Introduction: Fabric Art: Tie and Dye
This Indian technique of tie and dye is called “Bandhini”, which means “to tie” in Sanskrit. It involves tying the fabric with a thread tightly then dying it, leaving the tied portion without colour. I am sharing here some photos of the process as I did this art!
Step 1: You Would Need
A cotton dyeable cloth, some string, and many small round beads. I used dry yellow peas because they were the perfect size I needed, you could use anything else, round stones work as well!
Step 2: Tie the Beads
Before I started I doubled the fabric so that the effect would come on both the ends. Now take the bead which you have, wrap it around the doubled cloth and tie the string around it as securely as possible. Show a bit of muscle here, because later when you dye the cloth you don’t want the dye to reach the cloth. This will create your Bandhini effect. You don’t have to knot the string after every bead, just take the same yarn to the next bead and keep continuing.
Step 3: Continue Tying, Create a Pattern
Now that you know the technique of tying, wrap the beads all along the cloth in what ever formation you like. You can create a new design every time. This is how I tied my beads. After 5-6 hours of hard work I was done! All that pulling had given me boils on my fingers. But I was very exited to see it being dyed now
Step 4: Finish the Design
Here are some more pictures of the beads tied to the cloth. See how pretty they look tied together! Also how it looks from behind.
Step 5: Die the Fabric
I had envisioned a progressively receding pattern, hence I decided to give the fabric ombre dying effect. I did not completely dye the fabric but only its ends.
Step 6: Open the Yarn
Here is how it looked after being colored. After it was dry, all was left was to rip the thread off the fabric. The best part ever!
Step 7: We Are Done!
Step 8: Time to Start, Make It Yourself
See how pretty the effect looks finally. Now go ahead and try it, its worth all the effort.
Have a look at my blog to see many more hand made products and DIY's
https://tangytinge.wordpress.com/
Thanks for viewing :)
Second Prize in the
Dyeing for Color Contest
Leftovers Challenge
