Geneva Roller Ruler, a Pocket Sized Infinite Ruler
13,945
170
15
Introduction: Geneva Roller Ruler, a Pocket Sized Infinite Ruler
About: Hi I'm Michael! I love all things Science, Engineering, & 3D Printing. If you've enjoyed my work then I've love to hear from you!
The 'Geneva Roller Ruler' is a special pocket sized tool for measuring any line, any curve, any length! With this device you can measure square objects, round objects, straight lines, curved surfaces, you get the idea!
This tool can be very handy when measuring curved lines or oddly shaped surfaces that are difficult to measure dirctly with a straight ruler or tape measure. The roller ruler uses a wheel of known dimensions, regularly spaced tick marks, and a counter mechanism to measure up to 1/2 meter in 5 mm increments.
-The device is tiny so you can literally carry an infinitely long ruler wherever you go! :) It’s a simple but handy tool for home owners, architects, engineers, interior designers, fashion designers, decorators, art students, or anyone who needs to precisely measure irregularly shaped things on a regular basis.
-Assembly is simple so this instructable will guide you on how to print & use the device as well as tips on how it was designed.
>If you dont have a 3D printer you can pick up a geneva roller ruler in my store here<
A note on technical names:
  • The intermittent geneva drive mechanism is also known as a 'maltese cross drive'
  • Technically this device is a tiny form of "Measuring wheel". Which is very similiar to a 'curvimeter' 'opisometer', or 'meilograph'
VIDEO DEMO:
Step 1: 3D Printing Files & Settings
Print Settings: (Files attached)
  • Any material, No supports needed (Parts must be oriented as shown in the image)
  • 0.4mm dia nozzle max
  • 0.2mm layer thickness maximum
  • Minimum 2 perimeters all sides top & bottom
  • 10% infill minimum
  • Expect 2 hrs to print
Vitamins:
Post Processing:
Update: At this point I have built dozens of these devices and have learned that you can optimize the free-spinning performance by following a post processing procedure. Bore out the holes in the geneva drive & primary roller with a 3.5mm drill bit & deburr the hole edges. Also use a file to briefly smooth the raised surfaces on the clip part that make contact with the wheels. And finally after assembling break it in by manually rolling it back and forth hard on a carpet. The end result should be able to free spin the geneva wheel an entire rotation with the flick of a finger.
Assembly:
Assembly is so easy it doesn't merit its own step. Use the two screws to attach the 3 parts together. Do not over tighten as that will prevent motion. The parts are naturally pokayoke so you cant do it wrong!
Step 2: HOW TO USE
-To use, hold it like a pizza cutter and place the start mark on the starting point of the surface or line you want to measure, and then roll. Every time the primary wheel rotates once, the Geneva mechanism keeps track by rotating the counter to the next number. One primary wheel rotation is 100mm (or 4 inches for the imperial version) and the geneva counter goes up to 5 so you can measure up to half a meter before the counter restarts.
-The measurement resolution is limited to the small notch spacing on the primary wheel. The notches are in 5mm increments for Metric, & 0.25" increments on the Imperial version.
Once again, see the video demo here.
INTERESTING UPDATE NOTE:
It occurred to me that the diameter of the wheel will affect the measured length. Note the attached sketch with the large blue wheel rolling over/past portions of a rock that the small wheel would pick up. Smaller wheels produce longer measurements than large wheels and different sized wheels are better for different jobs. This is a form of what is known as the coastline paradox.
Step 3: Design Notes
I used Solidworks to design this tool from scratch. Its only 3 pieces but it was a bit of work to get the geneva mechanism properly functioning. For that I referred to a design table I found here.
Well that's all, I hope you enjoyed and get some use of of this. If you enjoyed this instructable please take a second to vote for it in the Instructables Pocket Sized Contest, Thanks!!
Second Prize in the
Be the First to Share
    • CNC Contest 2020
      CNC Contest 2020
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
    15 Discussions
    mestep
    mestep
    1 year ago
    I had a friend (who is not technical at all) print this for me. It files were simple and perfect. I do a lot of backpacking and I work with engineering maps all day. I love this little thing. I voted in the pocket sized contest too.
    OnionTheAnion
    OnionTheAnion
    1 year ago
    This is one of the most unique things I've seen on here in a while. Thanks for sharing!
    orioza
    orioza
    1 year ago
    Great idea, just to share my 2 cents worth on some add on mechanism
    Roller >> increase the friction surface by adding an O Ring
    Counter Reset mechanism >> add a sliding function with a spring return to allow the wheel to disengage and reset the counter.
    Racheting mechanism >> something to hold the roller in position, when its taken off the surface, and it will hold the roller in position. Also it make a cool clicking sound, :)
    zooms99
    zooms99
    Reply 1 year ago
    The only potential issue with the o ring would be getting the circumference correct. And that could very if other people don't use the same brand/type of o ring. But something to increase group would be useful. This would be a great use for dual/multiple extrusion. A hard core of the wheel so it doesn't warp or bend, but the outer ring in a soft semi flex.
    zooms99
    zooms99
    1 year ago
    That is awesome. Great use of the Geneva mechanism.
    One possible modification would be make it with imperial on one end and metric on the other. Then just print the metric wheel a different color than the imperial wheel. I could probably do that in meshmixer, if I really wanted to deal with that software.
    Dwargh
    Dwargh
    Question 1 year ago
    Really nice and useful!!
    Maybe the primary roller can be made from rubber as well? So there's friction on glossy, smooth or even slippery surfaces...
    Hm. Is there something like rubber filament that can be used to achieve this?
    MechEngineerMike
    MechEngineerMike
    Answer 1 year ago
    Thanks! Yes a slippery surface like glass is an issue, especially when the geneva wheel engages. But it is a surprisingly free spinning device and for paper or countertops it works great! I thought about adding a rubber o-ring to the outer rim but I wasn't sure it was worth it. (BTW 3D Printed TPU is surprisingly fairly slick because it has to be extrudable!)
    MechEngineerMike
    MechEngineerMike
    Reply 1 year ago
    Update- I experimented with using a file & a break-in procedure and now they spin even better!
    winchester883
    winchester883
    Answer 1 year ago
    There are a lot of flexible/rubber filaments. Ninja Flex comes to mind first. Yo could just give the edge a bit of a scuffing or brush on some silicone/plasti dip.
    Dwargh
    Dwargh
    Reply 1 year ago
    Great idea! Got a can of plasti dip at home! Great stuff!
    samayaraj
    samayaraj
    1 year ago
    Its osm man! Thanks for sharing this wonderful tool!
    4
    gmcpcs
    gmcpcs
    1 year ago
    I could see this being very useful to mark distances on paper maps.
