Introduction: Hand Light
I'm not exactly sure how this idea came to me but I thought it would be pretty cool to make a casting of a hand holding a lightbulb as a sort of desk lamp. So here it is! And you can do it too!
I completed this project in less than a day never having done this before. It's not too tough to do, it just requires a little technical knowhow along with some soldering skills and the ability to follow directions.
So let's get started...
If you like this and want to learn more or see what other things I'm up to check out my website at travderose.com
Step 1: What You Need
Supplies you are going to need:
- 1 lb Alginate (I got mine from a local dental supply store)
- 4-5 cups of Plaster of Paris (I used about half of a 4 lb container, can also be found at your local home depot)
- Various containers for mixing and molding (I cut off the top of 2-liter soda bottles for the mold)
- Light bulb socket
- Lighting wire
- 2 part adhesive epoxy or a strong glue
Tools you are going to need:
- Some way to mix the supplies (a paint mixer attached to a drill works best but you could probably get away with just stir sticks)
- razor blade and/or file
- soldering iron
- solder
- wire cutters
- electrical tape
Optional things you might want:
- feed through on/off light switch
Step 2: Mold Your Hand Using the Alginate
You need to prepare a mold of your hand using the alginate. I used a 2-liter soda bottle with the top cut off as my container to mix and hold the mold in. It was the perfect shape for me and it could easily be cut away later to reveal the casted hand.
The brand of alginate I used called for a 1:1 volume mixture of alginate and water. I used 4 cups of water and 4 cups of alginate to produce my mold and it turned out to be the perfect amount for my container.
Get everything ready beforehand because the alginate sets fairly quickly. Mix the alginate mixture for about 45 seconds and then insert the hand into the mold. Try to set-up a comfortable position for your subject so they can keep their hand as still as possible in the mold.
Use the light bulb socket to get a sense of how to hold your hand so the socket will fit later. Insert the hand into the mold keeping it as still as possible and do not touch the edges or bottom of the container.
After about 5 minutes, or when the mold is set, you can begin to wiggle your fingers and pull out your hand. Alginate is an incredible material that stretches and returns back to it's form without cracking so you are able to remove your hand and still keep the form of the mold.
Step 3: Prepare and Pour Your Plaster in the Mold
The next step is to mix together your plaster. The brand I used called for a mixture of 2 parts plaster to 1 part cold water by volume. I used 5 cups of plaster with 2 1/2 cups of water which was more than enough to fill my mold.
Mix together your plaster and water in a separate container and begin to pour into the mold. You'll want to pour about 25% in at a time and lightly tap the entire mold on the ground to remove any air bubbles. Continue pouring until you are happy with the thickness of your base for your hand light. The advantage to using a 2-liter soda bottle is that it provides an excellent round base for your hand light.
Let the plaster harden in the mold for about an hour.
Step 4: Remember to Have Fun
While your hand is drying, take some time to relax. I think it's important to remember why we do these projects in the first place: to have fun and experience a sense of accomplishment! So don't lose sight of that, try not to get frustrated or mad, and enjoy the time you spend on all of your projects.
Step 5: Remove the Plaster Hand From the Mold
After an hour has passed and the plaster feels hardened you can begin to remove the mold. I first cut the bottle off of my mold and then began breaking off the hardened alginate one piece at a time. Carefully continue to do this until all the alginate is gone. I used the back of a razor blade to get into all the nooks and crannies.
You should now have a plaster duplicate of your hand and you can hold up the lightbulb to get a sense of how it will look!
Step 6: File the Hand to Fit the Lightbulb Socket
It's unlikely that your lightbulb socket will fit perfectly into the casted hand so you will need to file it down for a snug fit. I used a combination of a round file and a razor blade to file and shave down what I needed. Just start slowly removing what you need and keep trying to fit the socket in there without removing too much.
This takes some time, don't rush it. I worked on mine for about 30 minutes until I was happy with the fit.
Step 7: Optional: Painting
This step is optional depending on what you want but I decided to paint my lightbulb socket black to match my wire. You can also paint the hand for some more variations on this project.
Step 8: Soldering the Lightbulb Socket to the Wire
Next you are going to need to solder your lightbulb socket to your wire. It's a pretty simple job so if you haven't soldered before this is a good chance to get in there and try it out for the first time. Here is a great instructable on how to solder if it is your first time: https://www.instructables.com/id/How-To-Soldering/#step0
Twist and solder positive to positive and negative to negative. Finish it off with some electrical tape or heat shrink tube, test it out, and you are good to go!
Step 9: Glue the Lightbulb Socket in the Hand
The final step is to glue the lightbulb socket into the hand so it is sturdy. I used a 2-part epoxy that worked great.
Simply rim the inside of the hand with the glue and place the socket in there. After the glue has dried, screw in your lightbulb and plug it in! I got an old timey looking lightbulb from Home Depot that I think looks good, but you can use whatever suits you.
So there you have it, you're done! It's an interesting light and conversation starter. It's also pretty cool to have an exact replica of your hand.
I'm going to try making some more of these, painting the sockets and plaster hands different colors, along with incorporating cloth cords. I'm also going to try implementing mounting hardware into the mold so it is possible to mount this on a wall. There are a bunch of possibilities to change and alter this project. I can't wait to see what else you all come up with so please let me know if you try making a hand light, I'd love to see it! I'm also looking into using a different material besides the plaster so I can possibly start selling and shipping these.
I feel proud of the end result and had a lot of fun doing this project and I hope you do too!
-Trav
