Introduction: Esp32 Temperature and Humidity Web Server Using PYTHON & Zerynth IDE
Esp32 is a magnificent micro-controller, It is powerful just like an Arduino but even better!
It has Wifi connectivity, Enabling you to develop IOT projects cheaply and easily.
But Working with Esp devices is frustrating, First it is not stable, Second it is extremely difficult to develop your projects with the official SDK. Third it is a huge headache to find a suitable working library.
What if you could use all of the functionalities of the mico-controller while also code it in PYTHON.
Would it make a difference? of course, Python is powerful, easy to read and extremely easy to write.
Plus you don't have to worry about all of the low level stuff (pointers, registers and configuration files)
Also, You are using Zerynth stable system.
If you are not familiar with Zerynth yet, it is the next BIG THING!
It gives you all of the functionalities of the micro-controller with the easiness of Python and it is Free
Let me introduce to you the Esp32 Temperature and humidity web server written in Python.
Step 1: Step 1 : Hardware Connection
The hts221 Temp and humidty sensor uses I2C connection, You have to connect the sensor to the appropriate pins in the ESp32
Node-MCU Esp32s Hts221 Sensor
3v3 pin --> 3.3v pin
GND pin --> GND pin
IO26 --> SCL pin
IO25 --> SDA pin
Step 2: Step 2 : ESP32 Code
- Connect your Esp32 development board to your computer.
- Download the Latest Zerynth Studio IDE for free : https://www.zerynth.com/zerynth-studio/
Use this installation Guide to help you:
https://docs.zerynth.com/latest/official/core.zery...
- Inside the application; Create a new account and vertualize your device.
Use this guide to help you
https://docs.zerynth.com/latest/official/core.zer... - Now Create a new project from main toolbar ; Project --> New -->Write a name for the project and save it.
- Find the code Attached
- Copy the code and Uplink ( upload to the uC)
- Open serial monitor
- Copy the Ip-address to your browser and open the web page !
If you need help with the IDE : https://docs.zerynth.com/latest/index.html
Step 3: Step3 : Code Sample !
You can find the whole project attached!
This wanted to show you how easy it is:
from stm.hts221 import hts221
temp_hum = hts221.HTS221( I2C0,D16) #initiate i2C protocol with the sensor
temp, hum = temp_hum.get_temp_humidity() # get the current temp and humidty using the library !
from espressif.esp32net import esp32wifi as wifi_driver #importing Esp32 Wifi driver
WifiAP_name = "WIFI AP Name"
Wifi_Pass = "Wifi Pass!"
wifi_driver.auto_init()
wifi.link(WifiAP_name,wifi.WIFI_WPA2,Wifi_Pass)
It is that easy to use Zerynth IDE with python.
