Introduction: Hide--N--Slide
The purpose of this instructable is to use wasted space . I built a new workbench in my garage/work space but still did not have enough room for all my tools to be easily accessible so I came up with the slide -n- hide
this is my first intstructable so please bear with me
ALWAYS USE YOUR SAFTEY EQUIPMENT
tools needed for this project is as follows:
SAFTEY GOOGLES
GLOVES
screwdrivers
drill
1/4 in drill bit for metal
measuring tape
square
pencil {of course}
materials needed :
one pack of drawer slides (you get 4 in the package )length will vary depending on your space
1 package of 1 1/2 in L brackets
2 shower door rollers
4 #6 x 1 1/2 flathead screws
2 flat washers to fit #6 screw
wood
Allot of patients :>)
STEP 1
put the drawer slide into a vise and drill out the rivet that holds the roller onto the bracket
keep in mind that the roller has ball bearings inside and when it comes out those little suckers will go everywhere if you're not careful lol
I placed a hand broom under the roller to catch it (rather than taking a chance of drilling thru my finger )
STEP 2
mount the slide brackets onto the sides 1 1/2 inches from the back
Step 3
measure the width of you opening and subtract one inches and that should be the width of the board you need
Step 4
cut your board at the measurement you just came up with for width and the desired length
note : the opening I had was 27 inches long but I only cut my board at 21 inches leaving room for another project your board length will vary depending on what your needs are
Step 5
measure on your board 3 inches from the end you want in the back and mount the 2 shower rollers ( with the nut side towards the board ) the #6 x 1 1/2 flathead screws also mount the front rollers same method but you need 2 small flat washers the will allow it to roll when tightened
Step 6
mount your board into your sliders (back rollers only as you want to mark your desired limit of the pull down )
Step 7
position your board to the desired spot you want it to stop and mark your side walls
Step 8
install you L brackets at the angle you want the board to stop
Step 9
install your board to see if everything works as desired
Step 10
now you can attach anything you like to the board
hope this helps someone
Total cost of this project around $10.00 includes wood for 2 HIDE-N-SLIDES
i used a scarp piece i had left over from another project
This would also work for under the bench as well
any question please feel free to ask and like I said this is my first instructable so please be gentle lol
and please excuse if i have set this up wrong
Thanks for looking
batteriesnotincluded
SAFTEY GOOGLES
GLOVES
screwdrivers
drill
measuring tape
square
pencil {of course}
materials needed :
wood
STEP 1
STEP 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Thanks for looking
