Introduction: Geometric Stool
A geometric stool inspired by Google Drive™.
Step 1: Making the Parts
Materials
- Timber: Totara - A New Zealand hard wood or what ever you have around!
- Dimensions: 40mm x 140mm x approximately 2000mm
- Gorilla grip glue
- 24 10mm dowels
- Ruler
- Pencil
- Extra wood for when you put in the vice
- 10mm spade drill bit
- Dowel markers or small nails
- Clamps
- Safety gear
- A drop saw
- Cordless drill
- A protractor or 30 degree angle
Cutting the wood
Legs 40mm x 140mm x 310mm (3 of these)
- To create a leg that narrows, mark 50mm down one side and 50mm across on the opposite corner and rule a line between the two points. Cut off the wedge.
- Down the outer length of the leg cut a 30 degree angle from a marked halfway point at the top with the drop saw.
Seat: 40mm x 140mm x 215mm cut on a 30 degree angle (3 of these)
- Using the protractor mark a 30 degree angle at the end of the wood (or set the drop saw to 30 degrees.
- Measure and cut one piece of the seat.
- Place that piece on the remaining length and mark the next piece to cut.
Step 2: Assembling the Seat
Sorry, I forgot to get many photos of this bit
- Assemble your three seat pieces together to check they fit more or less. The shape can be trimmed if necessary later on.
- With a pencil, mark out evenly between the pieces where the dowels will be between the seat pieces. I used 4 dowels per joint e.g. 12 dowels for the seat.
- Drill dowel holes and test the fit.
- Glue and clamp. Try to get the joints as tight as possible.
- If the outer opposite edges are not parallel, then trim to shape. Ensure the joints end at the points.
- Sand the seat.
Step 3: Fitting the Legs to the Seat
- Number each leg against the seat.
- Align the edges and trace the edge.
- Mark out the dowel holes on the seat. Either use dowel markers or small nails to align the centres. I used 4 dowels per leg joint.
- Drill the holes. Use tape on the drill to ensure you don't drill too deep.
- Test the holes. Glue and clamp
Step 4: Finishing It
Give the stool a thorough sanding to ensure there are no sharp corners and the surfaces are smooth. Then polyurethane or oil the stool. My preference is oil based polyurethane as it's very hard wearing and won't leave any marks on your white disco pants.
Furniture Contest 2018
