Introduction: Front Door Halloween Scene Light Box
being Halloween I wanted to make something new for our home. The idea behind the box was, on Halloween night I will hang it up on the door or in my front window to let the trick or treaters know they can get treats at our house.
Step 1: Find a Shadow Box
The shadow box was one I left over from my daughter's bridesmaid invitations, but these can be picked up for about $7 at our budget stores and they work great.
Step 2: Find a Suitable Background
To find images I googled free Halloween images and I selected this one. When you take images off the internet you can use them for personal use as long as on your website you give credit to the creator with a link back to them. I printed my image and cut it to the correct size of the box.
Step 3: Find Silhouette Images
A good way to find images for this project is to google free Halloween silhouette images and download them to your computer. You can print them out on black paper or card stock and cut them out and glue them to the front of the glass. If you have a vinyl cutter you can get more creative with the detail in your images. But It can still be done without one, the designs will just be more basic. If you do have a Cricut the links to the images and more detail on the project are available on my website.
Step 4: Find Lights
If you want to have the box on your front door you will need to use the string fairy lights that are battery operated. They were my first choice but when they arrived they were blue and I wanted red for my scene.
Step 5: LED Lights With Remote Control
I had some LED remote control lights at home and I thought I would try them and see how they looked. And they looked awesome. They have a few settings on them to change the colour of the lights and can be set to flashing, strobe, smooth or fade. So they offer you more variety. The only downfall is they can not hang on the front door because they need to be plugged in a USB plug. But they will still look great in the front window. The lights had self-adhesive tape that I removed and stuck the LED strip to the inside of the box.
Step 6: Add a Hole for the Lights
I used a drill to make a hole in the box so the wires can come out. If you are using the battery operated lights you can attach the battery box to the bottom where the hole is using double-sided tape.
Step 7: The End Result
This was the end result with the lights switched on one of the settings.
Step 8: Materials Required to Make This Project
- Shadow box
- String fairy lights or remote control LED lights
- Glue
- Black paper or black cardstock
- Cricut machine and vinyl if you want the full detailed graphics
Another project you might be interested in Tip to restore an antique Dresser
Halloween Contest 2018
