Fab-House (a Modular Open Source House Made From Cnc-cut-parts)
17,149
185
31
Introduction: Fab-House (a Modular Open Source House Made From Cnc-cut-parts)
The FabHouse, is generally inspired by the tiny house movement and in particular by the Wikihouse and the Earthships, which favors not only environmentally friendly and affordable living but also a natural life and democratic house building.
The FabHouse was made in an interdisciplinary course at Rhine-Waal University of Applied Sciences in winter term 2017-2018 by the people of FabLab Kamp-Lintfort. We developed an open source self-sufficient house that can be reproduced in any of the >1400 Fab Labs worldwide and be deployed anywhere in the world. This vision is taken from the WikiHouse-Project, which “endeavors to democratize and simplify the construction of sustainable, resource-light dwellings“. However, the focus of this course was to not to simply copy it but to ‘Re-Think it’, driven by the goal of making it as sustainable as possible. This included not only the construction of the house and materials used but also energy harvesting and management systems.
More details about the project can be found here.
Step 1: Decide Your Space
The Fab House construction system is based on three modules: Middle, corner ('cake') and the key module.
Key modules link all other modules and provide columns to carry the roof. Corner modules can be mirrored, construction-wise. Middle parts are used to stretch the space in whatever size you have in mind. All modules are growing around the core.
The modular structure of rectangular and cake-like-pieces enable the house to grow and shrink, according to the users’ needs. If more space is needed, even after the house has been finished, it can be extended at any time by just removing one of the outer walls and by attaching one of the preferred modules. Shrinking takes place in a reverse way.
  • The smallest combination of modules would be with 3 modules (one middle, two corners, and one key element).
  • Corner provides 1.5 m²
  • Middle provides 2.7 m².
  • The smallest combination would provide you 5.7 m².
Step 2: Design Your Tiny House
With the modular technique, you can design your own space.
As an example, you can see a half-size-doughnut plan of a house in the image above.
  • Please download the FabHouse Sketchup-file.
  • You can download house interior components from Warehouse 3D if you like to play a bit.
Step 3: Understanding the Technique
Fab-house is made out of 18mm thick OSB wood. You can simply make it from any 18 mm material which can get and cut with a CNC router. This tiny house can produce by anyone who has access to a proper CNC machine. The cutting files can be arranged according to the size of the machines workspace (machine bed).
  • Decide on your material and its size. The bigger the machine bed, the easier to create many parts at a time.
  • In your DTP/CAD-Software, place the pieces to cut according to your material sheet template.
  • Likewise, you can see how much wood sheets you will need.
  • Order your material and enjoy cutting.
Step 4: The Foundation
The manual provided describes the assembly of the house in detail. Plan ahead and prepare the base for your construction. You need a balanced fundament or structure made of beams to place the ground sheets of the house. We used we used styrofoam which turned out to be quite effective. It is easy to handle and as a side effect, it inhibits the moisture from the soil. We dug into the soil and placed a layer of sand, leveled it and put the styrofoam on top of it.
Here you can download the Fab house assembly manual.
Step 5: Basement Pieces
Before pouring the bulk insulation you have to complete these steps for the basement. You can use some brackets for the first step.
Step 6: Basement Insulation
Then you can pour the bulk insulation to the basement and after that, place the ground floor sheets. (Hint: try to place the ground floor sheets temporarily, to make sure all alignments are correct)
Step 7: Structure
You should follow the rest of the manual to build the FabHouse.
Step 8: Walls and Roof
After having completed the base structure, you should apply the outside sheets for the walls, before applying the insulation material from the inside. We also recommend placing the roof sheets first.
Step 9: Wall Insulation
We used wood wool for insulation (80mm thick, 135 x 57.5 x 8 cm). This is a standard size but can easily be cut to whatever size you need.
Step 10: House Wrapping
House wrapping is essential if you want to live inside the house :). Because of any possibility of water leaking into the OSB material, can cause fatal damage to its structure. Before covering it with larch wood, we put an extra layer of vapor diffusion open underlay foil.
Step 11: Applying the Metal Roof
Onto the OSB on the roof, we used the same vapor diffusion open underlay foil to cover it. On Top, we placed some beams which were used as the base structure for the profiled sheets (metal). In our case, the roof was sponsored by a company named Siegmetall. You may find similar products in your area.
