Introduction: Graphical Roulette With Obniz
I have made a graphical roulette. If you press the button, the roulette starts rotating. If you press again, the roulette stops rotating and beeps!
Step 1: Circuit
We use only a wired speaker and a button.
The pin numbers of wired are written on the program.
<p>button = obniz.wired("Button", {signal:6 , gnd:7 });<br>speaker = obniz.wired("Speaker", {signal:0 , gnd: 1});</p>
Step 2: Rotate Rulette Image
In HTML, you can use "CSS transform". For example, this is the code of rotate image 90 degree.
document.getElementById("roulette").style = "transform:rotate(90deg);";
To start and stop rotate slowly, add a var speed for rotate degree per frame.
let speed = 0;
let deg = 0; function rotate(){ deg += speed; document.getElementById("roulette").style = "transform:rotate("+deg+"deg);";} setInterval(rotate,10);
Step 3: Beep
Do you want to beep on the roulette no change? With this, you can beep on 440Hz 10ms.
<p>speaker.play(440);<br> await obniz.wait(10); speaker.stop();</p>
This is how to know on change of roulette no.
<p>if( Math.floor((deg + speed) / (360/7.0)) - Math.floor(deg / (360/7.0)) >= 1){<br> onRouletteChange(); }</p>
So, this is the code of rotate and beep.
<p>let speed = 0;<br> let deg = 0; function rotate(){ //on change value if( Math.floor((deg + speed) / (360/7.0)) - Math.floor(deg / (360/7.0)) >= 1){ onRouletteChange(); } deg += speed; document.getElementById("roulette").style = "transform:rotate("+deg+"deg);";</p><p> } setInterval(rotate,10);</p><p> async function onRouletteChange(){ if(!speaker){return;} speaker.play(440); await obniz.wait(10); speaker.stop(); }</p>
Step 4: Start on Button Pushed.
To know button state, add var buttonStateand set value of current button state.
<p>button.onchange = function(pressed){<br> buttonState = pressed; };</p>
And also add var phase for current state of roulette.
phase is setted one of this.
<p>const PHASE_WAIT_FOR_START = 0; <br>const PHASE_ROTATE = 1; const PHASE_STOPPING = 2; const PHASE_STOPPED = 3;</p>
For example, when phase is PHASE_WAIT_FOR_START and you want to next phase.
<p>if(phase == PHASE_WAIT_FOR_START){<br> speed = 0; if(buttonState){ phase = PHASE_ROTATE; } }</p>
To speed up rulette, change var speed .
<p>if(phase == PHASE_ROTATE){<br> speed = speed+0.5; }</p>
To speed down rulette, change var speed .
<p>if(phase == PHASE_STOPPING){ <br> speed = speed-0.2; }</p>
Those are component of roulette. Let's make it!
Step 5: Program
Please refer here for the program
Game Life Contest
