Introduction: Fan Boat Lego DIY
This is an instruction for building a beginner level fan boat using basic legos.
Step 1: Step 1
Locate the flat 2x10 (red) block, and the 45 degree block (yellow) block. Then attach the yellow block at one end of the red block as pictured below.
Step 2: Step 2
Find the 2x8x1 (white) block. Attach it directly behind the yellow block. There should be one row of connector dots left on the red block. See picture below.
Step 3: Step 3
Locate the flat 4x10 (grey) block and attach it atop the white & yellow blocks. Make sure it is centered on the white & yellow blocks.
Step 4: Step 4
Holding the bottom red block by the two remaining cennector dots. Attach the clear 45 degree block to the upper left corner.
Step 5: Step 5
Hold as in Step 4. Attach the yellow roll-bar to the second row of the 4x10 (grey) block up from where your fingers are located.
Step 6: Step 6
Clip fan blade (black) to the 1x2 (white) block with the cylindrical pop-connector.
Step 7: Step 7
Attach fan assembly to the boat direct to the rear of the roll bar. Make sure it is centered on the 4x10 (grey) block.
Step 8: Final Product
Enjoy your completed Fan Boat!
