Introduction: Hair Tie Clamp for Amputees
This clamp was designed to assist amputees with completing a task that, to many, would seem trivial, but to an amputee, would pose a problem: tying a hair tie.
Step 1: Print Clamp
- Scale the clamp based on the size or amount of hair
- Print 2 copies of the model with the desired dimensions
- Both must be the same size to fit properly
- Find a nut and bolt that would fit through the center hole of the model
- glue a spring that fits into the smaller holes in the handle
Step 2: Attach the Clamp and Tie Hair Tie
- Use the clamp to secure all of your hair into a single, tight, column
- The clamp will spring closed allowing it to hang from the base of the head
- With the hair secured, wrap the hair tie around the fingers of your hand, creating an opening used to pull the hair through
- Pull the column of hair through the hair tie
- Remove the clamp from hair
