Exporting Multiple Bodies As One STL File in Fusion 360
Introduction: Exporting Multiple Bodies As One STL File in Fusion 360
About: Vladimir Mariano is the founder of desktopmakes.com and instructor of the online course Designing for 3D Printing with Fusion 360. He is cofounder and president of the Fairfield County Makers’ Guild, a...
When I first started using Fusion 360, one of my favorite features was the ease of going from 3D model to 3D printing. No other software provided a smoother workflow. It’s very straightforward to do if your model contains only one body. However, if you are trying to export multiple bodies, it can get a bit tricky. But no worries, I’m going to show you the trick.
Step 1: Exporting a Single Body
Let’s first go over the process of exporting a single body. Simply go to Make on the toolbar and choose 3D print.
Step 2: Send to Slicer or Save As STL
You’ll then see this dialog box pop up. You now have two options: 1) Send the body directly to a slicer of your choice, or 2) Save the model as an STL file. If you choose to send the model directly to a slicer, simply check the box that says “Send to 3D Print Utility”. If you would rather save as STL file for later use, simply uncheck this box. If you decide to send directly to a slicer, you have the option of choosing a slicer from the drop down list. You also have the ability to add your own specific slicer by choosing Custom, clicking on the little folder and navigating to your slicer application. This will assign the slicer to the custom choice so that whenever you choose custom, that slicer will open up. For example I currently have Simplify3D as my custom slicer.
Step 3: Exporting Multiple Bodies
Now that we’ve covered how to export a single body let’s go over how to export multiple bodies. Here’s an example of three separate bodies that are not connected to each other. The intuitive thing to do would be to select all bodies by drawing a selection box around everything and then Choosing Make - 3D Print. However, this method will not work. In order to 3D print multiple bodies you first need to right click on the name of your project under your browser. If you have saved your design, it will be the name you gave it. In my case since I haven’t saved yet, it simply says “Unsaved”. Right click and choose Save as STL.
Step 4: Select Which Bodies You Want to Export
Doing this will open up the same dialog box as before, however, now you have the ability to select which bodies you want to include by toggling the visibility of the lightbulbs next to your bodies on or off. All bodies that are toggled on will export. Select which bodies you want included and click OK.
Step 5: Step by Step Video
Here’s a step by step video of the entire process. If you’re interested in learning how to design with Fusion 360 make sure to check out desktopmakes.com
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
    • Audio Challenge 2020
    mdeudon
    mdeudon
    25 days ago on Step 4
    Thank you for this post, it helped me ;-)
