Fizzle Loop Synth II
12,024
126
18
Introduction: Fizzle Loop Synth II
About: I've always liked pulling things apart - it's the putting back together again that I have some issues with!
This is my 2nd version of the fizzle loop synth and this time I use 4 x 555 times (yes you heard me right!)
Its circuit is really just 2 flashing LED circuits and also a light Theremin circuit mashed together. I’ve added a potentiometer to each LED to be able to dim it along with the ability to change capacitor and resistor values via switches. This gives you the ability to change the sound, tone and speed of the synth making for a much more varied sound machine then the first Fizzle Loop synth.
I also used 2 vactrol’s (check out step 3 on what these are if you haven’t heard of them before) which connect the flashing LED’s circuits to the light Theremin circuit.
After a bit of experimenting I found that the values on the resistors and caps I choose gave me a good range of sound. I strongly encourage you if you do make one of these, to do your own experimentation to find what works best for you.
Check out the video of the synth in action
Step 1: Parts and Tools
I didn't bother showing images of all of the parts - I don't want to scare you off!
Parts for the circuit
1. 4 X 555 Timers – eBay
2. 2 X 22uf Capacitors – eBay
3. 2 X 10uF Capacitors – eBay
4. 2 X 0.1uf (103) Capacitors - eBay
5. 2 X 10K resistors – eBay
6. 2 X 1.5K resistors – eBay
7. 1k Resistor - eBay
8. 3 X 500K Potentiometer – eBay
9. 2 X 100K Potentiometer – eBay
10. 1 X 5K Potentiometer - eBay
11. 4 X 5mm White LED’s – eBay
12. 2 X Photo Cells – eBay
13. 8 ohm speaker – eBay
14. Proto board – eBay
15. Lots of thin wire. I use computer cables to get from my local tip.
16. Heat shrink (used to make the vactrol so will need to be big enough to fit a 5mm LED and photo cell inside.
17. 6 X AA batteries (equals 9v). You could also just use a 9v battery.
18. 6 X AA Battery holder – eBay
19. On/off switch for the power - eBay
20. 4 X on/off toggle switches – eBay
21. Audio out jack - eBay
Parts for the case
1. Case. I used a cigar box which you can easily get from eBay
2. Knobs – I used following ones
Skull knobs
Small knobs
Large knobs
3. Speaker cover. I haven’t been able to find the one I used on the net but here is a similar one
4. Small screws, nuts and bolts
Tools
1. Soldering Iron
2. Drill
3. Hole bit
4. Wire cutters
5. Screwdrivers, spanners, etc
6. Hot Glue
Step 2: The Flashing LED Circuit
The first image below shows the original flashing LED circuit and the 2nd shows how I modified it. In the original, you controlled the speed of the LED by the 100K Potentiometer. The 10K resistor between pins 6 and 7 control how fast the LED will flash. A lower resistor will make the LED flash faster.
In the modified circuit, I have added another potentiometer at pin 3 which now allows you to control the brightness of the potentiometer. You can also see that I have added a switch for the resistors on pins 6 and 7 which give the ability to change the speed of the LED. I have also added another switch on pin 2 and an extra capacitor so I can switch between these as well which also gives you more ability to change the sound.
Lastly, you can see that I have added another LED which is connected to a 7.5k resistor. This LED goes on the outside of the synth so I can visually see how fast and how bright the LED inside the vactrol is flashing
I would suggest that you build the original circuit first and get this going. Then experiment by adding different value resistors and caps to see what happens to the LED.
Step 3: The Light Theremin and Final Circuit
The first circuit in the images is the light Theremin and it doesn’t really have any modifications. The only thing different is the 2 CdS cells or photo cells are added into vactrol’s. I also added a 500K potentiometer to one of the photo cells. This helps change the tone and adds another way to change the sound.
The next circuit is the final circuit with both Flashing LED and Theremin circuits joined together. You may notice that in the flashing LED circuit on the left, that there is a 10K potentiometer to control the brightness of the LED. I found that a 100K pot had too much resistance and was turning the LED off when turned about half way on this circuit.
Lastly, I’m not going to go through step by step instructions on how to put the circuit together. It will just be too long and I’m going to assume that you at least know how to breadboard and solder circuits.
