint with a Kodak screw
  14. Add counterweight on the threaded rod to balance the mass of the DSLR
Step 6: The Controller
Once printed, screw in place the two PCB (Arduino + ULN2003 driver) and place the components in the box.
Solder wires according to this schematic:
Then plug the motor and clip the lid on the box
Step 7: How to Use It?
  1. Place the star tracker on the tripod (tube pointing to the north).
  2. Screw the DSLR on the ball joint, and add the counterweights on the other side.
  3. Remove the small gear wheel from the motor to release the axis.
  4. Then adjust the counterweight to balance the rotating part, and put back the small gear wheel.
  5. Look into the tube and adjust the head of the tripod the see the North Star into it (you can also use a laser through the tube).
  6. Power on the equatorial mount and enjoy !
Step 8: Astrophotography
Here is my first photography with the mount :
Here is a picture of th milky way,
Canon 750D, Equatorial mount, Canon 18-55mm stm (at 27mm), f/4, iso1600, 196s
You can see that even at 196s exposure, stars stays dots (except in the corners due to chromatic aberations) however there is a motion blur on the trees. If you want them sharp too, you will have to add a motionless picture of your foreground and mix those into Photoshop or Gimp.
on the picture we can easely notice some deep sky objects:
I also practice astrophotography with a telescope, you can see my photos on Instagram ;)
Space Challenge
First Prize in the
Space Challenge
3 People Made This Project!
  • Sew Fast Speed Challenge
  • Fandom Contest
    Fandom Contest
  • Jewelry Challenge
    Jewelry Challenge
87 Discussions
Spi_WvS
Spi_WvS
5 days ago
Finished mine yesterday... only to find out, that my program has the wrong direction of rotation. On the northern hemisphere, the camera has to rotate clockwise :-) Changed that in my code.
I also printed an adapter for a cheap laser module (6mm diameter) to fit into the 10/8mm tube. You can find it here:
https://www.tinkercad.com/things/93DpwaPHiin-guide...
As a counterweight i used the case of an old 42mm motor (magnets still in place), filled that with nails and a piece of 10mm-tube. To make it nicer, i also printed two endcaps for the 42mm tube.
SimonRob
SimonRob
Reply 5 days ago
AWESOME ! Can you post a picture :)
moggymad1
moggymad1
8 days ago
Thanks for sharing your project. I've just finished building one for myself but with a slight modification to the tripod mount so it'll fit my tripod's quick release and changed the 45° angle to match my latitude of 53.5°. I'm hoping the skies stay clear to I can test it tonight.
SimonRob
SimonRob
Reply 8 days ago
Ho nice ! If you have time could you post a picture of your mount in "I made it!" ?
Hope it will work fine :)
moggymad1
moggymad1
Reply 8 days ago
Sure will. I'm just waiting on a battery holder to finish printing & it'll be done.
fredbear
fredbear
18 days ago
The "Kodak screw" is just a 1/4-20 UNC thread. Common in the US.
I have tried to find information on the tripod you are using, the Manfrotto website doesn't seem to have it, nor the 45 wedge part which is not printed. Are the Manfrotto part numbers for these items available?
While I am considering building this, the fact that the "wedge" is an important consideration is a problem. What does the wedge normally connect with (in Manfrotto terms)?
Paul Nance
fredbear
fredbear
Reply 18 days ago
The important part of the "Kodak screw" is that it is long enough to provide a secure hold on the camera, while not being long enough to damage the camera. One should measure the depth the the screw into the camera.
SimonRob
SimonRob
Reply 18 days ago
Orange: kodak screw
Green: ball joint
Blue: camera
SimonRob
SimonRob
Reply 18 days ago
The kodak screw is holding the ball joint which is holding the camera (thanks to the kodak thread on it)
SimonRob
SimonRob
Reply 18 days ago
In fact the 45°wedge is 3D printed ! ;)
(The schematic shows all the parts, but those with a "*" are not 3D printed)
My manfrotto is the compact advanced and it has a piece with a Kodak screw on top, that piece has to be remove to place the 3D printed wedge instead.
I would love to see the result of your work !
Simon
synaptic.axon
synaptic.axon
15 days ago
Found this via Thingiverse. This is one of the better Instructables I've seen. Thanks for explaining this in such detail and making the models available.
SimonRob
SimonRob
Reply 14 days ago
Thank you ! :D will you make it ?
synaptic.axon
synaptic.axon
Reply 14 days ago
I may build it but it's at the end of the queue. :)
I've been doing research on types of trackers so that I can track Starlink satellites and I want to be able to dynamically adjust the aim on 2ft parabolic beam antennas on simple masts (can't climb them to aim and they're miles apart). I'm not quite sure this fits the bill for those two use cases but I may experiment with this type someday using jetsons and rpi cams in my maker observatory.
seriesman71
seriesman71
14 days ago
Hello again. I attach some images of my finished mount. The counterweights are turned out of 40mm aluminium alloy bar, in sections because my modellers lathe can't cope with anything bigger. The whole design is simple, brilliantly engineered and the STL files are so accurate - no filing or shaping at all. Thank you for a superb project executed to perfection.
SimonRob
SimonRob
Reply 14 days ago
Wow so nice! I am so happy to see my design here! Did you attach the controller to the side of the mount ? That is smart ! Mine is just hanging on the cable ... If you have time, could you post an "I made it" ? It will allows to group the pictures of those who made it :)
I wish you good skies!
jdavis1278
jdavis1278
16 days ago
Can't wait to build this with my nephew and try it out! I've been looking for a DIY solution to star tracking, and this looks like it just might fit the bill!
