Google Assistant Controlled LED Matrix !
4,530
57
7
About: Hi, I'm Nemeen, Electronics Enthusiast! I have seen a huge decline in electronics hobbyist in past few years. I started this channel in order to inspire you to create. Hopefully, you will find something tha...
In this tutorial, I will show you how you can make Google Assistant Controlled LED Matrix which you can control form anywhere using a smartphone,
So let’s get started!
Step 1: Watch the Video !
If you don't want to read all the stuff you can watch my video!
Step 2: Everything We Need !
Step 3: Schematic, Code and Setup
Connect the
CLK to D5
CS to D8
DIN to D7 and
Vcc and GND pins to ESP8266 Board.
Then download the code for this project. Just enter your WiFi SSID and Password in the program and save it
Step 4: AdaFruit IO Setup
Head over to io.adafruit.com site
Once you login you will see Welcome Dashboard click on it, then click on Create New Block and select the Text then enter LED Matrix (program won’t work if you change it) and select Create then select it and click Next then Create Block. then go back to your dashboard and select View AIO Key and copy it.
Now open the program and paste this key here with username and upload this code to ESP8266 Board.
Step 5: Google Assistant Setup
Now we need to setup Google Assistant so we can control it to change the text on Matrix.
So head over to IFTTT.com,
Once you login select My Applets then New Applet, click on This and search Google Assistant and select it then click Connect select account and allow it
Then select Say a Phrase with Text Ingredient and here type "change matrix to $" so whenever you will say change matrix to and whatever will be after to(i.e in place of $ symbol), will be displayed.
You can select multiple triggers like that and also select what assistant will reply. Then select Create Trigger. Now click on That and search Adafruit click Connect and authorize it
Then select Send Data to Adafruit IO, select the feed name which we created earlier then click on Add Ingredient and select Text Field and hit Create Action.
That's it!
Step 6: Put Everything Together !
And last but now the least I designed case in Fusion 360 and 3D printed it on my 3D printer.
Print turned out to be great but I was not happy with the color so I decided to paint it. And because I am such a great artist I asked my friend to paint it you can follow her on Instagram
link to her account - https://www.instagram.com/bunny_anii/
Then I gathered all the complementary component soldered it secured everything together with Hot Glue and this Project was Complete!
Step 7: Thank You !
Sucess! I hope you have learned something new and found this project interesting
If you like my work
Feel free to check out my YouTube channel for more awesome stuff: https://www.youtube.com/c/Nematics_lab
You can also follow me on Facebook, Twitter etc for upcoming projects
https://www.facebook.com/NematicsLab/
https://www.instagram.com/nematic_yt/
https://twitter.com/Nematic_YT
    • Pocket Sized Contest
    • Organization Contest
    • Weaving Challenge
      Weaving Challenge
    7 Discussions
    kiwigrinder
    4 months ago
    The datasheet for the MAX7219 shows that the minimum voltage is 4V. Running it from a 3.3V supply is not recommended.
    Lycasdekiwigrinder
    Reply 4 months ago
    It will use a step-up module. so don't worry
    rsikandar
    7 months ago
    how many google assistant users can control these led's? in this instructable you authorized your google account that you are using at your device. what if i want to add two different google accounts to control the same led?
    GiampieroR1
    7 months ago on Step 7
    Really a good tutorial !
    I have just build it (only esp8266 and matrix) and il works so nice.
    thank you very much - ciao
    saaviverma8060
    7 months ago on Step 3
    Can you please share a small introduction and future scope of this project?