Step 4: What Is a Vactrol?
A Vactrol acts like a potentiometer - applying a voltage to the Vactrol's LED has the same effect as turning up the knob on the potentiometer.
It consists of two components incorporated into one package: a light-emitting diode (LED), and a photoresistor (a resistor whose resistance drops when it is exposed to light)
It’s important that the only light that the photo cell can detect is from the LED. If outside light is able to reach the photo cell, then it will interfere with the performance and sound, that’s why you need to add something like heat shrink to protect them.
Step 5: Making a Vactrol
Steps:
1. Cut a small length of heat shrink tube. The LED and photo cell need to be able to fit inside.
2. Place the LED into the heat shrink with the legs facing out and also the same for the photo cell. Make sure that they are touching inside the heat shrink.
3. Heat the heat shrink and start to shrink it. Start with one end first and when it has shrink enough, grab some pliers and flatten the end of the heat shrink so it is sealed shut.
4. Do the same for the other end
5. That’s it! You have made an important component to the fizzle loop synth
Step 6: 1st Circuit - LED Flasher
Steps:
1. Start with the first flashing LED circuit and solder it to a protoboard as far left as possible
2. I didn’t wire-up all of the potentiometers, switches etc as I will do this once the circuit is complete. However, add wires to the solder points in preparation.
3. I added a couple of female pin headers for the capacitors. This way i can change them out if I want to for other values and get different timing and sounds out of the synth.
4. Lastly, test the circuit to make sure that it works. I just added the wires, LED and Pot to a breadboard and tested to make sure the LED flashed.
5. Once you have this first circuit working, you should then add the Vactrol. I have included a separate step on how to make one of these and also what they are. You can also buy them if you want to but they are very simple to make so I would suggest just doing your own
6. Solder the vactrol into place making sure you note the polarities of the LED legs when attaching them to the 555 ic and positive.
Step 7: 2nd Circuit - Light Theremin
Next section to add to the protoboard is the Theremin circuit.
Steps:
1. Carefully follow the schematic when adding to the protoboard
2. Remember to connect the vactrol to the section where the photo cells are connected. Connect the first vactrol to the LED flashing circuit you have already added to the protoboard. The other one you can wait until you have built the last flashing LED circuit
3. Make sure you test this circuit as well before you attach it to the vactrol. All I did was add a couple of photo cells (CdS cell) to the pins on the 555's, added a speaker and some power and made sure that the light theremin was working correctly. It's definitely worth taking the time to test - I messed-up 2 boards before I got it right and it was all due to not testing.
Step 8: 3rd Circuit - the Last Flashing LED
Steps:
1. Build and complete the last flashing LED circuit and add this to the right of the Theremin circuit.
2. Test and make sure that an LED flashes
3. Next, solder the LED section to the Vactrol making sure your polarities are right.
4. You will probably use most of the protoboard so make sure that the case you choose is big enough to house the whole thing.
That’s pretty much it for the circuit. It’s now time to start on the case
Step 9: A Few Ad-hoc Changes
It took me 3 tries before I got this circuit right! The first 2 half worked but I couldn't trouble shoot them to work out why they wouldn't work properly. Each time I re-started the circuit I add a couple new ideas which I'll go through now.
Adding IC sockets
I usually just solder the IC directly to the circuit board. The problem with doing this way is you can't remove the IC if it doesn't work. Well you can but you have to de-solder and everything just starts to become a mess. In the 3rd iteration I added IC sockets so I could easily change them if I needed to.
Making the Capacitors Changeable
This wasn't necessary but I thought if I wanted to get different sounds out of the synth, then making the capacitors easily changeable would allow me to change the sounds later on. I just used some female headers and soldered them onto the circuit board. the legs of the capacitors fit inside them.
Testing
I know that this is probably self evident, but I tend to rush when I'm making and sometimes skip the testing stages. On the final board I tested each circuit (both flashing LED's and light theremin) to ensure they worked before I finally attached them altogether. It meant that I had to add a couple of temporary parts each time but it was worth it.