Step 12: Mounting Windows and the Door
We bought wooden windows for the house in the proper size. They could easily be placed in the openings and have been screwed onto the frame after they were properly aligned. The same was done with the frame of the door.
Step 13: Applying the Larch Wood
To cover the walls and to make it long lasting, we used larch wood which we applied line by line onto the outside walls. We placed some beams beforehand because this creates extra space for air ventilation.
Step 14: Happy Living
Enjoy a sustainable housing :)
Tiny Home Contest
Runner Up in the
Tiny Home Contest
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Metalworking Contest
    • Puzzles Speed Challenge
    31 Discussions
    UdyRegan
    UdyRegan
    1 year ago on Introduction
    This modular open source house could open up various opportunities to help address the issue of homelessness not just within this vicinity, but everywhere else as well. Though it might not directly become a solution in the near future, it could offer an alternative as a long-term plan. The idea can be further explored to see how a homelessness predicament at any given location can be tagged to such a modular house accommodation option.
    I reckon that if you can get your hands on to spare parts for wood, and enough of it at that, you'd be able to put together something pretty decent for yourself to use. It might not have to be as big as to be able to be called a home, but perhaps you might be able to make a shed out of scrap if you wanted to! Whatever it is, it's great to see people looking more towards recycling such material!
    woodlab
    woodlab
    1 year ago
    How do these walls compare in strength to other types of construction?
    fablabkamplintfort
    fablabkamplintfort
    Reply 1 year ago
    We cannot say, to be honest. But that's one of the reasons why we built it. This is just a test-case of a bigger one, we are planning to build.
    alexwhittemore
    alexwhittemore
    Reply 1 year ago
    I'm curious both about the strength (can't wait for some longer-term notes!) and how the CNC wall construction compares to good old framing and nails with respect to effort. I'm unclear where there are gains to be made going this way. I've seen some other tiny house concepts integrate CNC, but for less pervasive aspects of construction. For example, CNC-shaped panels for cabinetry, since it's much faster and easier to assemble ikea-style cabinets that already fit the tight space perfectly vs hand-shape something to fit as well. I wonder if you feel like you saved effort, in practice, assembling the cut shapes vs nailing.
    davidwat
    davidwat
    1 year ago
    A great idea, but doesn’t anyone else think this thing is ugly?
    fablabkamplintfort
    fablabkamplintfort
    Reply 1 year ago
    Of course ... nut no ... ;)
    Just kidding. Well, you may think so but we like it. You can download the files and modify them. You can also just capture the idea and create your design based upon it. We would love to see variations!
    davidwat
    davidwat
    Reply 1 year ago
    I apologize, that was very rude of me. It is a way cool process, and the example would make a fine workshop, but when you are making tiny houses, you somehow need to figure out how to give it a more open feel maybe with big windows, skylights, or something. Otherwise, it's like living in a closet. I would be excited to see it with furnishings, etc.
    fablabkamplintfort
    fablabkamplintfort
    Reply 1 year ago
    You are right. But due to money constraints we had to go with the smaller windows. Wen wanted them to be bigger but we ran out of our budget ;)
    jessyratfink
    jessyratfink
    1 year ago
    This is so clever! And I love the rain catch on the back. I'd love to see photos of the inside!
    fablabkamplintfort
    fablabkamplintfort
    Reply 1 year ago
    Thanks. Currently it looks little messed up inside. But I will check whether I can find some older pictures.
    That looks really nice. I need to make one of these as a workshop.
    fablabkamplintfort
    fablabkamplintfort
    Reply 1 year ago
    If you need any support, jsut let us know.
    Sardinops
    Sardinops
    1 year ago
    The windows are set quite deep. Are you sure water doesn't enter the structure?
    fablabkamplintfort
    fablabkamplintfort
    Reply 1 year ago
    Yes, it doesn't. We made little window benches out of steel.
    Dwargh
    Dwargh
    1 year ago on Step 14
    Schaut super aus! Bin mal auf weitere instructables von euch gespannt! :)
    Looks great! am looking forward to your further i'bles! ;)
    xred11
    xred11
    1 year ago
    The links to the build manual and more information don't seem to work as posted.
    DavidH62
    DavidH62
    Reply 1 year ago
    I would also like to see the build manual
    fablabkamplintfort
    fablabkamplintfort
    Reply 1 year ago
    Hi. We have updated our Website - all files should be available now. Sorry for that.
