Introduction: 3D Printed Halloween Pencil Holder
Step 1: Design
For Single Color
Not recommended for dual color
- In Tinkercad editor start by creating a pumpkin
- I made mine by making a low-quality 3D oval shape and duplicating it in circle and then added one in center DON'T USE HIGH QUALITY IT IS HARD TO WORK WITH AND SEEMS IMPOSSIBLE TO DOWNLOAD
- Copy it
- Shrink copy
- copy copy
- make second copy hole cut it into pumpkin's center
- give it eyes by using two triangles
- give it a mouth using a half circle then cutting out to what you want
- cut eyes and mouth into pumpkin
- Align small pumpkin(copy) with the large hollow pumpkin
- group
- duplicate that in a circle your chosen size the less pumpkins the easier it is to work with
- Duplicate move up twist by 12.25 degrees and duplicate several times
- added cylinder to bottom to created flat surface
- Cut hole into it
Unfortunately dual color does not work properly with this method as pumpkin mouth gets messed up so I created instructions for anyone who wants to print in dual color as well.
For Dual color
Do not use for single color as faces will not be visible
- Copy it twice
- shrink copy
- make copy hole and cut it into the pumpkins center
- give it eyes using two triangles
- give it a mouth using a half circle and cutting out what you want
- align to middle of front
- duplicate eyes and mouth
- switch duplicate to hole
- cut that into pumpkin
- create a large cube
- switch second copy of pumpkin into hole
- align and group with cube
- switch that two hole
- align with pumpkin
- group everything
- Cut hole into it
Step 2: Files
Here are files for mine
OBJ for dual color 3d printing (I recommend you download the new version, old version uses single color design style and does not print faces correctly)
Stl for single color
Step 3: Printing
Dual Color
This is probably around a 25-40 hour print in .2 mm quality and dual color. 27 hours for old version
33 hours for me
Single Color
It is probably around a 10-20 hour print in single color at .2 mm quality. around 17 hours for me
For some random reason estimates are very high for print time and extremely inaccurate
Step 4: Please Vote
If this was helpful for you please vote for me in halloween contest.
Thankyou