Step 10: Adding the Switches and Knobs to the Case
I used a cigar box for the case. I find that they have a lot of room inside to add all of the parts and they also look pretty damn cool. I also added the knobs and switches first before the speaker. This way I could work out the best position once all of the other parts had been added. I'm going to assume you too have a cigar box for your case as well.
Steps:
1. First drill 3 holes and add the 500K pots.
2. Next, I secured the knobs to the pots
3. Add a toggle switch above the 2 500K pots on either side
3. Next I added the 100K pots above the 2 toggle switches
4. Then add a toggle switch above each 100k pot
The switches allow you to change the speed and sound of the pot underneath it.
Step 11: Speaker and LED's
Steps:
1. First I added the LED's. You don't have to add LED's but I find that they are a good visual indication on the speed and brightness of the LED's in the vactrols.
2. Use a hole bit on a drill and make a hole in the top of the cigar box just big enough to fit the speaker inside
3. I added a computer fan cover next over the speaker to protect it. To do this I also needed to add some spaces to ensure the fan cover wasn't touching the speaker. Secure in place with some small screws and nuts.
So that's pretty much for the lid of the case. I added a few extra switches later on which I'll go through in the next step.
Step 12: Soldering the Circuit Board to the Pots and Switches
Once you have added all of the switches and pots, it’s time to solder the circuit board to them. This isn’t really a hard step, it just needs a little patience to sort out the wires and where they are to be attached. It’s up to you on how you want to configure the different effects and sounds – I’ll go through how I laid-out my synth but you may want to do it totally different
Steps:
1. The 2 large pots on the left and right of the synth are used to control the brightness of the LED in the Vactrol
2. The toggle switch above each of the large knobs are used to switch between the 2 capacitors
3. The large pot in the middle is connected to the vactrol
4. The 2 smaller knobs control the speed of the LED flashing. You need to join the wires from pin 7 and positive on the 555
5. The 2 toggle switches above this are joined to the 2 resistors so you can change the valve of them and make the LED flash faster
6. You’ll also need to attach the speaker wires to the speaker. There is a 5K pot also used to volume control but as I added this into the body of the cigar box, I decided just to solder direct to the speaker for testing purposes
7. Lastly, solder the LED wires from the circuit board to the LED’s in the cigar box. These help you visually see what is happening inside the Vactrol
8. Add some power and test to make sure you are getting sounds out of the board. Play around with the pots and make sure they work ok. If not, check over your wiring and connections and trouble shoot to try and fix the problem.
Step 13: Power and Final Wiring
After you have tested and are happy with how it sounds, the next step is to add the volume pot, on/off switch and audio out jack
Steps:
1. Attach the batteries to the on/off switch and also the circuit board
2. Next solder the speaker wires to the volume pot
3. For the audio out, solder a couple wires to the positive and negative terminals on the speaker and attach these to the audio out. You can also add a 10uf cap from the positive wire to the positive terminal on the jack which will help clean-up the sound.
Step 14: Bonus! Change the Sound by Adding Some Capacitors
Adding the extra capacitors to the speaker to get different sounds only occurred to me by accident. However, it can really help clear-up the sound and also add some delay depending on the size of the capacitor.
I added a couple of momentary switches to I could turn these on when I wanted to along with a couple of SPTD (toggle) switches to be able to keep them on all of the time
Momentary Switches
Steps:
1. Add a couple of momentary switches to the top of the cigar box. I placed mine just above the first lot of switches.
2. Next, add a couple of toggle switches to the cigar box. As this mod was an afterthought, I didn’t have much room to add them. In the end I found a little space at the top of the box and added them there.
3. Next you need to add a capacitor to each of the momentary switches. Solder one leg of a 1uf capacitor to one of the legs on the momentary switch and do the same for a 10uf (to the other momentary switch. You can use whatever capacitor values you want – I just found that these gave some nice variances in sound.
4. Next, solder a wire from the leg of each capacitor to positive on the speaker.
5. Lastly, add another wire to the other solder point on the momentary switch and attach this to ground.
Test to see what happens when you push the switches down. You should get a rise in pitch and some cool delay as the capacitor charges and then releases.
Toggle Switches
Steps:
1. Add a couple wires to the solder points on the switch.
2. Solder one to the speakers positive and the other to the capacitor
3. Lastly solder the other wire from the switch to ground
Audio Contest 2018
Audio Contest 2018
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
    18 Discussions
    filsdudragon
    filsdudragon
    1 year ago
    Thank you for this brilliant tutorial.
    Here is my creation.
    I hade a potentiometer in the final circuit to adjust the sound and create more distortion.
    49012522_2097701753684768_447839680222724096_n.jpg48419769_2097701763684767_27417580864012288_n.jpg48427767_2097701820351428_2099051144343977984_n.jpg
    lonesoulsurfer
    lonesoulsurfer
    Reply 12 months ago
    Oh due - I only just saw this! looks awesome. Any issues with the schematics etc?
    technovative
    technovative
    1 year ago
    The combined look of skulduggerous menace, and Teslaesque control apparatus, appeals to my affinity for turn-of-the-century tech, and heavy-metal band accoutrements.
    An aha moment struck me a while back and I coupled an LED to an LDR. Delightful experimentation ensued. It seemed inevitable that this component already existed, but until reading your article, I was unaware of the vactrol. Thanks for that satisfying bit of info.
    audreyobscura
    audreyobscura
    1 year ago
    This came out so well, and I am now going to go try and find the skull knobs! SO GOTH! I LOVE IT!
    lonesoulsurfer
    lonesoulsurfer
    Reply 1 year ago
    Cheers! Yeah the skull knobs are pretty cool. I've added a link to where you can buy them in the parts section :)
    audreyobscura
    audreyobscura
    Reply 1 year ago
    Hey there, I've tried to email and message you a couple times about your win in the Game Life Contest - could you send me an email or a DM? thanks!! :D (this project is still totally tops. i bought some skull knobs and am currently trying to figure out what i should mount them to.)
    lonesoulsurfer
    lonesoulsurfer
    Reply 1 year ago
    Sent you a PM Audrey - let me know if you got it
    audreyobscura
    audreyobscura
    Reply 1 year ago
    Hey there! So it looks like you helped us find a bug in our DM system and my messages aren't being delivered to you for some reason. Can you email me directly at audrey@instructables.com?
    pdsmith87
    pdsmith87
    1 year ago
    Really love that copper-looking speaker. Awesome design, I'll be trying my hand at it for sure.
    Tura Street
    Tura Street
    1 year ago
    This is great. I love the skull idea, and I play the synth, so thanks for sharing this creation. Good luck in the contest.
    throbscottle
    throbscottle
    1 year ago
    I love this. Way back when I was young in the 80's I tried combining oscillators to get interesting sounds (didn't really understand what I was doing, but hey), but the Fizzle Loop is better by a long, long way.
    I enjoyed finding out what a Vactrol is - I'd never heard of them before. It would be interesting to find out what changes if you used a bulb rather than an LED.
    I might actually build this.
    Gadisha
    Gadisha
    1 year ago
    Very nice, I love the sound of synthesizers! Who knows maybe I could try a project like this in the future ( probably in the distant future). Thanks for posting, it looks great, I like that you used a cigar box.
    lonesoulsurfer
    lonesoulsurfer
    Reply 1 year ago
    cheers. If you wanted to start playing around with synths - I have done a bunch of 'ibles starting from beginner to this one.
    qdogg
    qdogg
    1 year ago
    About 40 years ago I built a high gain amp for a parabolic mic & had long wires between some components so there was lots of "motorboating", squeals, that sounded like this & more. Sorta like an involuntary synth! I like the skull knobs & the cigar box vibe. Right on.
    lonesoulsurfer
    lonesoulsurfer
    Reply 1 year ago
    "involuntary synth" sweet!
    lonesoulsurfer
    lonesoulsurfer
    Reply 1 year ago
    Would have probably been easier I know (and I have a whole bunch of them as well!) but I'm still working my way around the 555 timer. The 556 I've used in a couple projects but still a noob when it comes to working out the wiring etc.
    gm280
    gm280
    1 year ago
    You need to set up your ideas so they are triggered via an musical instrument input. That way you can create sound that can be in sync with the instrument and make it a new sound for music.
